0 Members and 27 Guests are viewing this topic.
sparks
    Telsa produced electrical sound waves.  Longitudinal waves in the scalar potential of Earth and atmosphere.  The terminals of the magnifying transmitter alternately are pumped and relaxed using dc impulses.  This is done at a very low rate of repetition to avoid em radiation.  The terminals increase and decrease in charge magnitude in response to the electrostatic induction of the primary into the secondary.  He discovered longitudinal waves messing around with dead shorting large dc dynamos.  Finally developing the Tesla transformer so that the greatest charge seperation is experienced on the terminations of the coil of highselfinduction.  These terminals were then modified so that there were no coronal discharges (power loss and dangerous)  The terminals were alternately pumped and relaxed with charge.  This in effect enlarges and deflates the electrical size of the terminals.  This causes compression and rareification of the scalar potential.  Very unique setup.  Now comes the interesting part.  He stated that his magnifying transmitter was going to produce a maximum activity of 10megawatts.  He was reluctant to disclose where he was going to get 10megawatts or twice the power of niagra falls from.  To my knowlege Wardenclyffe included no plans for a 10megawatt power plant to be built.  He just stated in this particular letter that he would employ certain artifaces that he would disclose at a latter time.
Anyone know what these artifaces were?.  I'm sure that the equipment building in New Jersey didn't house a 10megawatt steam driven generator.  I dont think they had the teck to make them that big back then.  I don't think the entire grid at that point had 10megawatt capacity.  What was the genious going to power the MT with?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jbignes5
 Good question. Welp lets see what he looked at already. He knew that the upper strata had a huge potential associated with it when compared to the ground right?  Well he also knew or realized that there is an existing grid of lines already emanating from our planet connecting the upper strata with the lower ground. This is via the atmosphere.
Ok first lets look at antennas.
If a 1/4 wavelength element is coiled up like a spring, a very compact antenna can be made that still has
reasonable efficiency. Some experimentation may be required to find resonance, because the length of the
wire is not exactly related to a 1/4 wavelength. This type of antenna is very popular at lower frequencies.
Fyi Tesla was looking into the problem of DC generators that upon switch closure would surge and shoot a blue fire out all the lines and also kill anyone close enough to the wires. This is what Tesla was doing for Edison while working for him on his DC system.  It was no accident that Tesla was investigating this phenomena.
Whenever Tesla talked about output he talked in terms of horsepower and not Watts.. He said Niagra falls was built to supply 40,000 horse power so I don't know what you are talking about there. In fact Tesla said his system was designed to handle 25 million horsepower. Way beyond what Niagra falls was capable of producing at max output. Thats where the magnifying part comes from. If you charge the antenna/ground system to energize the near field of this ball we live on you can understand how he could do this. His system was a very brilliant way to allow anyone and anything to utilize this setup if they had the right tuning to the main system. I firmly believe that you would not need a size of an antenna like he used at the plant to receive this energy. Hence the focusing ability to magnify the surrounding charge level of the near field of earth and using smaller antennas to receive with while attached to the ground on one end. A virtual ground could also be used with less power coming from it as well. A virtual ground could be the shell of a car or any metal that is parallel to the ground but not connected to the ground.
I suspect that the whole system could be virtualized to ground or trough the car's body as a conductor. So all one needed to do is create the imbalance between the center coil and antenna and the receiver antenna. This will focus or magnify the voltage and hence after cap and transformer be reduced into real current. I also suspect this process turns the on and off voltages to form AC in coils which then can be converted to full DC and not pulsed DC by the transformer. This uses the common pulsed dc to create an AC output.
As I have said before Do not use low frequencies with this stuff. It is the reason why linemen and generator operators were dropping dead on the DC system of Edison's. Think of the pulse wave at 1 cycle, it is the same process we use for starting a stopped heart and coincidentally stopping one. Tesla did extensive tests and found the low frequencies were destructive to matter, even biological matter. Frequencies of over 2k produce various effects on matter including the atmosphere. The higher you go the better and safer it is.
You could think of it like the old magicians trick of pulling the table cloth off of the table without moving anything that was on it. The faster you pull(pulse) the less effect on the items depending on the mass of the items on the tablecloth. But to the contrary the faster you pulse the density of lines becomes increased. This has another benefit as well and thats the feeling of well being. This is because your matter has more connection to the environment and coincidentally more energy available for use.
verpies
Quote from: sparks on May 22, 2012, 02:30:46 PM
The genius took that secret to his grave. Perhaps he was planning to build a huge power plant using the potential difference between Van Allen belts and the Earth.
Pondering this does not bring anyone any closer to making a tabletop OU device.
For this concrete engineering details are needed - not loose thinking.
jbignes5
Quote from: verpies on May 22, 2012, 03:59:28 PM
So wait, let me get this straight. It hasn't worked with the traditional style. IE the one that has been predominant for well over 100 years. In fact it has been 112 years to be exact. If the best minds in the world can not figure out whats going on and get an advantage by now then they obviously have failed to grasp the finer details. Constants are one thing in nature and fractals for that fact. One constant is that energy likes to form in spheres. With the center having higher potential. Take a circle and put a dot in the center. What don't know the center? Draw two lines in 1/4 fasion and walla center is the crossing. But keep filling in the lines to certain densities. each line is a perfect half and half with either all pointing in (potential) or all pointing out or any mix in between. Ok thats the internal field now for the outer field. The outer field is composed of the same lines but extended far beyond the inner lines length. This is because the potential from around it is focused into the interiors space. The exterior lines are flexible but springy. With the higher internal potentials dictating the strength of the external fingers. The circle is made of little wedges of matter that are statically attracted to each other. Whats in between the matter flakes is our concern here. The field creates a network both inside and outside of the matter. Thinking of that now ponder the density of our network we live on. Our planet is kinda unique. At least until we hear another world like ours. We are shooting signals through space and others can hear it.
This focusing is a constant. You must focus it and draw more lines in to access more power. Matter is just a temporary collection of lines bound by that matter. The lines are the reason we can charge matter. There are all kinds of lines. Free lines have ambient charge on them and they have no real direction. When we add a source of electric lines it gives them order.
sparks
Tesla wrote:  "The first of these central plants would have been already completed had it not been for unforeseen delays which, fortunately, have nothing to do with its purely technical features.  But this loss of time, while vexatious, may, after all, prove to be a blessing in disguise.  The best design of which I know has been adopted, and the transmitter will emit a wave complex of total maximum activity of ten million horse-power, one per cent. of which is amply sufficient to "girdle the globe." This enormous rate of energy delivery, approximately twice that of the combined falls of Niagara, is obtainable only by the use of certain artifices, which I shall make known in due course."
Think Legacy
Spread the Love
