0 Members and 83 Guests are viewing this topic.
stivep
Quote from: jbignes5 on May 18, 2012, 06:35:43 PM
one wire has been cut as well... Center of devices.
I bet there is a high voltage version as well, they are called 3 phase shunt capacitors.
So look at that:
http://www.ebay.com/itm/180848795685?var=480089016066&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2648#ht_2394wt_1139
and that:
Wesley
forest
here is IMPORTANT question :
what is inside those igniters ? could we assume this is just replacement of disruptive discharge of capacitor in single compact box ?!!!!!!!!
that would be FABULOUS help  ;D
energia9
writing this in here might not be relevant, but those of you who have seen this or understand what is going in here can you explain..
Is this Andrey melnichenko guys work for real?
it seems that his lightbulb at the output side shines more than at the input side of the transformer..
is there a good explanation for this?
http://www.youtube.com/watch?v=TT9ynJ2_6Ng
in my theory, that if someone could even achieve 105% efficiency at the output of a transformer, and 4% percent would be eaten by the wires that connects back to itself,  it would self run with that 101%,  because  there would be a gain at every pulse.
what do you think...
jbignes5
Quote from: stivep on May 18, 2012, 11:21:22 PM
So look at that:
and that:
Wesley
Come on Wesley you really think they are ignihters or whatever? Even with the description of what the bank is for? Also I found out why the wire was cut in the foreground cap. The first item to be tested was a motor if I'm not mistaken. Then the motor was taken off and lights were affixed to the whole thing. If you read the description of the shunt bank it will tell you that you need to change the bank of caps to match the load. Since the first load was a 3 phase motor it drew considerable juice. When they swapped the load to lights only they had to change the caps connections to match the load.
I wouldn't expect regular people to know what the shunt bank is for. That is a powerman forte. It seems there is stuff out there that will work we just have to find the niche. Most of those caps are oil based so they know the benefit of using oil to extend the life of the cap and make them self healing. Now onto the transformer.
