0 Members and 66 Guests are viewing this topic.
grizli
Quote from: xenomorphlabs on March 30, 2010, 06:48:18 PM
The one million dollar question is : "At what frequency (Fres) will you run it?"
To get into the wavelength range of the bifilar you would have to go into the high MHz range.
I REALLY dont see that bifilar has to have frequency related to wavelength !!
Firt imput TC has to have THATS ALL
in Turkish vide TC has tiny wire , but bifilar coil tube has thick wire= bifilar coil tube has nothing to do with quater wave, all in all at next energy ru SR said its NOT classic TC
Feeder for bifilar is CLASSIC TC with wuarter wave for wire length .. all other is NOT TC...
In the last page video pictures you can also see  man core with thick wire and TC with THIN wire
QuoteNowhere in the diagram is a metal pipe mentioned ?!
WHATS than on the last page ,, bifilar i wound on metal tube ...  and METAL TUBE itself is conductor that goes to REAL earth !!! is not ?
grizli
Quote from: baroutologos on March 30, 2010, 06:49:42 PM
@Grizly,
Kacher schematics are all over the place. Mine were given courtesy to rutube user destine, the one that utilized a PNP 2SA1943 transistor runnign at 25 volts. and consuming some 70 watts.
In any case, since one and a half year i have being making devices from noob ones to a little more better build setups. I have spent in 1 1/2 year more that 5.000 USD in making mechanical as well as electrical devices.
What i want to say is that: sitting and theorizing is easy. Getting your hands dirty is another story of its own.
Sometimes i can feel people who have struggled to make things (and are reluctunt to share) while others sit and talking and talking and do nothing at all. Experimenting has a high cost. And if all experimenting is being done by a few, then the cost (and the odds) are overwhelming against them
I also have his svhematics
the are many of them..there is NO point for me to waste money on burning transistors if you can tell me right schematics and tuning ..but ok never mind...
yes, believe it or not I also REALLY do make experiment but NOT spend so much money cus I dont  have so much money to spend ..
xenomorphlabs
Quote from: grizli on March 30, 2010, 07:06:57 PM
Question to you then:
Of what nature do you think is the resonance then between the TC on the left and the bifilar coil? SR says it is NO parametric resonance.
You say :
QuoteFeeder for bifilar is CLASSIC TC with wuarter wave for wire length
So is your wuarter wave something else than a quarter wavelength?
Please explain, i might misunderstand.
grizli
Quote from: xenomorphlabs on March 30, 2010, 07:14:05 PM
You say :
First of all SORRY for typos  , I made them lot and often lazy to recheck spelling!
Yes its quarter..
Left classic TC which is tuned to 1/4 wave obviously give peak of voltage at the top of TC.
If we have bifilar which magnetic field is in opposite direction MAYBE  there is NO current going through that coil by itself and if we presume that current does not go in great amount (we are not sure we have to test) than resonance of first TC is not AFFECTED .
On the other hand bifilar coil at certain frequency could act JUST LIKE capacitor (cause magnet field is canceled) if so than it is PART of whole process and its capacity is part of first coil resonance and number of turns of first TC must be calculated acordingly.
So wet I can see from Tariel videos :
TC use TINY wire
bifilar coil use thick wire
bifilar coil is wound on METAL tube (probably aluminum )(thick black conductor on schematics)
Problem is I can not afford scope right now (i am student) to check all that , but I am going to make variable oil capacitor and try to tune and wee whats going on..
With scope I would not have to claculate values of TC, all on all I have never seen mathematics that can be sure about TC resonance frequency, but link above is up to date to newest "dsicoveris" and is probably 99% accurate..
grizli
ALL in ALL
EVERY coil acts as capacitor at frequency higher than natural LC frequency ; MAYBE biffilar with cancleing magnetic fluxes acts as CAPACITOR at much lower frequency !!!!  I am somehow SURE it could be the case here: SO we do not need much turns, and this coils can be part of "C" in the equasion of LC resonance of left side TC
