0 Members and 86 Guests are viewing this topic.
jbignes5
Quote from: MasterPlaster on May 15, 2012, 09:04:14 PM
You need to see this:
http://www.youtube.com/watch?v=44iT-wtj-o0
Thats exactly what I tried to say. Excellent experiment. You proved it. Now think of what kind of speed that thing will have when you resonate the entire coil with an electric field, intermittent shorts of the bifilar inductive/cap while in an exciter (electric bias field).
This guy also was using the prefered method of winding bifilar. The flat wound Inductacap is far superior to the elongated version like he was using. Using oil baths will Far outweigh anything we currently have.
Spark gaps are very very needed. We can shield them too based on grays patents. The metal around the gap was merely a static reflector with dampener built in. The dampener is the holes in the shielding. These openings filter the blasts and diffuse the concentrated wave coming off of the spark gap area. Carbon and silver being the target electrode. Silver was used because of it's particle size and that it was very conductive. Gold would show little wear if anything at all. The shield around the blast area is very important and is what causes the blast wave or excitation field. If a device was made to work in the open field the spark gap must be exposed with no shield. The blast wave hit the matter and excites it to a higher level/voltage. This is a bias wave. For brief sub seconds in time every pice of matter is intensely excited. Diodes will seem to spontaneously to light when the appropriate flow control is applied, redirection in this case is additional flow valves.
This system is all about creating field tensions and using them as an electric pump. The pump is actually condensed electric lines from our environment. This should allow a stream to form. This stream is densely packed with accumulated free lines. Those lines can increase the density of your field, growing in strength over time. It's sole job is to harvest lines and increase it's fractal nature. If we are moving at such speeds as they suggest, it's not a huge leap to say that, we couldn't harness all that speed. There are limits to this universe but our knowledge couldn't get a pure tap. If it could it would be a black hole. As matter gets soo dense the normal average laws get broken. Matter at that scale of a Black hole would be soo close together that the very space in between matter blurrs and becomes fuzzy. Infinite amounts of energy are created in the birth of a space or bubble and great forces are at play. The space expands at speeds that would seem to defy time. Waves emanate around the bubble and skins are formed, these waves are in the medium of that space. Reflection waves are very powerful if used to laser excite a field. At some time we will figure this polarization thing out. Polarizing is the key. It is what will allow us to bias the field in the direction we want.
Try this experiment next time you got some M and M peanuts. Sit in front of an led monitor. Pour the candy and look at the reflections and how the candy changes in color. Screen color and brightness all effect this polarized light. *tip* do this experiment at night. Having a monitor and incandescent light. Very interesting effects can be made even when both sources are mixed. Since light has polarity why cant a field? Shouldn't the same basic laws of light be based on the fundamental laws? Reflection seems to be the way to store potential. Like layden jars. And this brings me back to the video. That bifilar cap you got there can be charged and this is vital. Is there a field outside of the bifilar when charged? If there is then it can be harvested by modulating that field by excitation.
Like I said before it will take some time to ramp up this process, it will grow stronger. So you must design in the capability to sustain itself. If a house needs to be energized you would used some very big conductors for the pickup. To handle the pressure of the current. the reflector coil should be of very thin wires. This is to create the highest voltage field to reflect better. Remember that any coil has self induction but the bifilar doesn't. It's capacitance increases and not the self induction. So this means as the capacitance raises the shorting and unshorting of the capacitance gets stronger and stronger. The pulsation blasts and the rate of which you short and unshort the bifilar will also adjust buildup times for charges in the bifilar coil. Each pass of the blasts from element to reflector will bias the bifilar cap that much more. Lets say the field reflects 10,000 times a second. Thats 10,000 step charges to the bifilar coil receiver cap. Now lets do the same for 50,000 and 100,000 times? How about an infinite amount of times?> Magnetic quenched spark gap.
jbignes5
 Now lets see if you understand the antenna system as I have talked about. If you are not gonna use the TK system with two grounds you need a capacitance inductive hook up then with antennas. The thing about antennas is they radiate according to mass then geometry. If a mass is equal they are considered resonant no matter what shape they are. Resistance is just matter based. So having a resonant antenna system is mandatory. Second major fact is surface area. Same weight conductors but the gauge is the only difference give an advantage to the amount of surface area they present to each other. This can be designed into the system from the start and is why I want the intensifying effect you get from that antenna system. The bias is made through the special bifilar flat wound oil caps. These will have nil resistance to movement or fluctuations and will have extended ranges in both directions of capacity. This you can consider as the inertia or added intensity to the input of background noise or reflections.
