0 Members and 116 Guests are viewing this topic.
T-1000
Quote from: jbignes5 on April 30, 2012, 08:18:13 PM
Ok so take a gander at the scrib book again and read more on the motors he designed. Pay attention to the specific details like he was using circles wound with wire.  On page 234 of the book, figure 146 shows the way he uses the motor core with one wire and an antenna. Now that bar could in fact be a toroid like the motors on page 42. Well that isn't really a motor per say. It is a self exciting generator with prime mover (motor). The motor design is actually on page 40.
The http://ia600302.us.archive.org/16/items/inventionsresear00martiala/inventionsresear00martiala.pdf has full book you can read offline. It was mentioned several times over last few months and I am surprised it is being picked only now.. :)
Basically the usage of 90 degrees angle out of coil magnetic field + bifiler coil + disruptive capacitor discharge is the key to all Nicola Tesla work done. And he made very efficient motors and transformers with that.
P.S. There are more: http://nikolat.wikispaces.com/file/view/tesla-high-freq-coil.pdf
http://archive.org/search.php?query=Tesla%20AND%20mediatype%3Atexts
jbignes5
Thanks for the pdf my friend. Excellent.
My acess to the book was limited to say the least. Now it is not. Thanks again.
27Bubba
@forest
"btw,have you thought that your question could be not fair ?  :P"
Actually, I think very fair question was asked.
I previous post you posted
"Personally I don't know why you think so deeply instead of clearly. Is Kapanadze device so complicated ?  ???
No,I don't think so.
Ingenius in simplicity. "
To me at least, it implies that you actually done it, and know what you are talking about... :D
Best...
T-1000
From http://nikolat.wikispaces.com/file/view/tesla-high-freq-coil.pdf about transformer winding:
The second section is wound directly on top of the first,
starting at the same end, and being sure to wind in the same
direction.
So each layer end connects to previous layer beginning..
And now think how todays transformers are wound. They are opposite on each layer so transformers and not like N. Tesla had.
wattsup
@T-1000
Thanks a mill for those docs. They are more candy for the mind.
@ronotte
Well, I set it up and there is nothing after the 6N137. The FG goes to the 2-3 pins but nothing is happening on the other side and no pulse is getting out of the IRF840. I don't know what I may have done wrong.
I am putting up two images in case you can see something obvious.
Man oh man.
We should have an EE task force. Guys that have the equipment, know how, components and some spare time to help builders with these damn circuits. I can build coils galore and set them up, do the experiments in countless ways and means but the circuit itself is really something that should be left to the pro's. I would not mind at all paying for such circuits that I and others can think up the overall process and have implemented as this would save so much time.
There are way to many variables in making these circuits that can go wrong. To much solder heat is one of them when you do not have the expertise for fine soldering. Bad overall layout when you don't know how best to place components and the list goes on and on.
Anyways I will try to see what is going wrong.
And I had this whole rainy day to play with this if it worked. Now it will be spent backtracking.
wattsup
