0 Members and 100 Guests are viewing this topic.
pix
Ganzha
Wesley!
Could you please publisch schematic of this experiment, this is not quite clear - why you so glad to watch light from your bulb?
http://youtu.be/Mn8TLBsR3r0
pix
Quote from: Haan on May 05, 2012, 11:29:27 PM
pix,
what is  NMR?
Nuclear Magnetic Resonance- this time from iron.If you keep a piece of Fe in the constant magnetic field, and then "tickle" it with
proper frequency- iron atoms suppose to perform isotopic chanhe-drop to lower energy isotope relasing excess energy.See for Meyer-Mace experiment, there is also czech patent around.
I don't say this wouldn't work, but I don't realy see this stuff relevant to Kapanadze or TPU.
That is my 5 cents.
Regards,
pix
energia9
Hello again.
i would like to tell something,  a bifiliar coil is not so special as you may think it is... nor paralell bifiliar nor series.
it has no special anomaly that comes with the configuration,
please understand, it has parasitic capacitance .    it is true that a bifiliar coil has 500 times more parasitic capacitance then ordinary coil, but it can simply be explained by the two wires that run paralell.
and you could do the same thing with an ordinary coil and a capacitor..
today bifiliar coil has no use commercially
it is not special at all.
if for some reason kapanadze used this kind of wire configuration (works same as ordinary)  it might be for complicating and make it more difficult to reproduce.
understanding this you will understand that the device uses and works on the simplest configuration as well.
and the reason Tariel used so many coil configurations in different videos, because all coil configurations work, and this is the way to confuse the person who watches the videos or to see the device in live, this will make you think that the coil configuration is the key,  and in fact Its Not.   Its how you drive this coil and what methods you use for utilization.
It is the electronics circuits that are more important.
without his magic circuit it is a hard job to reveal the secret,   and all of you who play with coils and not electronics will more likely not suceed.
i hope this clarifies some issues.
sadang
energia9, maybe it is time to rethink you statements about bifilar coils, because these king of coils, like the others (caduceus coils) ones, have a special voltage gain, and Tesla used this kind of coils, under different geometrical shapes, cause he knew very well what he did! It's all about potential not current! Maybe this link will make light about the special characteristics of this kind of coil:
- 1996 - Oliver Nichelson - A Special Case of Voltage Gain
