stivep
Quote from: jbignes5 on May 19, 2012, 08:36:33 AM
Come on Wesley you really think they are ignihters or whatever? Even with the description of what the bank is for? Also I found out why the wire was cut in the foreground cap. The first item to be tested was a motor if I'm not mistaken. Then the motor was taken off and lights were affixed to the whole thing. If you read the description of the shunt bank it will tell you that you need to change the bank of caps to match the load. Since the first load was a 3 phase motor it drew considerable juice. When they swapped the load to lights only they had to change the caps connections to match the load.
I wouldn't expect regular people to know what the shunt bank is for. That is a powerman forte. It seems there is stuff out there that will work we just have to find the niche. Most of those caps are oil based so they know the benefit of using oil to extend the life of the cap and make them self healing. Now onto the transformer.
First  answer the question:
Tent presentation
Where  you see or you think  you might locate presence of interrupters= any form of impulse forming devices such as spark gaps, electronic switches and so on  knowing that   it must withhold such load?
Second answer the question:
Do you agree or you disagree that motor in tent presentation serves  as asinchronic generator for 3 phase.
Yes or No?
and support  your statement.
Third answer the question:
If take for a moment  that  your statement is false  and you just want to analyze what if Wesley is right than:
How would you support presence of ingitors?
Than we go deeper with your " come on story"
Wesley
verpies
Quote from: energia9 on May 19, 2012, 11:08:21 AM
- who ever did a proper measurement of the input vs output?
Reply #10266 contains answers to these questions.
- I guess Aidas played with the yoke device for hours and hours, did he get health problems??
I don't remeber any complaints from him.
- Did someone had a Geiger counter and confirmed radiation bigger than the background?
Nobody ever wrote about measuring the beta or gamma radiation, however headache can be also caused by high-amplitude ultrasound from magnetostriction acoustic waves, which a ferrimagnetic core is prone to.
- did the Yoke heated up excessively?
A little, but not excessively.
this is not provoking!
This would help all...
I think so too. I have never asked my questions in rude or hostility provoking manner.  I tried to clarify the tunning istructions in Reply #9509 for the benefit of all.
btw if energy was gained as said,
that means  if you mix needed frequencies , any kind of material could be made to release particles.
Maybe not any material but certain class of materials.  The chemical composition of the core and its crystallographic structure most likely is essential for the functioning of the Yoke device. Perhaps its conical shape is too
so we could confirm all these with the simplest ways,
we could make several cheap oscillators from cheap IC's
any cheap IC which we can produce several mhz with would do it.
Yes, once the operating principles are identified, an application specific signal generator and analog amplifiers/drivers can be constructed cheaply.
energia9
what about Copper Verpies?
T-1000
Quote from: verpies on May 19, 2012, 10:34:03 AM
You don't see me building it because of other reasons than trepidations. The reasons we don't build these Yoke devices is:
1) No access to exotic vintage ferrimagnetic core from russian TV sets.
2) Lack of needed information.
   a) Unwillingnes of the inventors to make simple clarifications to tunning instructions, see: Reply #9509
    b) The possibility that Baroutologos' explanation of the author's unwillingness to help is correct.
What argument?
My two points listed above and the fact that the inventors did not make any effort to mitigate the dangers of the apparently working OU device cut off any discussion of the Yoke ustrojstvo, are unwilling to clarify anything more to others and hide behind unconfirmed dangers, make their inactions suspect.
Instead the authors and this thread has been rumbling about unremarkable sparking tubular devices for months (200 pages), and nobody has made a single valid and interesting In / Out power measurement out of them yet.
Yeah, I know HV Tesla coils and similar tubular devices are pretty, educational i nice to play with, yet difficult to measure...  but what of them?
There are many nicer toys in this world that consume more energy than they provide!
Please see http://www.overunity.com/4333/meyer-mace-isotopic-nmr-generator/
http://www.e-catworld.com/2012/04/english-translation-of-build-instructions-for-pirelli-athanor-cell/
Also in http://www.drjudywood.com/pdf/050521_EVOsHutchisonEffect.pdf
They all are describing same process just approach is different.
Question for you: do you have proper equipment to stay safe and find out what is radiated? And how many people have it?
verpies
Quote from: T-1000 on May 19, 2012, 12:54:56 PM
Yes, neutron, beta and gamma, X-ray detectors.
Ultrasonic microphones up to 3.5MHz.
For safety I would use distance since simple shielding might be ineffective.
