0 Members and 130 Guests are viewing this topic.
jbignes5
 I found another tid bit again about Tesla and the parameters he was formulating for a highly efficient motivator. Lets see what he says.
In a patent which appeared in April 1905, the application of which was filed on May 15, 1900, I have enunciated the law of propagation, which I have explained, and have stated that the frequencies should not be more than 30,000 or 35,000 cycles at most, in order to operate economically.[/size]
[/size]
Even with a resonant connection if he went over 35k cycles it became work again. And below 30k cycles you get a lessening of the amplification. It built up over time and growth was slow. But the initial reaction is very quick in it's growth cycle. Near instant transitions are made in this density of the field. If you built such a machine one would have to have a magnetic quenching of the spark gap. You would want the cleanest clipping of the power. The filed would be very static like in it's excitement of the mater around it. Tesla also said it increased his well being and stamina and could work for days in the machines field..[/size]
[/size]
If the intensity was too much it would set coils and other metallic objects with a fire like emission in the near field. the field looking like a cells nucleus and a lighter field surrounding that is my guess. These emissions would work like fluid flowing over the forms shape. So we could use this like a steam type of force. We should be able to enter the near field and work on a field compression process that might be able to harness the near field very efficiently as a base of gross power generation. with the external field being the connective portion. Small devices would work wirelessly if designed right in the external field. think about the possibilities. We could start making ships that have these power systems designed in the core of the ship. It could work like gravity as well if the design was proper and the flow was going twords the center node. Hmm too many ideas...
Tesla did a lot of work in the fluid area to understand how to shape fluids to do work. He made great strides in pressurizing fluids with matter that didn't deal with real valves. He designed a turbine as well to extract energy from fluids.
jbignes5
 I now know Tesla's secret. He was modulating the worlds energy field. This modulation of the field had two states. One energized and the other non energized. The lowest of the two being the ground state. Once the field is very intense you can get any amount of energy out of that system. He was using the inertia of the worlds electrical field. Usually this field is very low or in the ground state. It can be excited to very intense sweeps of the worlds magnetosphere. With sufficient intensity you can effect that electric field or modulate it from ground state to high energy state. The translation of power has to be based on the volume of our whole magnetosphere. This would be a world wide energy system. Pure genius. The longitude waves that transverse back out from the center of our world in this system would energize instantly anything in their path tuned to receive that movement. Most objects wouldn't even know there is any difference other then the network making them last longer due to the growing intensity of this new system. More flow in the base system that our planet uses currently would only reinforce the ability to stay together with the increased movement of the longitudinal modulation.
Hence the energizing feeling of well being. This also opens up the protective ability of a spherical field. We could learn to take the modulation and slow it down or in fact speed it up and use that to create protective barriers based on the frequency of the two states. Remember matter will react differently at different cycles. Once an object has been scanned all we would need to do is modulate the field to respond with the matters resonant frequency and blammo, either destroyed or even repelled from the surface of the energy field. This also opens up flying vehicles by passive means. Coils tuned to the longitudinal waves could ride them like pogo sticks and extract sufficient power to run any type of device all at once. Remember longitudinal waves are radiant in nature. Just like the picture I showed.
Remember also that we are speeding through this universe. We are moving faster then you would believe.
stivep
Quote from: jbignes5 on May 02, 2012, 09:36:14 AM
See this is exactly why Tesla and I have recommended that you use higher frequencies of the field. Slow moving frequencies of the sweeping field tends to strongly effect matter. Even your matter. The lower frequencies do this. As Tesla noted it takes 20k-40k to not effect matter. There are also some bands of the frequency that have heating and lighting effects as well. This band is in the 2-3k range per sweep of the field.
I think what it is, is you are creating at static field then modulating the field to revolve around the device. This was not part of Tesla's design and in my opinion is the whole reason for the adverse effects. Just remember that aluminum reacts to the static field just like iron reacts to the magnetic field. Although the reaction is kinda the same in both fields there is an huge charging ability of the static field when it is set into motion if there is matter in the field. But as Tesla found out the static field can be shielded but only when the shielding is not connected to anything. This is a prime law of induction of free bodies in that field. Tesla has a patent on this and describes how to shield this field from the surrounding area.
