0 Members and 51 Guests are viewing this topic.
jbignes5
 Again I have to agree with stevep on this. This is a forum built on the idea that free energy does exist. How we attach our generator is very important to the resonant feedback to that tap. Resonantly shaped coils could cause a harvest able ringing in the steam that flows through it. I don't think we need to do anything but initiate the stream tap and allow a flow from the ripples we tailor by the coils in the stream.
A good way to tap the stream is via Bifilar coils.
I remember a video of the electric side of the magnetic field. They intensified the voltage component around two magnets either in attraction mode or repulsion mode and charged the field from an electrode with a ground plate inside of a vacuum bell jar. You could see the magnetic field flowing in the valleys of the electric field.
I'll see if I can pull it up again.
http://www.youtube.com/watch?v=TxNYO_2FMpI&feature=results_main&playnext=1&list=PL42F201860665F11A
Heyyyy look at what I found!
http://www.youtube.com/watch?v=JjSOAOFqBio&feature=relmfu
It has an excellent view of the double toroid coils within the outer drive ring coil. If you wait till the end of the clip you will see a nice shot of the two toroids within the larger coil. The outer coil looks to be wound with very light gauge. With the inner coils wound with heavier gauge wire. Also if you look really close you can see bar magnets in the smaller inner coils. The earlier small toroid that he showed he had to activate. This was the magnet he added to bias the unit on.
He talks about two frequencies. Those frequencies are produced by the inner coils. It has to be. So the TPU that everyone is working on does not conform to this video. I suspect the outer coil is the driver and is the one Tesla designed. This is a high voltage setup with two converter toroids in the center. This is to lower the voltage and increase the current and is of a fluctuating dc current. Hence the two toroids in the middle. If you put that fluctuating current into a transformer you would get ac output.
Somehow I have never seen this video before today and is a very clear explanation of the process even without him explaining it. In order to turn off the system it seems the magnet must be removed and flipping of the coil over stops the flow. of the smaller coil. The larger coil seems to stop if you disconnect the inner coils from the transformer.
Another interesting concept with reference to where it originated from:
http://www.youtube.com/watch?v=iJsVSMQqCOM&feature=endscreen&NR=1
Another tid bit:
http://www.youtube.com/watch?v=2kOQr7hZA70&feature=related
Some non related video's for your enjoyment. http://www.youtube.com/watch?v=3yUqb0wrxRw&feature=related
What if we could correct the wobble? Think of the pyramids shape and what it is grounded to.
Acca
 Wesley:
here is a ref. to a nuclear event that can be done at home... that is very dangerous to do.. That is why the "yoke" experiment
has to have some careful looking at.. The effects may not be apparent until it's too late..  The "ferrite" material just like "Terfenol-D"
will cause intense shock waves to manifest and impinge in nearby materials when modulated with a right Very Fast switching pulse,
like this example below...  "Terfenol-D" is a unique magnetostrictive metal that is used in sonar generators and it was secret..
Al...
https://nanospireinc.com/
Mark LeClair and Serge Lebid discovered that the scaled-up "LeClair Effect" reactor was triggering intense fusion, fission using ordinary water. The 1.25” ID by 12” long reactor produced 2.9 kW of hot water using only 840 watts of input, a coefficient of performance (COP) of 3.4 times more energy out than in. The water temperature was raised an average of 18 degrees C (32 degrees F) average passing through the reactor with 28 degree C (50 degrees F) temperature spikes observed. A total of twelve experiments were performed, with 100% repeatability of the high levels seen in excess heat and transmutation in the various configurations.
The experiment also accidentally resulted in acute radiation sickness beginning the day after the August 25, 2009 experiments for both investigators Mark LeClair and Sergio Lebid and lasted for more than a year.[/font]
"There are a few differences that are quite interesting in terms of the signature on the transmutation data. But the result is pretty clear that it produced abundant radiation. It actually ended up activating the PVC enclosure in one of the experiments and two and a half hours after the experiment it was so radioactive that it would have been lethal if you had been exposed to it for 40 hours. I actually captured a decay curve following the half-life of radioactive chlorine that was inside the PVC so it was obvious there had been heavy neutron, deuteron, and alpha particle absorption into the 35 and 37 CL in the plastic. And that was transmuted into 39 CL and you could see the 56 minute half-life. It produced a very strong neutron flux based on that result. Gamma ray production was not that significant. It was only 20 to 50 percent above background during the experiment. So we have seen a lot of other interesting results due to the particles that were produced inside of the experiments. Transmuted materials placed in clear polystyrene dishes. Polystyrene acts just like Cr-39. It allows you to see nuclear tracts. I think it is a better material than CL 39. You could see spiraling electron tracts, spiraling alpha particles, stars where nucleuses were disintegrating, you could see gamma branching of electron-positron pairs. "
Mp3. interview about this discovery by Sterling Allen from last week.. form Peswiki.com [/font]
http://m.podshow.com/media/1049/episodes/314012/pesn-314012-04-26-2012.mp3
http://pesn.com/2012/04/28/9602083_NanoSpire_Inc_on_Harnessing_Cavitation_Zero_Point_Energy_to_Produce_Fusion_and_Transmutation_in_Water/NanoSpire_Fusion_Energy_Executive_Summary.pdf
energia9
kapanadze is not Radioactive approach,
look at depalma machine,  it is the mechanical version of Kapanadze machine.
