0 Members and 1876 Guests are viewing this topic.
energia9
even if Voltage gain is present, it is not free energy. it is caused by the charges that is stored between the two wires,  because bifiliar has parasitic capacitance it stores energy like a capacitor.  very simple,
do an experiment you will see.
i have done mine.
there is nothing special, no mysterious energy from bifiliar.
jbignes5
Quote from: energia9 on May 06, 2012, 05:32:58 AM
Hello again.
i would like to tell something,  a bifiliar coil is not so special as you may think it is... nor paralell bifiliar nor series.
it has no special anomaly that comes with the configuration,
please understand, it has parasitic capacitance .    it is true that a bifiliar coil has 500 times more parasitic capacitance then ordinary coil, but it can simply be explained by the two wires that run paralell.
and you could do the same thing with an ordinary coil and a capacitor..
today bifiliar coil has no use commercially
it is not special at all.
if for some reason kapanadze used this kind of wire configuration (works same as ordinary)  it might be for complicating and make it more difficult to reproduce.
understanding this you will understand that the device uses and works on the simplest configuration as well.
and the reason Tariel used so many coil configurations in different videos, because all coil configurations work, and this is the way to confuse the person who watches the videos or to see the device in live, this will make you think that the coil configuration is the key,  and in fact Its Not.   Its how you drive this coil and what methods you use for utilization.
It is the electronics circuits that are more important.
without his magic circuit it is a hard job to reveal the secret,   and all of you who play with coils and not electronics will more likely not suceed.
i hope this clarifies some issues.
I'm sorry, I could not disagree with you any more. What you say is ludicrous. Any time you can take out a capacitor and replace it with the very coil you are trying to induce a voltage in reduces the resistance and increases the reaction. Coils are the way to access this phenomena. The capacitance of the coil is key to maintaining a static field. Once you have established the field if you modulate the field with additional coil you can effect the fields shape and texture. It has already been established that a vortex holds power beyond our expectations because of this relationship between induction and capacitance. Having to add a capacitor only further reduces the energy that can be held or manipulated. Also the bifilar coil seems to be able to take an oscillating field and convert it to a one way pressure with the added effect of boosting the fields strength and range. This is because of the one way nature of the bifilar coil.
As others have sdaid if you can gain extra voltage from the coil with the same input are you not increasing the output once it is converted back down? Again my shoddy math but this might help. 12 volts*10 amps input=120 watts with a regular coil. Now with the same voltage and current applied to the other coil would be something like this: 1200 volts*.3-4 amps=360-480 watts. There is a big difference. I'm not saying those are real numbers but if you go wind for wind the bifilar will always output more. This is because each opposing wind acts like an accelerator. It creates a vacuum like effect attracting the previous wind. The bifilar cancels self induction between winds and hence reduces the choking effect that most coild exhibit. With an added capacitance growing between each wind this increases the voltage component in fold like ways: example 10 fold.
Lets say we create a river' it has well defined borders including a beginning and end. Now we stick the river on a plane that oscillates up and down like a teeter totter. If we used general valves on each end to allow the buildup of potential energy we can only harness one way of that flow that happens in the river. But if we used a special valve that allowed the use of both flows you would get twice the movement or flow. With a regular valve you only get one side of the flow. Half the efficiency.
Bifilar coils have no self induction and no resistance other then the wires resistance. In fact it actually speeds up the energy flowing inside of it via induction to the external field. It's like a sponge in that respect taking all of the field and converting it for use as a constant current. Consider it being a valve. We can sputter that valve as well. We can redirect the energy very easily via a ground plane. These devices are passive taps to the back ground energy field. We are changing the density on and off from very highly charged back to the background energy fields level. The field is already present and highly mobile. We are just borrowing the lines and raising the density per cubic inch or centimeter if you will. It is the same process that we are using to form magnets. It isn't the field but the density of the captured field in the matter that we are looking for in the creation of strong magnets.
http://oersted.com/magnetizing.PDF
The funny thing is I never went looking for capacitor discharge but yet it is the most powerful way to magnetize magnets. Hmm curious isn't it?
Also they talk about bipolar capacitors and how they free up the movement both ways. Oil filled caps are used for that. So everyone using polarized caps will not see the oscillations that Tesla saw! After all they are polarized. We don't want to use polarized caps in our design because we want the back and forth oscillation we get from a bifilar coil and cap. The dual winding coil being like a drum skin and the cap being the drum stick. This can be seen in most Tesla patents and is the reason for his "Freaks" that he produced.
