0 Members and 557 Guests are viewing this topic.
frantz
Georgia have a flood!
10000 people are without grid power. Maybe TK will help his own country...
And other too...
jbignes5
Quote from: T-1000 on May 13, 2012, 11:03:00 PM
You need to flip that upside down. The pernament magnet is direct energy source.
The resonance in magnetic field will not diminish(yes, you need magnetization and magnetic field oscillation after) when load is applied to electrical field byproduct in special case.. :) This is what also N. Tesla was about with wireless energy transfer.
I'm sorry but magnets are only specific sized balls mixed together to form energy channels. Channels that polarize or give a specific spin to the lines it holds. The energy is all because of the minute particles emitting fileds that interact with each other bidirectionally for the most part. When you flip the paired channels and polarize them they all align up in parallel orientation. These channels are loosely bound. They are not directly connected(inductive connection only). This is an electrical phenomina that uses that particular set of reactions to a field. Especially a polarized field.  It is this that causes the diode like effect. It is why we can simulate a transistor with only coils and a core(Magamp). Current or magnetic fields are actually a byproduct of the vast voltage field we call our Universe. If that voltage field was not there nothing would be connected. Nothing at all. The electric field is an exciting field, no pun intended. This area has not been explored very well. It seems we went astray because we forgot about this subtle force. The same force that gives water it's ability to do it all. How you conduct this source or polarize it determines the outcome. It seems polarization is the strongest form ever over distances.
All of what I have been saying goes along these lines. You don't need numbers to divide the Universe. Generalism can completely explain all these processes If you adjust your view of what energy is. Shift 90 degrees and you will see the real force at work. It is not magnetism that runs it all. There is very little magnetic interaction out in the universe, where there is, great destruction or flows that we could not even explain happens (Black Holes).  The higher you go with voltage the less real current it uses in the transmit portion(Massive loss of loss = greater efficiency. Only convert where you can dissapate the heat from the resistance of your units generating coils. The best setup is high voltage to direct conversion to current in the generating coil, this will supply the amount of energy through induction and excite the energy via reflector coils. Very high voltages could be created as reflections reverberate in the core. Bifilar pickup coils when put into this exciter field, EXCITE Both ends of the spectrum and act like a battery. This can be the perfect battery that both stores and pressurizes the natural network around it. The tune of objects would change slightly and we could create a living environment again through this excitation field.
When tuned right it enhances our bond and we become more connected. The benefits are endless. We just need to go slow.
Some thoughts on what water really is. Water is life. Water is ever pervasive and is usually called the ultimate solvent. Lets look at that statement of Ultimate solvent. What if water was a condensation of the Ultimate solvent. Maybe water will show us how to efficiently couple to the natural flows. The combination of water(condensation) and oil could show us the movement of this surface. How does shapes effect the form of the container. Like spherical, box and pyramidal shapes. Learn about reflections in that interface and you will harness the very wheel work of nature. What happens when you drag a sphere through a water bath. Only put it in half way and drag it along at incredible speeds. The magnetic lines are actually great collections of waves that stack like flakes. The waves are the medium we float in. Let me see if anyone did this.
You do understand that 220kv sphere that is around us is a barrier we are in that field. This is what gravity is. Things flow from uppermost to lower most. These flows cause great masses of gasses to move across our planet and to interact generating huge eddying flows that sweep across our nations. These flow will show great layering ability. This is the density game now. Higher density of mass the faster and harder it will fall. Likewise when you lower the density (hot air balloon) it rises like a bubble in the deep sea. This is a fundamental rule of underwater diving. Bubbles will almost always go up, except for those vortex bubble the dolphins play with. Hmmm.
Space and matter does some strange things when one of them is removed from the equation. Check this out. Gravity is the only thing missing in this experiment.
http://www.youtube.com/watch?v=zaHLwla2WiI&feature=results_main&playnext=1&list=PL13A000477DB5CE8D
The water in space experiment can be equated to the ability of water to adhere to itself when it is absent from gravity. That buble could be equated to the atmosphere  and our bubble. The bubble is a constant in this fractal. The line as another. It would seem obvious to me that we are in the space of a super immense black hole. The matter that is in our universe is the remenants of matter that had ultimately squished into the finest substance ever know to anything or to be exact the Ultimate solvent.  Built with the power of the immense matter that had collected or condensed. I suggest we have a cycle. That cycle is about to restart. Good news guys we are on the way up. Lets see if we get it right this time...
You can think of it like this. At around Tesla's time they were still heavily debating what physics was, heck they are still debating this and yes I sometimes enter that debate. We were peeking then because of Tesla. AC was the best system at the time. It allowed them to get power to the masses. Somewhere along the lines it became about getting an income. It stop being so important to look any further. They were happy with what they had because of this tap to power. They control the masses with the amount of power they let you take. Take more then you have to pay them for it and it will cost you. Really it's a loosing battle that way.
Nothing will be more important to the corporation then increasing the dividens of it's investors. That is the only reason for this terrible entity we call the corporation. Corruption is rampant and far more reaching then they really let you know. If one wanted to ask about something there is a bevy if freedom of information bs you need to fill out. I'm surprised they haven't asked for DNA yet. But then again it only takes a scan of the documents you had requested or anything you have touched public or private to get that.
We are letting them loophole the constitution by what they call amendments. These are not directives they are additional "rules" to control the masses through teaching and reinforced slaps on the wrist. The amendments are to further describe or reinterpret what the previous amendment described could not do?