Every mechanical version has a non moving transformer version,
think how depalmas generator could be done as a transformer.
kapanadze made a mechanical device first, that mechanical device works on the same physics as the non moving one,  it is just the way it is arranged differently
Not radioactive, clean and safe, No NMR
bye
jbignes5
 I have to agree that NMR is not the approach. The radioactive approach is a dangerous one. This concept can leave pollution in material that would be seen as radioactive. We want radially active emissions which is wholly different. Think of a doughnut, now think of inflating and deflating that doughnut. That is the action that Tesla used. Tesla had a great explanation of the process. Instead of a doughnut he used the ball approach. Inflating the ball and modulating the balls size from maximum to minimum was all he needed to do.
The concept dealt with the solid to field area. He charged the solid and it emitted a field all the way around itself. The movement was from surface to atmosphere. Since our planet already has a network of radial lines it was easy to increase the intensity of that field all the way around it. This could be done on any scale. With the smaller scales effecting smaller areas. The smaller scales would create a bulb like protrusion to the already established field around our planet. The sharper the pulses the more current you can tap. It is not essentially the timing(resonance) that is very important. It is the quality of the break that matters more. Tesla showed that if you polarize the gap the breaks get very clean. The cleaner the breaks the more push you will have... The steeper the breaks, the distance in between background to excitation max, the more power this thing can shuttle. The higher the density of this field via voltage level measurements the higher it's ability to push back with great force. When dealing with a new form of electrical energy, you need to find out it's abilities. I think I have seen videos of the hair pin and the energy is very strange. Only the target filament is targeted and will bypass everything even dropping it in water. The next experiment is that he reached into the water and picked up the bulb and played with the bulb under the water with no harm of sensation.
This kinda energy is a new form and method of use. It is used in a more natural way. But I'm telling you if we go down this road there must be agreements made that it should never be used for war. We need a protection only stance here or else we are giving them the power to take anything they want. Shielding would be a natural event of this generator field. All one needed to do was change the harmonics to the field of an approaching object. instantly the field matches that frequency on contact and blaamo at the skin barrier. This change of the field would be done by specific tuning stations. So it will not effect the people inside or objects inside. These filtering stations would be like how a vehicle can fly. Tuning coil will harness the field lines and squeeze them to allow a pressure to build up in one direction or even twords the earth field. This is done by aperture like focusing of the stream. You will be able to change the movement by modifying the x,y and z axis of the coil. Shorting and unshorting the coils will allow for the field to be locked on and compressed or uncompressed the field lines. Take one of those long thin balloons and blow it up. Watch how it grows. Since the field is high density it becomes capable of some pretty good current movement capability. The whole network becomes better. Everything works better and performs better and that includes the Humans. Increasing the density lets you see everything in crystal clarity. Everything will work flawlessly. Hopefully it also will allow us to become more wise and just in our application of law on our Humanity. I guess my thoughts on that is better off not said atm but at one time we must discuss what is fair for all. I can see all kinds of good things we are trying to do with the limited energy we command. Having an ultimate source of energy must be completely thought out. We must build in safeties and make sure it doesn't get out of control. We must control it with the human in the equation. We are soo capable of great wisdom and history does have some good marks mixed in with the bad.
jbignes5
If we start to incorporate geometry in our designs we will find it much easier to convert this new power. The one clue I can find is the star of david.  This is a diagram of a 2d representation of the ultimate conductor. It is bidirectional conductor. I say 2d because if you twist the view of the particle it will have either a 3 sided pyramid or a 4 sided pyramids infused into one particle. Accessing this energy is only available via the angles provided by this picture:
[size=78%]http://upload.wikimedia.org/wikipedia/commons/9/9d/Leningrad_Codex_Carpet_page_e.jpg[/size]
