0 Members and 330 Guests are viewing this topic.
jbignes5
 I too think there is some flim flam going on there. But.. And this is a big but, the one simple fact is the coils. No matter what you do thats a Tesla setup. He can't patent it because there is rights already that will negate any claim. So I suspect alot is thrown in to blurr the fact that at the heart of the device is a Tesla coil and concept.
There are a great many things that have been teaken hidden and used with NO credit going to this man Tesla. The effect of building a static field and giving it motion or modulation is mirrored through all the natural processes.
Have you ever wondered why everything has a charge or standing value? Especially metals? We are in a standing electric field. One that is set in motion with billions of really small matter swirling around that potential. So to mirror that we should build a standing charge then modulate that standing charge to do our bidding. We can only do this with fields.
Lets look at the setup: I'll see if I can draw it up simplistic style:
jbignes5
 So what i suggest is to have a balanced inner coil frequency. Somewhere around 25,000 cycles or higher. The higher you co in cycles the more powerful this thing becomes but also this amplifies the current due to resistance not changing. The best thing we can do is reduce the resistance and the heat will diminish. Another way is increasing the frequency and or the current available to the main high voltage coil. This is the energizing part of the equation. Any resistances in that main part will act like a blockage and the energy will flow around the resistance. Carbon resistors would be the best form of resistance because then it is nano sized particles and the resistor will act like a filter or dampener of the speed of the energizing field. This actually causes the resistor to act like a capacitor as well or battery. If you think about it an exciter would raise the standing potential because you are biasing the base field of everything in that exciter field. This is why the exciter experiments have been so impressive and why they sorta work. With distance the effect gets dampened by the natural fields and lowers it's ability to effect the electric field around the exciter. Working in close will only increase the effect. Explosively release the inner field trough the heavy copper and the results would be very dramatic.
Thane uses this same technique to bias the heavy current he was generating with the wheel. This bias is self contained and self generating a reflection turned in on itself.
Let me see if I can pull up some information about Tesla experimenting in this direction. I believe there is a design that never went to patent that was delving in this area.
First thing is that he always equated the electrical to the hydrodynamic version first.
First attached picture:
Next was the proof that this field could be spun.
Second attached picture:
This might help to make you understand that we need the magamp to drive this, to replace the tubes Tesla had custom made by himself. These were tough tubes capable of great resistance to this blast wave, most of that wave converted to heat waves but enough got through to be converted into usable power.
http://teslapress.com/vactube.html
The beauty of it is it is very passive. Shorting out the bifilar will allow it to amass a great potential in reflected growth with extreme speed. Unshorting this unit allows it to apply that potential to the load with explosive power. Filling a cap from that should be a requirement to fill in the gaps or get rid of the pulsed current when unshorted. With a real capacitance coupled with the bifilar's inherit capacitance They should bounce pretty good in resonant modes. Tesla said this would come out as a steady current like a battery. Well constant current. This is done via the special transformer in the upper left of the second attached picture.
Tesla did experiments with multiple transformers and special transformers. Each transformer was capable of 44k by it self, but after he connected them To the special transformer it made the output extremely powerful. I know his final configuration had to be all parallel in the end. Somehow he got an amplified output but only with his special transformer. I think the transformer series the other transformers into pairs and directly opposes each other to add more inertia to the power an increase in the flow speed. Remember we are dealing with speeds and the mass of the energy. Especially when intermittent masses are concerned. Energy can be self accelerated through proper reflection of it's external field.
The lines we should start to talk about. Once formed they are very pliable and the potential we apply to the line will either strengthen or weaken the line. Stronger potentials will bear stronger lines. These lines are the connection to the environment. They are always around potentials no matter how slight that potential is. Intensifying the fields strengthen the fields potential and pull strength on the lines. We could think of the lines in a format that resembles a string of pearls with springs on either side of each pearl. The string being taught the line will straighten out and resist sideways motion to a degree. Loops tend to be the strongest form of line with a line connected between to object the second best. Regular lines being the lower with no termination, although a not terminated line is very sensitive to the surounding lines positions(field rules).
The fluid like form comes from the cross lines that form magnetic flows through condensation of the surrounding aligned free lines.
The egg experiment proved that the lines are real and straight but move in a lateral direction around the egg. This orients the egg to the new lines formed on the next line. Now substitute the egg for a properly aligned coil. Each line cutting the coil in a circular motion. This is a amplifying effect because of this concentration of lines into higher densities.
One of the problems that Tesla talked about was that closed coils still have a current associated with them. This current also resists the field in the center of it due to this minute current in the shorted coil. The pulsing field helps to relax this buildup and make the situation more efficient. Maybe that is why Kapanadze made an air space in between the coils to lessen the effect of reflections.
frantz
Quote from: jbignes5 on May 13, 2012, 09:35:53 AM
http://www.teslauniverse.com/img/wp/19190400-03-03-600x416.jpg
Could you corect your link?
Don't work correctly
Frantz
jbignes5
jbignes5
Hmmm...
http://www.google.com/patents?id=sTZmAAAAEBAJ&pg=PA1&source=gbs_selected_pages&cad=1#v=onepage&q&f=false
Farnsworth seems to be onto something here.
So anyways I was doodling again and wonder if anyone wants to check it out.
Attached picture for reference.
Remember this is a rough draft. Help me to improve this if you will.