Our rights are being systematically phased out into a carbon copy robot world. Work you fingers to the bone and forget everything about family and love. They keep us agitated by reinforcing the bad "News" via any kind of media available. This has now infected the internet. The corporate mentality is only trying to make interesting violent content to keep us on edge and satiate the beast within. Stimulants are rampant to increase the buzz and you will pay dearly for that. Both in health and mentality.
We need a change and it is coming. How we understand the processes are changing everyday. They are lining up with what I and others are saying and doing, experimentally It will prove itself eventually and thats where I'll leave the conversation. Tesla said it best that the future was his. He knew there was no other best way to interface with our environment and expand our reach both in distance and wisdom.
ronotte
Hi jbignes5,
I'd like to cooperate with you in a preliminary analysis of your kacher current pump design.
Part #1 deals with the the input RF mag amp:
1- first question is: why you are introducing such device? Your simplified sketch should be a mag amp where the mag amp is powered by ambient RF energy and output should modulate/interrupt the 'bifilar receiver' coil over the 'HV coil'. Is this correct?  Note: the connection should be unidirectional and a diode should be put in series.
2 -No standard mag amp DC biasing (control coil) is provided. Probably because the operating point is considered fixed around axes crossing (of saturation curve) hence bias =zero voltage.
3 -It is not clear what expected from such setup as even if obtaining 1mv from eventually tuned antennas and a x100 gain ...we are still around 100mv output on the load: not sufficient to interrupt it...
4- Connecting the mag amp load coil to load (bif rec coil) in series with lamp load should provide for mag amp exciting frequency (from the HV coil) to power the lamp load
5 -Input mag amp coil/antennas should be optimized in function of the RF field sensed in the operating ambient, so it is necessary to properly dimension both antennas, tuning circuits and of course impedance matching.
6 - Max amplification factor (high mag slope) is obtained using saturable reactor cores like ones manufactured by METGLAS. It is a good thing that I owe some of them. I'm not sure how they behave for Mhz range or whatever RF region showing max field value.
Roberto
jbignes5
Quote from: ronotte on May 14, 2012, 02:32:02 PM
Hi jbignes5,
(Good question. My thought was that if current is of no use to use in this field then only using the background flux of multiples of waves, This input would be free and self timed. Amplifying the background will instantly keep the same harmonics and frequency. The antennas are for focusing and intensifying the input on the fly. this takes care of the input signal Tuning can be adjusted there too. The load runs through the heavy coils that have been energized previously. The heavy bifilar coil is in between two coils. One folder over on one end and the other surrounding the whole thing. Since the energizing field energizes all of the metal it becomes super excited and charges to a great value when the lines are drawing trough the bifilar coil. Shorting the coil allows it to charge up and unshorting the coil allows it to dump most of that charge that was stored up in it's capacitance. The pulsing is a feature if you wanted the load to be ac based I think. If it is constant current then the pulsing could be done away with but you will still need a control mechanism for current control.)
Answer: (You know i got the idea from the roadster story. Antennas were used and I think since Tesla knew about focusing ability of this energy that he could intensify the frequency without loss. In fact he thought it had a higher fidelity after intensifying it. New details could be seen as it intensifies It could be that the antennas are connected to the bifilar oil cap as well to hold great masses of intensified space.)
Answer: (Remember this is very high voltages with very little current involved it acts very different from magnetic current. I just wanted an on light like "power is engaged sir!") lol
Answer: (I can not agree with you more Tesla said the same thing tuning is a must but not only tuning but resonance of masses and surface area per mass was well.)
Answer: (Nice, someone will have the ability to get max from the interaction. I'm still trying to find someone willing to make Bessemer steel for me in the proper method. Tesla said he used it in all of these systems. That is one component that has never been duplicated and hence why most fail. The special transformer that I have shown is the source spin that can be harvested both inside and outside of the ring. It is the electric field we are dealing with here and it is a much different beast then heavy current fields.) Anyways frequency will probably be on the lower end below mhz but who knows.
Roberto
gedfire
Quote from: core on December 02, 2010, 05:46:23 PM
John,
     After work today I built a very quick 'Proof of Concept' circuit that consisted of nothing more then just a induction coil (older style automotive ignition xfr), High voltage capacitor (35Kv / 400pf) copper plate and spark gap.
I have to say I was quickly rewarded with results. These results may cause controversy depending on what you have read in books regarding high voltage and capacitors.
   As far as I see it I was able to 'pull' a spark from a copper sheet in the air. This is how the experiment was conducted. For HV I used an induction coil 12 volt input for a car. The HV output, about 9000 volts dc was feed to one side of a 35kv 400Pf capacitor. The other side of the capacitor I had a wire that leads to a copper plate mounted on PVC pipe. Also off  the capacitor I installed a spark gap to ground.
Hello Core,
I am fascinated by this experiment.It has been awhile since you posted this but wanted to know if you or anyone else did a followup or confirmation of the results.I would love to know.
   I was a bit surprised to see a spark and a current being generated. The capacitor is rated for 35,000 volts so 'breakdown' is a non issue.
[/quote]  I have an old book that I downloaded from the internet about high voltage. This book was written during Tesla's time around 1910 or so. The most interesting park of the book was a paragraph regarding HV. This author states that HV run like a sound wave. [/quote]
Could you state the name of this book please? It appears to be a must read.
  [/quote] As it stands I was firing this by hand. A driver for the induction coil would be much better to have.[/quote]
Have you tried using an oscillator yet?
If anyone on this forum understands or have replicated this or have any other hints tips strategies links please let me know.
Kind regards,
Ged