Once initiated the process takes quite q while to spin down. Bifilar broadcasters and receivers would allow the background to bias it. This Bias not matter what you say it isn't is the basis of all life or matter. Access to this natural bias is merely through intensification of that natural field. We can empower it to yield any amount of energy based on the natural bias already present in the environment. We live on a MASSIVE amount of inertia. It has fields of it's own. You could think of them as a pom pom like orientation it is what holds up our massive atmosphere. There is a massive amount of energy moving and flowing around our sphere of the TESLA coil. Learn how to modulate the natural energy all around us should not be very hard and very simple. Tesla KNEW this was the only way to harness our energy that SPINS all around us! Remember the field is 90 degrees out of the magnetic sphere. It is what holds our shape , it's what causes the bad weather we have been seeing and it is what holds us in orbit around our sun. It has become out of balance and it's resisting the change. Hence all the earthquakes. We are speeding up and matter looses the battle in the end. We should be able to correct everything about our world through manipulation of the intensity of this field. Remember a higher base of energy or oscillation would increase the output of this system. We could also let man be what he is and that is the ultimate wonder in this universe. Seeing all of this beautiful vastness should become our aim. It is after all the reason we are here. We are the eyes and the proof the Universe exists.
I think it's time for man to grow up and relearn what we have mystified and turned into mumbo jumbo. We have forgotten our humanity and turned into a drone society. We follow blindly the command they issue and kill in the guise of righteousness. Yet we hold each accountable for their individual killings. So it is good for the goose but bad for the gander. We need to fix the problems that the corporation refuses to address. We must devise our own way of life that can benefit each and everyone living on our world. We need to stop fighting each other over resources and fix the gluttony we so dearly cling to.
Once we defeat greed by releasing this system nothing will hold value like it did before. The basics would be supplied because we will have infinite energy to address anything that may come up.
We must pickup Tesla's system it is the only way to do it fairly for every human being on this planet.
Remember we can use the near fields to control the far fields. The skin effect works on the 3d level. You can cause spherical waves that you can guide through fluid dynamic laws.
T-1000
jbignes5
 Any secondary energy can not be called input. It is allowed to enter via a tap or orifice. It is not an input that is supplied by the user. It is a reaction of the environment designed to interface with the already existing field. We just gather it's density and increase the current flow by doing so. The static field can be used in this process. It is static and once the flow begins it wont be stopped entirely. The strength of the circular static field can be immense. Radially formed torus shapes are extremely strong to movement and tend to skin with stronger effects. The field will have give but usually it gives in a lateral direction to the electric field. This bends the line but never directly compresses it. This is where spin comes from. We must design in the vortex pattern into the coil to increase the power more. This will have to be a multi-layer process to add more modulation to the existing stream. We should be able to multi channel the same stream to exhibit additional frequencies on the same stream.
I had chance to think about the transistors used to control the voltage current. A bifilar coil input on thew magnetic amplifier should fix the problem of the limits to silicon. A magnetic version would be more robust and allow for a much larger control range to the traditional transistor. This is the answer and is a superior control mechanism. Especially because it controls the pathway via anti magnetic qualities through polarization. Just like in Tesla's magnetically quenched spark gap we can have a finer control of a larger value through the channel. This has to be a split off the main current to have the same force on the oncoming forward flow. This polarized the iron core to push the magnetic field out of the iron or core. This creates a very high magnetic spheroid (squashed sphere). This is the same process that goes on in the jewel thief. The quality of the Magnetic amplifier would be based on the resistance of the input bifilar coil. Lowering the resistance will greatly increase the sensitivity of the MagAmp. With the power path having only the resistance of the wire and choke wind. Conversion should be very high at that point going through the choke wind. This is due to increased voltage and corresponding lower current conversion. This will maximize the voltage and lower the current of the magamp. Any resistance after the magamp will be pointless in the power loss then because higher voltages equal less reactance to resistance. <-thats what they do now to reduce losses in transmission lines.
The device of conversion should include a transformation of the very high potential into a very low potential and high current. That way losses are limited to the conversion area if any length of distance is included in the origination and conversion area is included.
If we understand we need to work with this stuff in a circular method. There is a special resonance that produces a free acceleration of the energy. A conical form should be sufficient to react from a toroidal conical coil. Sir Dyson has proven that the conical shape is very important to acceleration of the fluid like properties of air..  It is this very concept we must use in our power generation devices.
Building special rotor or armature cores is the key. We must understand that cooling of the core must be part of the design since that core will be the conversion target or convergence of electrical stimulation.
stivep
Quote from: Haan on May 06, 2012, 03:32:09 AM
Wesley,
the attached  picture  is shown in your video "Tariel Kapanadze HV generating circuit SHVGS" http://www.youtube.com/watch?v=IAPe3DiYt2o at 01:43
Please tell us where it came from.
Also please translate it into English.
The attached picture   from the post of Haan come directly from Gia He stated that TK utilized it in his device.
He said that Glass table had no spark that is shown  in video but there was a wire instead of spark gap creating direct connection.
He said that instead there was two hidden spark gaps  in glass table.
the spark on glass table was created because of demand of examiners.
So he went to the device and cut the wire,for them to see  how big is the spark
In presentation  under the tent he used
this instead of spark gap.
http://www.ebay.com/itm/180835174323?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648#ht_1276wt_986
but he also used in presentation for me personally
similar device only  less power from gas heater
http://www.youtube.com/watch?v=_YPVwfnvqw0
The picture pointing to ignitor under the tent come from Niko one  of people close to NYW Group
Wesley
PS: You want "them" to be   GBTB or you want GTBTB by yourself.. help me out to make it happened. Analyze Tent Presentation post schematic of whatever you think is happening there..
