0 Members and 130 Guests are viewing this topic.
T-1000
ronotte
Hi wattsup,
sorry for delay but I've been out for a small vacancy. So, I've had a look to your annotated pic and I do not
see the connection between the power mosfet's source pin and TB1-6 (common ground return). Perhaps is made under
the small board?
DEBUGGING INSTRUCTIONS:
6N137 check
1 - Disconnect TB1-1 and TB1-2 batteries
1 - Set FG output in order to have a 0 /  +5V squarewave output for example @ 100Hz
2 - Connect the FG + to TB1-3 and GND to TB1-4
3 - you must check that across the diode there are about 0.6 - 0.8V: this insures that the diode lights! Do not
go on if you are not sure diode is emitting light! If all oh switch FG to for example to an easier 10KHz.
Now let's verify that the OPTO output transistor is OK
1 - Check that a  12V is connected to TB1-2 and that the zener is correctly positioned (the band side (Cathode) must be
connected to  12V bar).
2 - Check that on 6N137 pin 8, there should be about 6V (12V - zener voltage). If that's OK than procede.
3 - Put your scope on 6N137 output pin 6 here you must find a copy of the input signal. If all OK procede
Now let's check the IRF7307 complementary driver's operation
1 - put your scope on pin 1. there you should find a 12V copy of the input. If you are OK than you have
practically finished
Power mosfet check.
1- Ensure that the FG is at 10KHz and connected to input. This is fundamental because if you leave the input
open the mosfet will stay 100% time in full conduction conditions as well as the IRF7307 that would burn out
soon!!
2- Connect  12V to TB1-1 and TB1 -2
3- If you have checked every thing OK you should find the coil switched. Pay attention as you will see huge bemf
spike reaching several hundred volts. So something must be used to protect the mosfet. Well, the mosfet itself
is protected by an internal inverse body diode but nonetheless you should consider to use an ulterior more
drastic protection. I'll show you what to do if everythingh thing is OK.
Good luck!
(please consider to call me via Skype when testing your unit)
Roberto
jbignes5
Quote from: T-1000 on May 01, 2012, 06:14:21 PM
The update about yoke device and effect:
http://www.overunity.com/4333/meyer-mace-isotopic-nmr-generator/msg320958/#msg320958
There are things to think about...
See this is exactly why Tesla and I have recommended that you use higher frequencies of the field. Slow moving frequencies of the sweeping field tends to strongly effect matter. Even your matter. The lower frequencies do this. As Tesla noted it takes 20k-40k to not effect matter. There are also some bands of the frequency that have heating and lighting effects as well. This band is in the 2-3k range per sweep of the field.
I think what it is, is you are creating at static field then modulating the field to revolve around the device. This was not part of Tesla's design and in my opinion is the whole reason for the adverse effects. Just remember that aluminum reacts to the static field just like iron reacts to the magnetic field. Although the reaction is kinda the same in both fields there is an huge charging ability of the static field when it is set into motion if there is matter in the field. But as Tesla found out the static field can be shielded but only when the shielding is not connected to anything. This is a prime law of induction of free bodies in that field. Tesla has a patent on this and describes how to shield this field from the surrounding area.
The whole reason he couldn't block the very low frequencies of this field is because they are very powerful blasts. Raising the frequencies lowers the fields ability to effect larger pieces of matter. The quicker the blasts the smaller the particles that gets effected but the more powerful the results are since there would be more very very small particles present in the environment.
Tesla's experiments provide the proof that he learned to effect such small particles of the ether that in volume it gave very high results without effecting real matter, which is grossly huge when compared to the ether particle size. You could think of this is a parts per million type of a density effect. The smaller waves can effect more of the smaller ether divisions then the larger ones. This creates a buffer like effect but inversely effects the pressure that returns from the ether.
One could think of the ether as antimatter. where matter isn't ether is. This includes internally as well and is why matter carries a body charge as well. The only difference is the size of the ether particles or units. Inside of matter they are finer and much smaller then exterior to the matter. The density is much higher in matter as well and is the reason matter can have a higher charge level as opposed to exterior of the matter.
