wattsup
Quote from: ronotte on April 30, 2012, 03:26:02 AM
Hi wattsup,
I understand your doubts hence the complete interconnected circuit sometime is much better than words: I would have done it before ;D . Do not hesitate to contact me for any reason. Good luck
Roberto
Ahhhhhhh, thanks @ronotte. Yes a picture is often much better then words. Lucky I decided to wait. Tonight will be the first tests. Thanks again.
wattsup
27Bubba
@jbignes5
So far, I have read all of your posts and most of the material you have pointed to. I'm enjoying all of it. Although I have problem comprehending good part of it. I think you into something. What you are saying make sense to me, because the Tesla concept is rather simple once understood completely. Obviously I'm not there yet, by far..  But I'm working on it! Recently I have looked at the Kapanadze setup trying to see similarities between his and Tesla coils, Those must be similar setups, and simple.. But often simple things are easily overlooked... Keep on the good work! ;)
jbignes5
 Thanks.
The real thing is that even I don't know it all and as Tesla stated we are all learning about this process with every step. But I am limited to my experiments because of my failing back. My scoliosis of my youth has finally caught up with me and the pain at times is rather bad. Along with the shaking my hands are exhibiting it makes it really tough to work on things.
This is why I am here telling others what I think I understand of this process. If someone picks up this with real experiments that I can not perform myself due to my illness then I will have contributed to that discovery. But like I said I think I am understanding this process and haven't proven it to myself or others by real experiments.
But I have a good amount of experiments that I have done with Jewel thiefs and the captret already that make me believe I am on the right track. The motor I plan on making should break the barrier and supply us with a clean power source even with regular batteries. This is because of one fact and the whole reason Tesla make statements that the capacitor is a wonderful thing and thats the discharge of a capacitor can be very very explosive. This energy can be used after conversion or in the event of the motor designed to transform it into heat and mechanical energy. You could think of it like the rifle. When the capacitor is loaded it's explosiveness  can be very great just like the bullet this discharge has great power. Harnessing the full discharge is the main problem. The toroid is one fix for that problem.
The Kapanadze method is actually a loose coupling of the main current line to a source of inductive high voltage. I think one way he gets around the buildup and stagnation of the high voltage coil is to allow it to build up then discharge in a cyclic way. This has a way of pulsing the main current line which is in loose coupling to the high voltage inductive coil. So at the center is the high voltage coil that builds up in inductive high voltage. When it gets to a certain level it discharges across a gap to equalize both ends of the coil. The high voltage coil is not in direct connection to the main current line and is only inductively coupled. I think this is where the magic is. It radiates and pulses the radiation on the High voltage coil which radiates into the high current coil raising it's voltage and hence the watts produced. If a core is provided you must take care to not excite the core beyond it's heat rating for keeping the core magnetic response of the current coil. As heat goes up so do the losses in the core. This is what happened to Wess and his experiments. Using iron would alleviate that to a degree but not if it isn't designed right with the cores, if cores are to be used.
27Bubba
Quote from: jbignes5 on April 30, 2012, 04:26:45 PM
Thanks.
I know and understand what you are saying, my wife is battling the same condition some days are worse than others. What ever you do please take your time and be careful.
If you don't mind explaining this, can you elaborate what is the motor Tesla was referring to and you plan on making?
Is it some kind hybrid AC motor? If so how it is different from common AC motor? This part I don't understand..
I'm sending you pm..
jbignes5
Yes I can elaborate. I'd rather keep this public so others can try this as well.
Ok so take a gander at the scrib book again and read more on the motors he designed. Pay attention to the specific details like he was using circles wound with wire.  On page 234 of the book, figure 146 shows the way he uses the motor core with one wire and an antenna. Now that bar could in fact be a toroid like the motors on page 42. Well that isn't really a motor per say. It is a self exciting generator with prime mover (motor). The motor design is actually on page 40.
My Idea to further that along is to design high voltage coils under the field coils. This will charge the toroid and bias the current that is in the armature, which should be of a heavier gauge. The heavier gauge allows for a transformer action on the armature. This very heavy current can be picked off to power whatever you desire on the down slope of the the armature. The more current you pull the more the armature will push away from the position it was in. So it is short the armature at the beginning then unshort the armature winding and reap the benefits.
Because the motor is designed way different then the normal ac motor it reacts much different then the traditional ac motor we see today. The armature is 90 degrees out of angle already from the design on page 40. This in Tesla's own words makes it behave like there is an infinite amount of poles around the armature. The coil I believe are bifilar in design around the field core. This will give no self induction and only the resistance of the wire itself. Literally the pulses would have very little counter reaction to any impulses going through the field coils. Massive amounts of electric field would be present and I believe the magnetic field if any would be locked into the field cores. Now with a transforming heavy gauge wire or form on the armature it would be capable of generating massive currents just from the inductive capability of the electric field if the armature windings were unshorted after the attraction phase that generators normally show. Somewhere in that process is the key.
If we go one step further we can apply the Kapanadze process to make a turbo mode and increase the gain before the prime mover or motor.
If we understand the revolving field motor we understand that we can make the revolving field part go in the opposite direction of the armature (generating coils). This has a two fold effect. One it increases the generating capability per Tesla's findings and it reduces the back feeding into the field coils.
Try to imagine the magnetic field in the field coils core going left or counter clockwise and the armature of the generator going clockwise. The two add together. This is evident by Tesla's description of increasing the efficiency of low speed generators.
Somewhere in the mix we have been pushed away from the improvements that Tesla was working on which include the toroid used as the field coils and that Bessemer steel is actually oxygenated soft iron. The Bessemer process was thrown away because of this. Try checking out the process to learn more about it. Tesla reported that transformers and cores made of Bessemer steel give 2.5 times the force or efficiency then any other metal for cores.
The exciter/generator/motor on page 42 is really my aim. It also shows how to tap the generator properly via another toroid transformer.
