0 Members and 490 Guests are viewing this topic.
jbignes5
Quote from: verpies on May 22, 2012, 11:33:14 AM
Without the ferromanetic core it will be a completely different device. Neither the Mag Amp nor the Saturable Reactor nor the Yoke device nor the Annis Eberly device.
NMR is still possible in air or wood, albeit at different frequencies.  Without a ferromagnetic core an eventual ferroresonance is definitely gone.  I dont understand the phrase "polar bifilar". Standalone "bifilar" winding is understandable. Also, what are the "positiive" and "negative" entities being separated?  Ions?
What are the T1 and T2 terminals in Fig.3 ?  Are they the ends of windings?  Where are the beginnings of those two windings? Is the gray/dark t1 element an insulation material of the T1 terminal?
The hysteresis loss in modern ferromagnetic materials is small (e.g.: 4W/kg @ 100kHz for Nanoperm) but if the core was eliminated then it would be nonexistent, of course.  I do not know if it is possible to simulate the ferromagnetic core without superconducting current loops.
Why would it be different. All we would need to do is substitute the core for a self terminated coil toroid. It should act the same as steel in a toroid or any magnetic material.
The description I linked to tells all about that transformer and the variations of said unit.
http://www.tfcbooks.com/tesla/1892-02-03.htm
Don't you understand that we are not gonna be working with current at all. Well as little as we can make it. This is part of the high voltage side of things. Reducing the current reduces the waste and is mostly the reason why voltage raises in the first place in this system. Current products are the whole reason why we are in this boat. They even sell it by your current use. And our whole science is based off of current or the electron. These are a fallacy to encourage them to not look at this other side that has been thought of as a novelty and not something useful.
If I'm correct then the whole Universe runs off of just the voltage potential and where there is a conversion you get the effects of that conversion to current. Mainly heat or radiations. This usually entails matter. But as Tesla figured out the transmitting part is purely voltage based and intensity is one of the components of voltage.
Another thing is why do they have to short out caps when not in use? Aha! They charge from the surrounding environment all by themselves. Well this is exactly what I am talking about with the antenna system as well. Voltage in that respect likes or attracts other less voltages. Stray voltages are present and all around us and can be collected very easily if you give it a place to attract to. Other wise why would they need to short the caps then when not in use?
There are two different kinds of bifilar coils. One that is integrated, two wires side by side wrapped in a coil and another kind that separates the polar fields by the turn direction of the coil. If you look at the transformer in figure 3 the separate coils wound around the wood is the polar version or can be in that figure because of each coil having it's wires brought out of the case. If you were to take each coil and flip one coil they both would be wound in the same direction. This does two things. It creates a bucking field and it orients the fields for the secondaries to take off in opposite tuned coils. With one polarity becoming two via the wind direction. One will be positive and the other will be negative constantly all from the same pulse or train of pulses.
Bifilar coils have no self induction and an enhanced capacity via this technique. So no real increase in the voltage being applied will happen in the coils but that also means electric pulses can flow quicker in them. Separating the bifilar coils change that I believe but I haven't gone that far in the theory behind it yet.
verpies
Quote from: jbignes5 on May 22, 2012, 11:59:59 AM
Because a self-terminated coil toroid, does not have the non-linear BH characteristic that is essential for the operation of a Mag Amp, Saturable Reactor and other devices using flux switching.
Also, any current induced in a shorted coil, rapidly decays if the coil is not superconducting.
Magnetic fields cannot be created without electric current (from moving charges or aligned atomic spins).
No, a self-terminated coil will oppose any external magnetic field like a decaying diamagnetic, however a ferromagnetic material will aid the external magnetic field (without decay).
Also shorted coils need to be precharged with current in order to create magnetic field but the atomic currents in ferromagnetics are perpetualy recharged by mother nature.
jbignes5
Quote from: verpies on May 22, 2012, 12:26:01 PM
It was merely a suggestion. Tesla says to do away with the magnetic and only work with the electric field. Do you remember the work with exciters done on here? The fields can be extensive even with low levels of voltage.
http://www.youtube.com/watch?v=2XrO34Wt21c&feature=endscreen&NR=1
verpies
Quote from: jbignes5 on May 22, 2012, 12:57:45 PM
Electric devices can be built without strong reliance on the magnetic phenomena.  The standard 9V battery can be used to supply a quarter-wave helical transmission-line resonator with a small magnetic stimulus at one end that will create an electric standing wave at high VSWR, having VMAX at the other end of the winding.  The built up electric field will be capable of lighting fluorescent light bulbs at a distance and remotely charging capacitors with antenas attached.  The voltages induced in this manner are not affected by resistance very much. RI^2 losses are minimal
...but how to get OU efficiency out of these spectacular E-Fields, though ?  No perpetual atomic Bohr Magnetons to help out... :(
jbignes5
 Well this is what I have been saying all along. Try watching Eric Dollard to explain the system. also remember this wasn't tuned and not fully implimented right but they still got very impressive results.
http://www.youtube.com/watch?feature=endscreen&NR=1&v=Y4m82cvThd8
They even address why this has sat there with no investigation of the process. No one was willing to build the devices because they didn't see any worth in the system. That means no income means no interest. We need to change this now while we can!
I fully believe TK used this system and learned how to increase the results. He could use the system as a stand alone AC power source or rectify it and use it to feed itself once started. Or even do all of those things while running a ac load.