The whole reason he couldn't block the very low frequencies of this field is because they are very powerful blasts. Raising the frequencies lowers the fields ability to effect larger pieces of matter. The quicker the blasts the smaller the particles that gets effected but the more powerful the results are since there would be more very very small particles present in the environment.
Tesla's experiments provide the proof that he learned to effect such small particles of the ether that in volume it gave very high results without effecting real matter, which is grossly huge when compared to the ether particle size. You could think of this is a parts per million type of a density effect. The smaller waves can effect more of the smaller ether divisions then the larger ones. This creates a buffer like effect but inversely effects the pressure that returns from the ether.
QuoteT1000
  The update about yoke device and effect:http://www.overunity.com/4333/meyer-mace-isotopic-nmr-generator/msg320958/#msg320958There are things to think about...
Thank you both of you.
Please look at that video but only from
31:25 to 32:27
one free electron+ atom/ion is pair that travels.( heavy  particle= hammering effect)
Correlate this with T1000 info.
PROPER SWITCHING GIVES YOU DESIRED EFFECT.
http://www.youtube.com/watch?v=HKVyeQkW8j0
Wesley
jbignes5
I agree Stevep. It's all in the timing. You want to do it to the resonant frequency of the material. Copper being a heavy displacement current. Aluminum a high voltage + heating element types of conversion. The metal itself excites to a very high level. Learning on how you extract that energy is another story. You would be best checking out Tesla's hairpin circuit. It is the same thing really. Knowing where to tap the nodes is the trick. Figure out that experiment and move the nodes on command with purpose and you have the best oscillator ever. A pure solid state transistor capable of maintaining huge amounts of current. I't also a better kind of energy. It likes to stay in the conductor.
If you don't want spurious emissions from the static field then shield(statically) it a distance away from the buss bar (element).
stivep
Preamble:
This work is dedicated as Thank you to
wattsup
zerofosil fuel
jbignes5
27Bubba
forest
ronotte
semenihin-77
AbbaRue
e2matrix
electro1574
T-1000
Aidas
and others
Try to "disturb" say transmutate structure of a nuclei - Neutron and you have nuclear bomb
So what is neutron? =subatomic particle=component of  nuclei excluding hydrogen.= has no charge.
subatomic particle
Any of various units of matter below the size of an atom, including the elementary particles and hadrons.
neutron
An elementary particle
without an electrical charge ; one of  the building blocks of the nucleus of the atom
A neutron has about the same mass as a proton
An electrically neutral subatomic particle in the baryon family, having a mass of 1.674 × 10
-24 grams (1,838 times  that of the electron and slightly greater than that of the proton).Neutrons are part of the nucleus of all atoms,except hydrogen, and have a mean lifetime of approximately 1.0×10  seconds as free particles. They consist of a triplet of quarks,including two down quarks and one up quark,bound together by gluons. In radioactive atoms,excess neutrons are converted to protons by beta decay. Beams of neutrons from nuclear reactors are used to bombard the atoms of various elements to produce fission and other nuclear reactions and to determine the atomic arrangements in molecules.
An electrically neutral subatomic particle in the baryon family, having a mass 1,839 times that of the electron, stable when bound in an atomic nucleus, and having a mean lifetime of approximately 1.0×10
3  seconds as a free particle It and the proton form nearly the entire mass of atomic nuclei.
neutral elementary particle with  a rest mass of 1.674 92716 × 10 --27 kilogram and  spin½; classified as a baryon. In the nucleus of an atom it is stable, but when free it decays
neutron
1921, coined by W.D. Harkins of Chicago from neutr(al) + -on, as in electron. First record of neutron bomb is from 1960.
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/7090/imode/
http://www.rexresearch.com/meyernmr/meyer.htm
Please analyze the 3 videos
Lakhovsky Multiple Wave Oscillator original device
http://www.youtube.com/watch?v=jT1XCd5Gndw&feature=autoplay&list=ULrRttn7xb0y8&playnext=1
http://www.youtube.com/watch?v=LAueb8yFT5U&feature=channel&list=UL
http://www.youtube.com/watch?v=rRttn7xb0y8&feature=channel&list=UL
We are dealing with earth interaction here.
