0 Members and 52 Guests are viewing this topic.
ronotte
Hey jbignes5,
"...So to mirror that we should build a standing charge then modulate that standing charge to do our bidding..."
Somebody think that our reality is nothing else than a standing wave  (The holographic universe - Michael Talbot)
Thank you very much for sharing your ideas.. even if you are not giving me enough  time to digest you extremely interesting  presentation :D I do not know if your idea on reflector action is true or not and I already thought to give it a try especially now, after your last possible implementation using a kacher. Fortunately for me I've had in the near past the opportunity to test several different kacher design including powerful push-pull and inverted kirality windings (a- la- Utkin) hence I must say that it will be easy for me to build on your basic idea. Please consider that using a standard kacher it is easy to reach a max of 1 -3KV (in my case) double it for inverted windings. Do you think it is enough to play with kacher pump? Frequency is also important: I generally built units running between 1 - 2 MHz, of course to go lower it will be necessary to load the magnifier coil top...
Roberto
jbignes5
 I will let you guys digest this but here is an edit I did already.
FreeEnergyInfo
INFO ....
www.google.com/patents?id=sTZmAAAAEBAJ&pg=PA1&source=gbs_selected_pages&cad=1#v=onepage&q&f=false
sadang
jbignes5, "...We are in a standing electric field", but we are also in a permanent magnetic field which generate all that said "electrostatic field"... see Hendershot device!
jbignes5
Quote from: sadang on May 13, 2012, 02:47:09 PM
The only field thats exists is the electric field. It is when the field changes polarization by degrees does it accumulate like snow against the existing lines. This accumulation is very concentrated form of electric lines. That is the magnetic field. It is the only way possible to have the magnetic field from how we are starting to intensify it and see it's movement. Somewhere we got it wrong and we wanted to make resources and objects have tons of monetary value. We created the demand for it. Otherwise it is useless.
So now it is time to get back to the basics. There is no magnetic field as a source. It has to be initiated in the formation of magnets via voltage bursts. Read up on it if you like.
A magnetic field is a byproduct of the source voltage field. And is made up of unattached field lines condensing around a potential point.
