0 Members and 77 Guests are viewing this topic.
ronotte
@wattsup,
half filled glass: at least this time you have saved your precious generator ??? .
No, the optocoupler does not have enough current drive to charge properly the IRFxxx switch. Best way is to use a complementary discrete set like you mentioned on a proper heath sink.
About the output you have not mentioned the battery you used, 12V?  Please consider that driver failure due to probably 50% duty cycle you could have used! I forgot to reccomend using a much shorter ON cycle....20-30% ON could be much safe. It could be also interesting if you could post a pic about the waveform on mosfet's drain pin in order to evaluate the Snubber necessity.
Ciao
Roberto
ronotte
@jbignes,
referring to your kacher-delamorto implementation you have explicited some ideas that I've tested a couple of months ago. In details I built several different kind of kachers in order to find a way to improve performance but always maintaining the quarter-wave geometry hence obtaining the field you have indicated on your pic. The problem is that with standard approach I've not found any OU so I tried to use two inner longitudinally slit copper tube and adjusted distances to maximize the ouput. I've seen that both copper tube dimensions and phisical relative position being very important: in fact after a careful refining I went near OU. Sadly I get tired and stopped the experiment.
Reading your proposal I find the two parter coils screwed  'one inside the other' is very interesting and I agree also on oil isolation: in fact I suffered of many HV punctuting and sparks between the two copper cilinders. Your two inner screwed coils mimic strictly my two copper tubes: the difference could be amazing as the copper tube is a single turn coil... I tried to take the load while interconnecting the two copper tubes . I do not remember if I tried as well to connect only one side of each copper tube to lamp load.
It would be great if you could explain more clealy on the reflector operation as I do not fully understand neither his function or the suggested shorting. Thanks
Roberto
dole
Hi,
Some thoughts from the experiments and TK video analysis.
It is quite obvious from TK patent (patent showing conversion principle, not Tesla transformer) and demonstration,
TK is using singe phase to three phase conversion, he must generate 3th leg somehow,
eider getting 3rd leg from 3phase motor in his large scale or SS Tesla transformer (3ph toroid) in a small scale.
(Seams that he was playing with 3ph Tesla toroid for a long time - mechanical device)
I think he needs 3ph motor to synchronize the process storing and adding free leg to peak of each other
synchronously magnifying (black barrel coils).
Mysterious magic or not is how he use hv hf transformer in process (maybe just simply to sustain capacitor charge),
since 3ph ground is connected to hv hf coil or maybe not, or just to misled (experiments will show).
Phase outputs are adjusted through Tesla dynamo regulator. Ground is just ordinary ground.
Who knows … back to silent experiments.
d.
jbignes5
Quote from: ronotte on May 09, 2012, 10:51:13 AM
@jbignes,
Roberto
I'm not sure that I have the fields aligned right. The other field might need to mesh with the center field. It might be that in order to get a difference of the frequency you need to move the sharp point of the one field to pierce the other and mesh the lines together. This way moving the outer cog field will net us a turn advantage or disadvantage as you raise and lower the outside field across the field slope. You just might be right about the orientation and gaining an advantage there.
Well the reflector method is much different. Like the radiometer of Cook the vanes act like a reflective surface to the flow already around our planet. Well as Tesla learned when you divide up the surface area you net more surface area to react with. The reflector should be bifilar wound 3d coil. Any shape will be allowed for it's operation. You could tailor the shape of the reflected blasts any way one wanted. Either to disperse the wave or perfectly reflect it or even focus it. The reflector should have close to no resistance in it's self terminated flow and can have considerable charge built up after the flow reflects that can be recaptured via more traditional bipolar capacitors. Matching the coils resistance to the caps esr should be the resonant spot of perfect transfer. Lowering the resistance can be done on both ends of the coil and cap hook up via paralleling.
When the reflector is compared to the internal electrode, the internal electrode will always have way more energy flowing due to concentrations of intensity between the two from the previous reflected waves. You could think of the design as being a soccer ball like design or Bucky ball. The center electrode is the base and the hexagonal geometry of the coils creates a very focused bubble. The perfect Layden jar. The electrode in the center needs to be able to handle immense temperatures. You might want to start thinking of ceramics like the space shuttle uses to shield the bottom of the shuttle. Dope the ceramic with the right metallic element and you have infinite energy. Well as much as that stuff allows you to tap. Matter is only so strong to resist the fundamental energies. But using fields can have vast amounts of power in it. We knew little of the fundamental energies because they usually work in very subtle ways if left unbiased. Once you bias the energy field it enhances the information received. The whole field grows more intense capability with near infinite division. We can supplement the natural lows and turn them into great feats of wonder. We can turn up the fidelity of our existence and rise to the surrounding crescendo of interstellar life. There is one fundamental proof that life does exists in the Universe. All we have to do is pay attention to the three fingers that points back at us when you point to the sky. We are the example and until there is someone out there to answer we should welcome the diversity of this great Universe with open arms. We can protect ourselves and no one should deny us that. We should also try to protect others that are or were working with us before.
woopy
Hi all
Hi Wattsup
Here my progress .
Seems that we can correlate the energised antenna , the oscillation of the ground , with the electronic of the LED (load.)
Somebody have shematic of this kind of LED ?
Hope this helps
Good luck at all
Laurent
http://youtu.be/hp9wCNFF6TQ
