0 Members and 51 Guests are viewing this topic.
27Bubba
Hey Wattsup, I'm happy you got the problem figured out. I'm looking forward to some videos.
Best..
BR
jbignes5
 Maybe you can make sense of this stevep.
When you slide to coils apart it creates a meshing of the fields and traction takes over between the cycling fields. Freedom of will direction will most likely go in the positive direction. Correct Field orientation would be a must and will follow wind direction generally. This is a singular drive reflector. the outer field coils will reflect while shorted and can be modulated via shorting and unshorting the reflector coils.
I think this is partly what Kapanadze is doing. The drive has to be the middle coil and the extractor is the inner coil in the oil. I might have the gauges off a bit but I am not sure about it.
The lower black arrow going horizontal to the right of the Electric line marking. The black arrows should be pointing inward since this is a variable static line. The variable is the bias we supply for the near field of this whole planet. This instantly energizes and biases everything in the near field instantly. Then just as fast off. The speed of the near field is immense and can be focused into amazing apertures. This bunching of these field lines already established and intensifying the strength then using them like the best springs. This reflection of the fields can be most perfect at the right angles. There are certain mechanical and hydrodynamic laws prevalent to this area.
Why exactly do you think Tesla got into improving the physical system for vortex technology. His turbine units more then proved his theories and even the direction he went while investigating this most wonderful fluid.
If we take this setup and turn it over the ring around the center cog might support itself and spin around the unit.
To add to the units generative ability one could wrap a layer around the outer coils and pick up the heavy current (magnetic fluid). Just wind it 90 degrees around the exterior coil and pickup the heavy stuff squirting through the fields.
stivep
Please give me some time  for analysis
I have few things that preoccupy my attention..
But I'm incredibly thankful for your comments.
Try to figure out tent presentation by analysis not only tent videos but similarities
to others.
- electric motor acting as frequency generator is  sort of justifiable evidence..( in green box it was 220V even if for some of you it looks like 12V.. "asinchronic" type - I do not know how to properly write it in English.
Wesley
PS: every move, every try, every idea... bring us to end of domination..
GTBTB
jbignes5
Quote from: stivep on May 08, 2012, 08:31:07 PM
to others.
Wesley
GTBTB
The tent presentation was like the blue coil setup right, in the plant room?
wattsup
@ronotte
I ran the circuit  on my 2Pri2Sec toroid that ran the flyback that made the spark that ran some output coils. I found the spark was very consistent but weak.
Well, to be consistent with my mosfet burning ways, after experimenting for a good few hours on and off with different output coils, at a certain frequency the IRF7307 just fizzed out. So I am thinking now that if the IRF7307 simply provides a convenient ultra small package that only has an N and P channel mosfet, then I prefer to use real mosfets instead. I will re-do the circuit with real mosfets and heat sinks on each and plan it out as per your circuit. I have some IRF9540 and more IRF840 so this should be good enough to try it AGAIN. This will also give ma an easy change out method since re-doing the IRF7307 and putting it back on the circuit will be a killer job.
TKs Green Box had two mosfets (parallel) on huge heat sinks with a fan). Hmmmmm.
@ronotte, do you think the 6N137 opto is enough to drive real mosfets or should I put two of them in parallel? Also, maybe I should parallel more mosfets after the opto (2 times N and P channel mosfets) and at the outputs as well (2 or 3 times IRF840). This is war against the beast. Every time I hit a certain frequency, bang fizz.
wattsup
