0 Members and 80 Guests are viewing this topic.
jbignes5
Hey Woopy,
What happens when you put a cap around the battery? Does the effect get stronger?
The HV to the antenna should use foil static shielding Ungrounded, where you want the pulse to emit from you use it unshielded.
woopy
Hi Jbignes
What do you mean ?
Something like wraping the batteries with some capacitor layers ?
thanks for elaborating
Laurent
jbignes5
Quote from: woopy on May 09, 2012, 04:55:41 PM
Hi Jbignes
What do you mean ?
Laurent
Hmmm.. Build in the captret. Or just paralleling an electrolytic cap to the battery. But the captret idea seems to be interesting. You did a separator between the batteries right? You could used the foil to create a bipolar ground. Sorta like the captret does. Since the bipolar ground  will interact with the lead in the battery, especially the positive electrodes, you might be able to get the captret effect. But it might need to be directly connected to the electrolyte. I con't know what it would do actually.
Ganzha
ronotte
Hi Laurent, very, very interesting: I suggest to use like Tesla did NOT a filar antenna but rather an aluminum plate. You could simply glue standard oven Al foil onto a wooden or plastic plate. Dimension at least 1/2 square meter.  Ha, put it vertical at least 5 meters up from your device. I'll try to replicate it ...when I'll find the correct led lamp.
Thanks
Roberto
