0 Members and 70 Guests are viewing this topic.
ronotte
@wattsup
:) ...I'm happy that you succeeded into putting in action your circuit. Please count on me for every ulterior needing.
I remember you also that such 'low side' switcher is not complete as driving a reactive load does imply the use of a proper Snubber circuit...or you are prone to have your mosfet zapped (in the meanwhile a strongly suggest you to power your test coil with no more than 6VDC). If you want me to design the correct Snubber, you have to give me the your TBC's primary coil L & R data. I can run PSPICE Snubber's optimization, provide that I already have a good knowledge of similar scenario for well known mosfets...but mainly for air coils (as used for TPU...).
I'm also happy to now that something's moving about the 'special' TBC from your friend Bob. Please keep me informed.
@Stivep,
Hi Stivep I thank you very much about your effort to lay down some foundations justifying the WNG group experiments direction. I encourage you to continue your home-task as it is touching many very interesting concepts that could be true or not...but in any case  could trigger interesting line of reasoning. Actually you are playing directly into an almost unexplored ground hence hypothized concepts could be true or simply abstract hypothesis...who knows? The important is to leverage on few well known even weird incontestable facts and then built on them. It is not easy: I do know it very well as in the past I've been faced with some of them and I saw by myself some effects indicating 'time warps' but only recently I've been able to correctly identifying them :( It is interesting to know that such kind of phenomena always appearing while pulsing with very short pulses (1-10nsec) and medium voltages (100-1000V) air coils (TPU's ControlCoils).
I'll wait to read all your exposition so having a complete frame to consider before expressing my thoughts on the matter. I wonder also if you with your WNG help could dig further on the effect you observed in relation to joke device and of course for the Tesla ionization device: I've not seen a reassuming test report. I've to warn anyone on ordering anything to ebay 'Siberian market' shopper as I've not yet received the valves I ordered them since almost 4 months ago!! Of course now I've found from a near radio amateur a set of 2E26 beam tetrodes that are very good for the experiment and I'm now finally wiring my Tesla/kacher unit as proposed by WNG group.
Ciao
Roberto
leo48
Please...
СиммеÑ,ричные каÑ,ушки индукÑ,ивносÑ,и выполненные биÑ,,илярная = Symmetric inductors made bifilar
(а) и перекресÑ,ная = (a) and cross-
(б) намоÑ,кой      = (b) winding
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
stivep
Quote from: leo48 on May 08, 2012, 08:02:29 AM
Please...
Leo48
basically it is that we have two different  ways to wind bifilar coils
both of them comes from Tesla
Utilized by Russians
One of the left is straight bifilar
The other one  on the right is cross winded
what is important to fallow is that right hand one is caduceus type of winding!!!!
but it does have "tip  lid " on the top while  caduceus does not have one..
Wesley
jbignes5
Hey stevep,
I wanted to ask you something. Could the fold of the solenoid coil back on itself create an inductive bearing to the filed. If the input was from end of fold to the other end that would create a very interesting filed effect. If you understand that the radiative part of the coil(high voltage field) will have a much larger portion of field on that high voltage end. That creates a vortex like near field. This vortex has flowing heavy current bands running in a corkscrew like fashion over the filed surface. Linning another filed next but inverted to the center gear field would allow them to mesh and transfer the conversion of going from outer diameter to inner diameter of the coil. It is the angle of those fileds and how cw and ccw fileds can mesh together and impart a mechanical advantage. Multiple fields around a central take off gear field would increase the power handling of continuous movement of the field.
I'll see if I can find a mechanical example.
http://upload.wikimedia.org/wikipedia/commons/8/86/1948amhub.jpg
Our ability would hinge on the reflect-ability of the receiving antennas.bifilar coils. A common buss bar could be used in a ring fashion to terminate the antenna's around the blast area. Remember this could be a response so big to physically damage things. Start small. design safety measures to protect against overloading the network. Think of star level blasts, star meaning our sun. Heat will be a natural by product of this process. And it's a great source to generate from and provide heat when needed in more conventional methods. Lowering the resistance of the bifilar reflectors should increase the ability of the coils to reflect the on coming waves from the blast. Multi layered  coils will provide less resistance the deeper the waves penetrate the shields. When you open the shields they will transmit the sideways bending the lines had to do to not violate the length rule. The lines will move explosively through the coils with many many times the force that was inputted by the blast. That would be the sphere method. The solenoid coil method can use gear physics to extract power from the bending lines. This amplifying of the force comes from the uncompressing if the lines in a lateral direction + the force of the rebounding from the reflectors to the source electrode and subsequent blasts. The good thing is nearly all of the forces are absorbed by the bifilar coils on the unshorted timing.  At least in theory.
FreeEnergyInfo
SHEMATIC ....
www.freeenergylt.narod2.ru/anonimus_free_energy/
texnik .....
1 медная Ñ,рубка с разрезом.
2 поверÑ... Ñ,рубки Ñ,рубка изоляÑ,ор.
3 поверÑ... Ñ,рубки изоляÑ,ора вÑ,орая Ñ,рубка с разрезом.
4 два слоя изоленÑ,Ñ‹.
5 две каÑ,ушки съема красный провод.
6 чеÑ,ыре слоя алюминиевой пищевой Ñ,,ольги.
7 намоÑ,ка биÑ,,ляра минус.
8 вÑ,орой слой биÑ,,ляра +.
  1 A copper tube with a slit.
  2 top tube tube insulator.
  3 over the second insulating tube tube with a slit.
  4 two layers of electrical tape.
  5 two coil pickup red wire.
  6 four layers of aluminum foil food.
  7 biflyara winding minus.
  8 of the second layer biflyara +.