Wiggler and Undulator Magnets
http://www.askmar.com/Magnets/Synchrotron%20Radiation%20Wiggler%20and%20Undulator%20Magnets.pdf
Wesley
PS:
something for you to think about it
It is in front of your eyes
FE in form of NMR
should anybody give doubt?
There  are many ways to Rome
Tesla way
TK way
NMR way
NYW group way
Your Way :)
If : 200 kelvins is equivalent to -99.7 degrees fahrenheit
77 kelvins is equivalent to -321 degrees fahrenheit
and
4 kelvins is equivalent to -452 degrees fahrenheit
and
no significant change to transmutation  is observed
than
Room temperature is sufficient for NMR transmutation and energy extraction
Period!!!
Watch this:
NMR in room temperature using Earth magnetic field.
No Cryogenic!!
http://www.youtube.com/watch?v=7aRKAXD4dAg all 11 Videos in easy language
or this by Wesley:
http://www.youtube.com/watch?v=F2BED9aDEYw
and this:
http://www.aetherometry.com/Labofex_Plasma_Physics/Archive/CorreasUSPAbstracts.html
http://www.aetherometry.com/Labofex_Plasma_Physics/aspden_opinion.php
http://patft.uspto.gov/netacgi/nph-Parser?Sect2=PTO1&Sect2=HITOFF&p=1&u=%2Fnetahtml%%2FPTO%%2Fsearch-bool.html&r=1&f=G&l=50&d=PALL&RefSrch=yes&Query=PN%2F4291255
additional material TESLA book:
http://nikolat.wikispaces.com/file/view/tesla-high-freq-coil.pdf
http://jnaudin.free.fr/html/mmcgen.htm
http://freenrg.info/TESLA/Tesla_Switch/D3.pdf page 44,45,46
http://jnaudin.free.fr/html/paraform.htm
http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296310
http://www.dtic.mil/cgi-bin/GetTRDoc?Location=U2&doc=GetTRDoc.pdf&AD=AD0296308
Abbarue:For Iron Fe57 the NMR at 2.3488T is 3.231Mhz    (H1 100Mhz)To get the NMR frequency for other T you just divide.  So for 0.5T the NMR would be 3.231/(2.3488/.5)= 3.21231/4.6976 = 0.68383395 Mhz or 683.83395 khz. Because the NMR frequency drops proportional to the  !important]magnetic field strength, different parts of !important]the iron will be exposed to different magnetic field strengths.  So as long as the frequency is close, a part of the iron should be exposed to just the right frequency for the amount of magnetic flux.  The trick is to get as much of the iron exposed to just the right magnetic field strength needed.  Maybe that is the reason for using an electromagnet instead of a PM.  The coil spreads the field out across a larger surface area.  Also increasing the current will increase field strength for tuning. Maybe use 2 doughnut shaped magnetron  !important]magnets with a spiral coil pinned between them, and then find the right NMR for their magnetic field strength. But that would mean tuning the frequency, so a crystal signal wouldn't work. Unless you had a fine adjustment to move the magnets back and forth for tuning. All in all the device may work when properly tuned, but not keep working for extended time because of getting out of adjustment to easily.
