anandml
I think he is using power transistors instead of junction diodes. Two pins from both transistors and two junction diodes and a filter capacitor needs to form a bridge rectifier circuit for producing HV DC supply. In green box video we can able to see one junction diode. pls excuse me if my assumption is wrong
verpies
Quote from: jbignes5 on May 19, 2012, 09:56:08 AM
Yup and I don't see you building one do I?  There is a reason these developers build and we don't.
You don't see me building it because of other reasons than trepidations. The reasons we don't build these Yoke devices is:
1) No access to exotic vintage ferrimagnetic core from russian TV sets.
2) Lack of needed information.
   a) Unwillingnes of the inventors to make simple clarifications to tunning instructions, see: Reply #9509
    b) The possibility that Baroutologos' explanation of the author's unwillingness to help is correct.
There are inherent dangers from that process. They even regulate who can go on the premises.
So your argument is not valid.
What argument?
My two points listed above and the fact that the inventors did not make any effort to mitigate the dangers of the apparently working OU device cut off any discussion of the Yoke ustrojstvo, are unwilling to clarify anything more to others and hide behind unconfirmed dangers, make their inactions suspect.
Instead the authors and this thread has been rumbling about unremarkable sparking tubular devices for months (200 pages), and nobody has made a single valid and interesting In / Out power measurement out of them yet.
Yeah, I know HV Tesla coils and similar tubular devices are pretty, educational i nice to play with, yet difficult to measure...  but what of them?
There are many nicer toys in this world that consume more energy than they provide!
jbignes5
I started to look again at the patent that Tesla released as an improvement to the ac system.
Link: http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
Notes are on attached picture.
Also note that the prime mover coils must be of the design Tesla specified in order to work. The toroid I drew was incorrect and should be the pole style of motor that Tesla shows here in this picture.
energia9
I would like to question the same thing as Verpies Too!
- who ever did a proper measurement of the input vs output?
- I guess Aidas played with the yoke device for hours and hours, did he get health problems??
- Did someone had a Geiger counter and confirmed radiation bigger than the background?
- did the Yoke heated up excessively?
- The radiation counter might have been tricked by high voltage?
- what is the type of radiation meter that was used?
- Any form of data available?
this is not provoking!
This would help all...
btw if energy was gained as said,
that means  if you mix needed frequencies , any kind of material could be made to release particles.
so we could confirm all these with the simplest ways,
we could make several cheap oscillators from cheap IC's
any cheap IC which we can produce several mhz with would do it.
