0 Members and 379 Guests are viewing this topic.
sadang
Are you sure? Why tesla used magnetic filed to generate electric currents, and not used electric field to generate electric currents? What about permanent magnets? Or about the magnetic field of the earth? And what about the magnetic moment of the electron? But finally, what is an electron? Exist it or not? A bunch of questions, not especially for you, just rhetoric questions!
FreeEnergyInfo
jbignes5
Quote from: sadang on May 13, 2012, 04:01:25 PM
I agree they are all excellent questions. And to tell you the truth why would it matter? This is a science of induction which defies modern physics. Why because it is outside of the possibility that we are a very minute species. I watched this video, if heard out the facts roll along. One connected to the last, all very interesting and maybe a complete understandings of the information we are recovering from the field. Well recovering and researching now.
Yes it's out there but give it some time to get rolling.
http://www.youtube.com/watch?v=U8NNHmV3QPw&feature=related
This one has great music!
http://www.youtube.com/watch?v=Jp6dJrt94cA&feature=related
http://www.youtube.com/watch?v=hKJluXR1Ipo&feature=g-vrec
jbignes5
Quote from: ronotte on May 13, 2012, 02:39:00 PM
Hey jbignes5,
"...So to mirror that we should build a standing charge then modulate that standing charge to do our bidding..."
Somebody think that our reality is nothing else than a standing wave  (The holographic universe - Michael Talbot)
Thank you very much for sharing your ideas.. even if you are not giving me enough  time to digest you extremely interesting  presentation :D I do not know if your idea on reflector action is true or not and I already thought to give it a try especially now, after your last possible implementation using a kacher. Fortunately for me I've had in the near past the opportunity to test several different kacher design including powerful push-pull and inverted kirality windings (a- la- Utkin) hence I must say that it will be easy for me to build on your basic idea. Please consider that using a standard kacher it is easy to reach a max of 1 -3KV (in my case) double it for inverted windings. Do you think it is enough to play with kacher pump? Frequency is also important: I generally built units running between 1 - 2 MHz, of course to go lower it will be necessary to load the magnifier coil top...
Roberto
Thanks for the mention.
I would start low then go high voltage. Thats what I am planning. Winding directions will be my worst subject but I think I'll get it right eventually. So 1-2k volts will probably be ok. I would suggest trying my way becaus of the increased capacity of the mag amp. I don't think silicon will handle the current.
But it will have to wait for some proper magwire that I can have clean winds. The gauge size is also very important. That will have to be played with. My first version will be quite small.. I only need 500 watts for my scooter. That should be no problem with this system.
T-1000
Quote from: jbignes5 on May 13, 2012, 03:36:25 PM
So now it is time to get back to the basics. There is no magnetic field as a source. It has to be initiated in the formation of magnets via voltage bursts. Read up on it if you like.
A magnetic field is a byproduct of the source voltage field. And is made up of unattached field lines condensing around a potential point.
You need to flip that upside down. The pernament magnet is direct energy source.
The resonance in magnetic field will not diminish(yes, you need magnetization and magnetic field oscillation after) when load is applied to electrical field byproduct in special case.. :) This is what also N. Tesla was about with wireless energy transfer.