e2matrix
A rough interprestation of the French patent.  I'll try to clean it up a bit later as this was an OCR of an image of the text which was then translated with Google (and if you know how OCR works on images of text you know it doesn't always get things right - in this case I think some numbers got put in places where it failed to recognize text correctly):EDIT: Cleaned up as much as I can:Text from Cover page in patent: (54 - I think this #54 is an irrelevant number not talking about isotope - just a reference number) Activator for isotopic mutation.(57 - irrelevant number) Power generator by nuclear resonant ferromagnetism consisting of a frame-shaped "U" mild steel containing a cylindrical bar of ferromagnetic fuel acted upon by at least 3 induction coils. The first is an electromagnet coil, the second activator is a nuclear magnetic resonance, the third induction recovering energy !important present in the bar.Device specifically designed to provide a commercially viable electric power and to make changes of isotopes.FR2680613page - 1 - DESCRIPTIONThe present invention relates to a device for generating energy by nuclear resonant ferromagnetism.Nuclear power is traditionally produced by fission or 'fusing atoms while the magneticfluxes are in turn traditionally obtained by induction caused by the movement of electrons.The present invention uses a physical phenomenon that we have identified and we will call "Isotopic Mutation".Description of the physical principle applied to the iron isotope 56:The iron isotope 56 contains 26 protons, 26 electrons and 30 neutrons,its total mass is 56.52 MeV, its actual weight being 55.80 MeV. The difference between the total mass and the actual mass is 0.72 MeV which corresponds to a cohesive energy per nucleon of 0.012857 Mev.If additional energy is introduced of 105 eV iron core isotope 56, that will have an energy level of cohesion per nucleon of 0.012962 corresponding to the iron isotope Mev 54. The instability created by this energy input is a specific radioactivity that will transfer the isotope 56 iron isotope 54 with a release of 2 neutrons which transform in 9 minutes in Hydrogen by natural radioactivity.This process will generate a gain of energy of 20,000 ev since the default mass of iron resulting 54 is only 0.70 MeV instead of 0.72 MeV for iron isotope 56.To make the iron core isotope 56 energy required to effect the isotopic mutation, we use the principle of reso-nance nuclear magnetic.The 26 protons in the iron isotope 56 are at the origin of magnetic moment that nuclear gyroscopic motion moved by a dependent of the actual mass of the iron core. The loss of mass caused by the phenomenon of mutation will alter the isotopic gyroscopic moment and the energy return of by increasing the rotation speed.   The physical phenomenon of isotopic mutation described above is applicable to all of Mandeleiev body of the table.page -2The device of the invention is shown schematically in Figure 1 attached. It consists of a metal piece of mild steel (1) in the form of "U" and a cylindrical bar (2) iron isotope 56 !important]supporting the different-5 annuities coils (3,4 and 5).    The first coil (3) is a magnetic field generator  A power of 0.5 Tesla to the orientation of the nuclear spins of the iron atoms 56. -        The second coil (4) is traversed by a sine wave of 21 MHz frequency of 10 to the -4 Tesla power which is an activator of Nuclear Magnetic Resonance observer permitting rotation of 180 ° of the nuclear spins of the iron atoms. -       The third coil (5) constitutes a transformer primary, which collects the induction energy present in all points of the bar created  by changing the isotope of iron atoms in iron 56 54. The recovered energy can then be transformed in a form commercially exploitable (110-220-380 voltage V and frequency 50 to 400 Hz). The basic !important]application that results is the creation of autonomous electrical generator. The particularity of this new generator is that it uses a bar ferromagnetic metal as fuel giving it considerable autonomy and a very low cost of ownership. This electrical or magnetic energy can also be used in all systems such as inverters, motors and engines. The second application is the resulting transformation of isotope using the same principle described in figure 1 as with magnetic core (2) to transform the metal and adjusting the setting values of the various components to match the mutation achieve.2680613 page 3 - CLAIM 1) flow generating device magneto-nuclear characterized in that it comprises a metal frame in the form of "U" (1), a ferromagnetic metal bar (2) representing the magnetic core of the induction coils (3,4 and 5). 2) Device according to claim N ° 1, characterized in that the first coil (3) is an electromagnet, the second coil (4) is an activator for the sine wave nuclear magnetic resonance of the magnetic core and the third coil (5) is the transducing element of internal flows of nuclear origin which recovers energy in all points of the bar (2). 3)        Device according to claim # 2 characterized in that internal flows of nuclear origin allow to obtain a magnetic or electrical energy commercially exploitable. 4)        Device according to claim 1 and N ° 2 characterized in that the change of the adjustment parameters of the coils and the magnetic core thereof would enable the system to make changes to other isotopes of elements Table of Mandeleiev.
