0 Members and 145 Guests are viewing this topic.
Bob Smith
Quote from Jbignes5:
QuoteIn my opinion this is exactly what Kapanadze is doing in the coil on coil model. Basically the internal high voltage coil is just an electric field capacitor to bias the external working current coil and get more out then the input via the inductive process.
I'm going to ask a simplistic question. According to your above quote, am I right to assume that the heart of the Kapagen (windings-wise) consists primarily of a bifilar series-wound primary and single-strand secondary?
I'm currently working on another project using pulsed DC (sq wave), and will be winding a new bifi series coil (ferrite core) for it. I can't help but think there's a connection to what Kapanadze is doing.
Any light to shed is most appreciated.
Bob
m786
Quote from: arce on April 30, 2012, 05:17:22 AM
Yes M786 i made  mustafa007 device ,  but have not obtained COP>1
Thx for replay,
I used frequency generator, then IGBT transistors, power supply is 400V direct current and really big ferrite cores.
in capacitance divider i tried capacitors from 1uF to 10 nF, but power consumption was to same.
Do you have some photos of your device? i can upload mine as well.
forest
Personally I don't know why you think so deeply instead of clearly. Is Kapanadze device so complicated ?  ???
No,I don't think so.
Ingenius in simplicity.
Digest this http://www.youtube.com/watch?v=UyqLpbg_HvY
forest
Quote from: Haan on May 01, 2012, 07:29:55 AM
forest,
have you built a working Kapanadze device?.
Not yet my friend  :D but due to other reasons you think. I am just incredible unlucky in manual works even the simplest. I remember when I was youg I could break my toys unworkable in seconds without any bad plan to do it.
Looks like it is  the opposite gift to that what Kapanadze has  ;D
btw,have you thought that your question could be not fair ?  :P
jbignes5
Quote from: Bob Smith on April 30, 2012, 09:22:29 PM
Bob
No thats my take on doing my motor/generator.
The Kapanadze method is to just put the load coil around a high voltage coil that is not connected initially to the load. The high voltage coil is then looped per Tesla's design to feed a cap and spark gap. I think at that point he feeds it to the high current coil through a step down transformer to add more voltage and amps to the load. At some point it must be enough of a discharge to convert into what the load needs to run itself. This is all because of the capacitor. If we didn't have it it wouldn't work. Also I have been looking at the book again and it seems that in order to use the process you must have a transformer of the toroid type per Tesla's design.
In the case of Thane he uses self terminated high voltage coils as capacitors to add more voltage trough induction.
