0 Members and 52 Guests are viewing this topic.
stivep
PART#3
If you want to know where is charge stored in the capacitor the answer is
dielectric material.
for the question where is stored charge in vacuum capacitor?
the answer of scientific group I'm associated with was
displacement
quote:
picture it Wesley as displacement
and
energy is always stored between plates of capacitor
well displacement is always  attached to point of reference
If we have space (vacuum as energy storage than  if we are at reference point
we are able to control displacement and extract energy from vacuum..
For us to have unlimited FE it is only  important to find reference point.
if we can store energy in the vaccum than we can extract it from it..
In reference to
cosmic ray= pure energy no mass according to science
photon     =pure energy no mass according to science
But photon      can not penetrate walls of your house
but cosmic ray can       penetrate walls of your house
So we are dealing with two different forms of energy here differing  with  ray properties
It is believed that photon travel accros the space as  cosmic ray does
so than
If  vacuum could be displaced as dielectric medium than it must interact with both  photon and cosmic ray on its way  of travel
if you look at capacitor video  from MIT you see that movement  electrostatic meter happen only when we move distance between  plates of capacitor.
MIT Physics Demo -- Adjustable Capacitor with dielectric
http://www.youtube.com/watch?v=e0n6xLdwaT0
This video also showed  charge stored in plexiglass
but also proves  point that dielectric by itself when moved = displaced
makes effect as we where to  live dielectric untouched and move  plates of capacitor only.
MIT Physics Demo -- Dissectible Capacitorhttp://www.youtube.com/watch?v=9ckpQW9sdUg&feature=endscreen&NR=1
conclusion:
When any movement happened
a- of dielectric medium
b- photon or  cosmic ray  movement
c- capacitor plates movement
we have mutual interaction of all 3 of components
That might prove the point of vacuum acting as storage  of energy at given  delta T point of space geometry  and point of time.
At the displacement than we  could move and see  differentiation of space due to displacement  properties
Electrostatics, Capacitance and Dielectrics - Concept
Builder
http://www.youtube.com/watch?v=nO2agzpooeY
Capacitors and Dielectrics Theory Part 1
a,
http://www.youtube.com/watch?feature=fvwp&v=NZwCrNcrw-k&NR=1
(at minute 4:55  compare point b)
b,
http://en.wikipedia.org/wiki/Vacuum_permittivity
appendix1:
What is permittivity of free space? - Definition from Whatis.com
permittivity-of-free-space
The permittivity of free space (a vacuum) is a physical constant equal to approximately 8.85 x 10 to the 12th farad per meter (F/m).
appendix2 :http://electrochem.cwru.edu/encycl/art-c04-electr-cap.htm
. Relative dielectric constants "k" for various dielectrics
appendix 3:
Electronvolt
http://en.wikipedia.org/wiki/Electronvolt
Historically, the electron volt was devised as a standard unit of measure through its usefulness in electrostatic particle accelerator sciences because a particle with charge q has an energy E=qV after passing through the potential V; if q is quoted in integer units of the elementary charge[/font] and the terminal bias in volts, one gets an energy in eV.
Please look at subsection :Energy
Atomic properties like the ionization energy are often quoted in electron volts
300 EeV (3×1020 eV) = (50 J :[5] the so-called Oh-My-God particle(the most energetic cosmic ray particle ever observed)
But cosmic ray occupies certain space and has certain volume in given delta T
That means it is renewable and in spacial geometry represents multiplied volume.
Cosmic Ray detector at the University of Utah's Delta office
http://www.youtube.com/watch?v=pLIj3fWP2l8&feature=fvst
Cosmic Ray Spark Chamber
http://www.youtube.com/watch?v=DpW08xV3RI8
Cosmic Ray Spark Chamber at Rutgers
http://www.youtube.com/watch?v=9Eip3Ece2HI
Prof Alan Watson - IOP Award winner: on cosmic rays
http://www.youtube.com/watch?v=hOSoGPXqNjo
he says  about speed of cosmic ray to be greater than speed of light..
that would stay about "time being distorted" as the highest speed is officially speed of light.
Cosmic Rays - Cosmic Background Radiation - Anti Matter http://www.youtube.com/watch?v=U1yhka8u-AI
"If we could produce electric effects of the required quality, this whole planet and the conditions of existence on it could be transformed. The sun raises the water of the oceans and winds drive it to distant regions where it remains in state of most delicate balance. If it were in our power to upset it when and wherever desired, this mighty life-sustaining stream could be at will controlled. We could irrigate arid deserts, create lakes and rivers and provide motive power in unlimited amount. This would be the most efficient way of harnesing the sun to the uses of man." ( Nikola Tesla, June 1919 )
Alfvén's approach to physics
http://public.lanl.gov/alp/plasma/people/alfven.html
Alfvén's approach to physics was based on insight and intuition. He was quick to understand how nature works and he was able to place new observations into a framework larger than that required to explain the observations themselves. For example, in the early 1930's, cosmic rays were commonly thought to be gamma rays filling the entire universe. However, when they were discovered to be charged particles, Alfvén offered in 1937 the novel suggestion that the galaxy contained a large-scale magnetic field and that the cosmic rays moved in spiral orbits within the galaxy, owing to the forces exerted by the magnetic field. He argued that there could be a magnetic field pervading the entire galaxy if plasma was spread throughout the galaxy. This plasma could carry the electrical currents that would then create the galactic magnetic field.[/size]Alfvén's discovery of hydromagnetic waves is another example of an original idea having a far-reaching impact on multidisciplinary science.
appendix 4:
Permittivity and capacitance are mathematically related
http://www.physicsforums.com/showthread.php?t=259916
The electrical permitivity of a vacuum is 8.85 pF/m.
The actual value of any capacitance depends on it's geometry
Wesley
forest
About HV module in 200W device shown to stiveip.
I don't think that HV module used to ignite gas can discharge HV spark continously. is there somebody from Zariad group ? I think this module is set to discharge at some rate which cannot be exceeded.
Am I correct ? Does somebody have documentation of that module ?
leo48
Quotein Reply #11501 I asked you to translate the picture's wording into English.
Please do this.
It can translate the Cyrillic alphabet in English using Google translate by clicking on the keypad at the bottom left of the window u using the mouse to beat prompt
the words and get the text in English and if you want you can also listen to voice
regards
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
ronotte
Hi Stivep,
speaking about cosmic rays may be misleading as they do not reach earth directly: they first impact on upper atmosphere and mostly are arrested producing a secondary showers of high energy electrons, gamma rays, protons, neutrons, photons, etc. Is that secondary emissions that we are able to track and record mostly on high mountains in Nepal.
http://neutronm.bartol.udel.edu/catch/cr2.html
"...When the primary cosmic ray strikes an atom in Earth's atmosphere, the collision may produce one or more new energetic particles called "secondary" cosmic rays. These secondary particles strike other atmospheric atoms producing still more secondary cosmic rays. The whole process is called an atmospheric cascade. If the primary cosmic ray has enough energy -- greater than 500 million electron volts -- the nuclear byproducts of the cascade can reach Earth's surface..."
Roberto
pix
I think that things are overcomplicated here.
Consider simple spark discharge in air as OU device.This is electron multiplier.
Regards,
pix