Why we can not detect the ether particles is because we don't have a means of accurately detect such small particles. How do I know they are particles we for the simple fact that the movement of the ether is fluidic in nature. This must mean there is division of the smallest forms in our world. It is one of the fundamental rules at that scale. If there wasn't division of anything at that level or scale then nothing would flow at all. To what extent of the division it would be impossible to calculate. Maybe a fractal computation could answer that question and maybe not. I would bet a fractal simulation could result in answers we all seek of the fundamental level of density in our universe. How we control these flows can be worked out and refined but only if we concede to the fact that there are some things we are never going to be able to see with our eyes or our instruments.
These ether particles react in a much different way at the smallest scales from our perspective. They have very few rules that govern their movement in a field. These rules would have to be on par with static and fluidic laws. Magnetics is a scaling difference of mass and are added to the originating laws. Densities would be so outrageous at the smallest scales that even our best computers could not keep up with the calculations. Think of our Universe on the whole and you can see the way density can get out of control and be highly incalculable. But we have changed our perspective going to the scale of our Universe but it should be the same as we change our perspective to the smallest places as well.
As our capabilities change we will be able to see smaller views of matter and whats in between matter at those scales but there will always be something smaller that we can not see. This is due to the fractalness of nature. One thing that might help is to use fractal laws when going to smaller scales. These can be based on much larger scales and inferred backwards but with certain mass effects filtering the results. We have to concede that there is still a density at the smallest scales. If there wasn't everything would be one body and nothing would exhibit division on the largest scales. Division is fractal in nature so it must be included in our attempts to peer into the smallest areas as well.
Now after we admit that density and flows are the root of the laws, we must understand that there are ways to effect movement and control of those divisions, even at the smallest of scales. Understanding how we can control the flow is the key to having totally free energy or access to the massive energy stores and flows that are present all around us.
Just like in our steam engines we must understand the controlling material we use. We shape it to pressurize and extract energy from the expansion of the water from solid to etheric or steam. On the smallest scales this would entail waves instead of matter. 4 interposing waves would cause a compression of the ether on a plane. 6 would be a crystal or double pyramid type of compression wave. This needs to be 3d and not the usual 2d we think of in waves. We must start thinking in terms of surfaces of the waves and not the planes. etheric waves are 3d surface based and usually take thew form of the sphere on the most basic level. Added together in a density the expanding bubbles of waves can create compression in the ether. In most cases we have been working in a 2d mode and this will never work.
The atom as well as the planet are very very important proofs of what this anti matter(ether) is and what shape it takes even on the fundamental level. These two extremes are fine examples of those proofs. It is the fractal that makes this a proof. Anti mater has no energy at all. it is neutral and will not detonate upon contact with matter. That is because anti matter is passive and could never touch matter. At those scales force doesn't and will never allow contact. Antimatter must be neutral and only reflects the charge of matter either directly of passively. Direct reflection is dependent entirely on whats on the other side of the point of reflection in the ether. There will always be something on the other side even if it is 2 billion spaces or units of ether away. Distance really doesn't effect the ether because it is lossless. But there will always be two points to reference with the ether. Increase the density of matter and it increases the distance at which it can effect it's neighbors through the ether. Change the shape of the matter and we can influence the shape of it's field in the ether. Resonante the shape to the field of the ether and we can import million upon billions of units of energy from extreme distances because we match the surface interface of the ether. This could give credence to why some matter is strongly motivated to do work when certain fields are applied to the matter. Like iron does with magnetics. The spaces in between matter become conditioned to work best with those fields. Work being channeling ability and control of the field through matter. How that happens must be related to the control aspect of the magentic field through it's body. Instead of letting the magnetic field dissipate it confines and can even concentrate the fields into a density that equals the space in between matter. This explains irons ability to increase the magnetic force. This has to be because of the interaction of the electric force to the magnetic force. and we all know that bodies of iron have an electric value.
This is come to me with my work in batteries and the new type of solid state battery that we are trying to make in another thread. Circular batteries seem to have the best output. This is because we present a more neutral conductor outside of a highly charged or higher voltage inner conductor. As in static this creates a space that the high conductor gets reflected back inwards multiplying it's value due to concentrating forces. We don't allow the radiated force to leave and force it back into itself. Induction must be the fundamental link that allows charges to exist in the first place. If this wasn't true all charges would instantly dissipate into the background or environment.