The emitter and reflector coil I am now thinking should be pre oxidized aluminum???? <Experimental
The emitter coil can be called the exciter coil. This is the coil with the 1/4 wave doubling of the high current end. This will further squeeze the lines and draw in more in the same process. When the exciter coil has full wave capacity it will start intensifying the exciter field like a laser. With each pass pumping through the bifilar pickup coil in between the reflector and emitter or exciter coil. Shorting and unshorting of the bifilar will allow for buildup and discharge of the capacitor side of the bifilar coil. If you put the load in series with the bifilar coil it should drive the load at maximum efficiency and have plenty to spare for other electronics designed to work with this new system or transformed like Tesla suggested to use existing equipment.
cheappower2012
I'm aware of this effect,the capacity effect is new to me,
however I don't deal with
ferrite cores or many windings on bifilar coils I make.The points of my postings are to
prevent people from following into a certain pattern,the inventor is a hero,can't lie,wouldn't lie
wants you to build it
and its a Tesla  invention.People that run around hero worshiping someone are fools in my view.
This device has been obfuscated to prevent anyone from replicating it,the windings
in the back coil do nothing,TK did
this is to confuse anyone from duplicating this device.He hid the real operating
parts in the can object
in the 2004 video,so you can only go so far.You guys will have think about what
I post,there are  few people in here that have pet theories
and want there pet theories to be correct,however they ignore facts and operate on
hope or mystical explanations.
I am posting an alternate wiring of the 2004 video device,and go thru how I arrived at this.
First off in the 2004 video theres an old guy in a suit and is also seen
in the turkey video so I assume hes important,this maybe why theres a lot of fake outs in the 2004 video.The transistors
seen on the heat sinks appear to do nothing
only 2 wires are connected to each of the transistors,this I think is a fake out,as are the rectifiers,near the power transformer.
The rectifiers are very big indicating
they pass high current,however they have tiny wires connecting them to the can object an inconstancy.
There are 4 main wires that connect to the coils from the can object,theres a green wire connected to the big coil,carries High Voltage.
A gray wire coming from the can object is a ground.An orange wire from the can object is connected to the orange front coil,a yellow wire
goes thru the center of the coil form and connects to the back coil.One part of the orange coil comes around and under the big coil
forming the hot side of the ac,power is applied between the orange wire and ground wire,power comes from the power switch on the can object,the 220 vac is generated in the can object
the orange coil plays no part in the operation of the device its there to confuse,the back coil
is also unimportant,only the yellow wire going thru the center of the coil form and the big coil are important.
This is not a Tesla invention,only looks like it,anyway check it.
frantz
Quote from: cheappower2012 on May 17, 2012, 01:54:55 AM
Hi cheappower2012,
I would like to join to your theory.
In My opinion TK lying every time when can.
When we take your theory with limited number of coils, I see one or two solutions:
1. Theory: Maybe, when conductor (read coil) we put inside (HV) electrostatic field,
we will observe something like increasing the number of electrons inside conductor.
Why? Because we are supply the energy to the system (conductor) and electrons from lower layers of
conductor atoms going upper to the valence layer. In this case we have multiplied the number of valence electrons.
And in this case, when we will use the same (EM) force to generating AC current we will to have multiplied current,
because we have multiplied numbers of electrons.
This theory has one flaw. In my opinion, this electrostatic force is not negligible.
I think this force should to be tuned to the working coil. To low electrostatic field,
don't move electrons from lower layers.To high field will glue electrons to valence layer or
electrons will escape from the surface of conductor.
How should looks device, in my opinion?
3 coils (3 layers), if we count from the center of the coil:
a) HV coil for energizing (creating HV electrostatic field) main work coil,
b) Main work coil (connected to the load) - like output winding of power transformer,
c) modulation coil (coil which has to have double function),
first is a modulation f.ex. 50Hz, second is a second "plate" of HV "capacitor" which is grounded
(a. and c. is something like capacitor where inside we are put our work coil).
If you will look on this movie :
http://www.youtube.com/watch?v=lFiaBKW50yA&feature=player_embedded
and screenshot:
http://www.freeenergylt.narod2.ru/delamorto/KAPANADZE_COIL.jpg
You will see only 3 coils.
Frantz
cheappower2012
@frantz,I don't have a theory as to how the KT device extracts energy
and transfers the energy to the electron flow.I believe that KT discovered
an unknown effect,SM of the tpu also discovered this same effect,the KT device
is a continuous power device,the tpu is a pulse operation device and uses a different field disruption method.Because the KT device needs
the arc discharge to create a disruption field,( EM field) it would not be a good device
except in shielded applications.Because KT hid a lot of details its going to be very hard
to figure out.I will post a few things related to the operation that maybe helpfull.
TK is a tricky guy,in the video there is no spark gap visible but there has to be to work,you need a coil with
a wire going thru it,current is flowing thru the wire at the same time,the wire is being subjected to the em blast from the coil.
In the end the other things needed to build the TK device are going to be shown to be simple ,sooner or later this is going to be figured out.
You guys need to think simple not overly complicate things,remember this a new principle that has not existed before,not a Tesla thing.
