0 Members and 151 Guests are viewing this topic.
Zeitmaschine
Greetings!
Having burned out my equipment during test runs a few days ago, I had a little spare time left (till replacement arrives) to think about what went wrong.
So in the meantime I have commented some still frames taken from Kapanadze (and related) videos circulating on YouTube and summarized them in a pdf document.
https://rapidshare.com/files/3571314754/Commented_video_frames_regarding_the_Kapanadze_device.pdf
Reading along this thread intensively since weeks, I would suggest anyway to rerail this thread and return it to square one in order to figure out which important facts have since been overlooked (some with the kind help of numerous distractors, I presume). I think the tin can video was recorded by chance, hence there are no fakes in it only incidentally hidden parts.
Besides, free energy for all at the end of this year (with over than a century delay) might surely have the potential to fulfill the Mayan Prophecy that »2012 is bringing the end of the world as we know it« - at least for some unlucky energy companies, unless ... this device has the ability to manipulate (if not disrupt) the space-time continuum when used too excessively ... then of course ... »the end of the world as we know it« could be an even more all-embracing event. If somehow this device borrows energy from the future (converting time into energy), then at some point there will be no energy left to create the future (the course of time slows down increasingly, Terence McKenna's theories). What is energy? Energy is the ability to change something. What is time? A chronicle of changes. Therefore energy equals time and time equals energy. And maybe the reason this technology of free energy has been suppressed up to the present day is not only due to money. So, I will let myself be surprised (but maybe I have just watched too much Star Trek).
So long and happy experimenting! (and don't worry about creating a black hole during testing)
P.S.: Anyone has tried this coil layout yet?
jbignes5
 That was using all very near fields as well. If you stretched out the distance of the coils it would Tune it as well. The closer you are the higher the energizing field would be. This means the bifilar Load coil should be placed on top of the energizing HV coil. Then the reflector coils could be moved in and out in some fashion.
I was thinking a little more on mater. To be exact the finite details. I was looking and thinking about scales and that fractals represent at almost all scales. The pattern repeats hence the fractal name. Check the picture out. Nature is so wonderful. The seeds are in a static grouping and the lines come out of the static space. They then terminate in a flowering of even smaller fingers. The skin effect looks to be something more specific. Do you see how clear the center is when compared with how you view the object or what angle.
If you look you will see the skin is actually dimpled. This is how it can move at the speeds it does. Lik a golf ball this bundle of charge is accelerating just enough to stay charged.
Awhile ago I tried to describe mater on it's finite detail and I though the mater was scale like. Boy was I wrong. It is seed like. and they group together through static induction. As the flakes get more mass they charge up and the field grows. Each piece of mater adds to the whole. The frequency is the fluttering of the space in between mater and this is radiated by the fingers coming off of the maters epicenter. In order to facilitate the information to the matter lines form and great networks are built and broadcasting of obect information is ensued. This network has rules. Some of which can be adjusted through excitation or bias of the mater itself. This increases the lines for more information to be transmitted by those lines. Information can also be current.
I think the electron could be applied to this model with the Dandelion. think of a closed set of fingers around the skin. Charge level could be based on how many closed sets compared to how many open sets you have. If you find a way to increase the density of the skin are you not increasing it's base level of information available? It would have a higher ability to pass charge and interface with the network. A standing value of metal in our space (near earth) is because of the standing electric field of that near field. If we increase the field, does it not increase the metals value?
This can be changed now to our planet. The very high voltage field looks exactly as shown. The radial connections hold the atmosphere to us by this skin of finer fingers. These sprays, Skin fingers, are coincidentally in a certain shape. The fingers radially go out to the sprays. The radial lines are the reason for our big storms, tornadoes, and hurricanes. Most geological events will fall under this category. In aeronautics this is the wind shear reported. It's a fluctuation in the potential caused by the fingers potential. The fingers can be seen best in high heat near field views. What this event is, is a polarization of space by the angle of the view. It will bend vision very easily because the lines are not so taught. The heat has expanded the lines and it flows or is pliable around the surface easily from side to side of the surface. We see this layering effect in density changes. Condensation seems to happen as the density goes down. This causes higher concentrations of the mater of that density to fall back down twords the higher charge. Lava lamps are so cool...
Hmm... http://www.youtube.com/watch?v=xir670oorIo
I thought this was interesting also. Possibly related?
http://www.youtube.com/watch?v=0XQlnsF3fGw&feature=related
sadang
And what if the electron does not exists as we know today? What if the electron is just a compound of other more smaller particles, that all these, bended together, make the electron to appear like a solid particle for us, or for our understandings? What if we experience just the effects of the dynamics of all these small particles that compose the electron? What if in specific experiments this dynamic conglomerate called electron, due to its specific dynamics, give the characteristics of a particle, and in other experiments due to the same specific dynamics give the characteristics of wave? What if, what is above is the same with what is bellow, and vice versa? Just like in a fractal, and in an exponential multiplication of the same pattern?
On the other hand, there is a certainty, that at Cavendish Laboratories, Mr. J.J. Thomson made the right initial setup of the cathode ray tube, in experiments number two and three, and also, he made the right interpretation of the obtained results? Just simple rhetorical questions!
An electron in motion:
- http://discovermagazine.com/2009/jan/070
FreeEnergyInfo
Shokac
Quote from: cheappower2012 on May 17, 2012, 01:54:55 AM
I'm aware of this effect,the capacity effect is new to me,
however I don't deal with
ferrite cores or many windings on bifilar coils I make.The points of my postings are to
prevent people from following into a certain pattern,the inventor is a hero,can't lie,wouldn't lie
wants you to build it
and its a Tesla  invention.People that run around hero worshiping someone are fools in my view.
This device has been obfuscated to prevent anyone from replicating it,the windings
in the back coil do nothing,TK did
this is to confuse anyone from duplicating this device.He hid the real operating
parts in the can object
in the 2004 video,so you can only go so far.You guys will have think about what
I post,there are  few people in here that have pet theories
and want there pet theories to be correct,however they ignore facts and operate on
hope or mystical explanations.
I am posting an alternate wiring of the 2004 video device,and go thru how I arrived at this.
First off in the 2004 video theres an old guy in a suit and is also seen
in the turkey video so I assume hes important,this maybe why theres a lot of fake outs in the 2004 video.The transistors
seen on the heat sinks appear to do nothing
only 2 wires are connected to each of the transistors,this I think is a fake out,as are the rectifiers,near the power transformer.
The rectifiers are very big indicating
they pass high current,however they have tiny wires connecting them to the can object an inconstancy.
There are 4 main wires that connect to the coils from the can object,theres a green wire connected to the big coil,carries High Voltage.
A gray wire coming from the can object is a ground.An orange wire from the can object is connected to the orange front coil,a yellow wire
goes thru the center of the coil form and connects to the back coil.One part of the orange coil comes around and under the big coil
forming the hot side of the ac,power is applied between the orange wire and ground wire,power comes from the power switch on the can object,the 220 vac is generated in the can object
the orange coil plays no part in the operation of the device its there to confuse,the back coil
is also unimportant,only the yellow wire going thru the center of the coil form and the big coil are important.
This is not a Tesla invention,only looks like it,anyway check it.
This is good approach!
If look TK pattent, and you will see that between HV coil and 220V coil have two element. This element sinhronization electromagnetic wave between HV and LV coil..
I thing that is condenser and spark (arresters)