If we look at the oil dielectric issue this would tend to prove that there is a certain amount of separation between matter and energy as well. But take that oil and expose it to a static field and it will move all by itself. The dielectric will jump away and move. This works with most matter on our scale. But when we work with electrical stimulation it perfectly divides two masses to allow for a greater buildup of the two divisions of that matter. This was proven by Tesla on more then one occasion. It is a key aspect of miniaturization of the coils he used. Because the oil is a fluid it is free to move and self heal when breaks happen in the dielectric. This is because there is nothing to contain the oil or hold it in one place. It is free to move and self heal the break within it's mass.  Another very important empirically experimented fact.
Now back to shielding or better yet statically shielding the component we want to keep energized. We need to field to stay where we want it and in some cases concentrate or pressurize. Where static shielding isn't used we want the field to release or depressurize and interact with the free moving environmental field. In one experiment Tesla shows the effect of using geometrical differences in two terminals of the same mass but different surface area. The smaller of the two surface area wise creates a difference in the intensity of the field we allow to exit the system. This can change the charge level between two elements of the environmental interaction zone. I like to call them antennas for short. If we interpose a not connected special pancake bifilar coil it would allow the passage of the concentrating beam, if you will let me call it that, and raise the intensity of the coil without interacting with the beam as much. This would allow us to collect a higher charge level on the bifilar coil and charge a cap that we can now dump explosively into another load.
Listen I know I put up walls of text but if we don't start thinking about this then we are just going in circles. We have been taught the way they want us to think and to tell you the truth it is a false teaching. Yes it works but only with the system they designed. This system is riddled with losses any which way you move in that system. If that was a mirror to the natural system the natural system would grind to a halt. In fact supernovas would not exist or even black holes. Heck our sun would not exist if it was based off of what they are trying to sell to us as the true physics of nature.
Every day the astronomers astound themselves by what they are seeing. Not in their wildest imaginations did they think it was possible at some of the stuff they are seeing. This is a grave error we are making because we obviously don't fathom the true nature of nature itself yet we still teach it the old ways. This is the same issue that keeps Tesla buried in obscurity. We allow this to happen because we feel we can never be right but yet others have done the impossible. Tesla proved experimentally of some of these truths which still are denied to this day.
When are we gonna wake up and see the real events happening and change our teachings to match what we see? When will we hold these robbers responsible for the lies and outright false teachings they teach our children or even us? When our we gonna open our eyes to new thoughts of the ether and how we can use this to our advantage. Everyone could be a millionaire and that doesn't fit with the dog eat dog world they have created for us. It wouldn't be about survival then it would be about expanding our consciousness and caring for every living being in the Universe. Our self importance is killing us. Everyday we expose ourselves to their world and it is mutating us in ever aspect of our lives. Why can't we treat them like the cancer they are and cut them out of our world. It isn't their world it is all of ours and we consume it like it was the fruit of the gods. We are killing ourselves for no good reason. Is money that important to us or is it the quest for the unknown. The realization that my brother is your cousin doesn't matter anymore. If we look back into time we are all related no matter what our race or creed is. We all treat our families with disregard and selfishness. We are unwilling to share our thoughts freely because most think about what it is worth. We don't discover things because they are interesting and educational anymore. We discover things for it's worth to others. Since free energy has zero worth to them we are left with or abandon the search because there is no value to them. To us it would mean pure freedom. To them it means lack of control over the money making machine they created. It's time we shut them down and let them go bankrupt. It's the only way. Once the cancer dies then we can recreate this world and live in harmony with our environment and each other.
I long for the day that I can walk down the street and know I won't be struggling to find my family the food they need to eat that night. I long for the day that we can get the medical treatments that are not about paying 250,000 dollars to make me healthy again. They are the real cancer and it is spreading like wildfire. They are killing our humanity and our search for the truth.
*Soapbox off*
wattsup
@ronotte
First last night the 840 mosfet was on backwards (sh&t). So I changed the mosfet and put it on the right way, but still nothing.
Tonight I will do the tests you kindly and thoroughly suggested and I will see what's happening with this.
Thanks again.
forest
Don't worry wattsup. My IRF520 exploded over my face, fortunately my eyes were not affected. From thos two I like your not working circuit more  ;D
