0 Members and 28 Guests are viewing this topic.
jbignes5
dole
Hi,
Text in the Tesla document Tariel K. holding in the hand at the end of “green box” demonstration:
I have been asked by the ELECTRICAL EXPERIMENTER to be quite explicit on this subject so that my young friends among the readers of the magazine will clearly understand the construction and operation of my "Magnifying Transmitter" and the purposes for which it is intended. Well, then, in the first place, it is a resonant transformer with a secondary in which the parts, charged to a high potential, are of considerable area and arranged in space along ideal enveloping surfaces of very large radii of curvature, and at proper distances from one another thereby insuring a small electric surface density everywhere so that no leak can occur even if the conductor is bare. It is suitable for any frequency, from a few to many thousands of cycles per second, and can be used in the production of currents of tremendous volume and moderate pressure, or of smaller amperage and immense electromotive force. The maximum electric tension is merely dependent on the curvature of the surfaces on which the charged elements are situated and the area of the latter.
"Judging from my past experience, as much as 100,000,000 volts are perfectly practicable. On the other hand currents of many thousands of amperes may be obtained in the antenna. A plant of but very moderate dimensions is required for such performances. Theoretically, a terminal of less than 90 feet in diameter is sufficient to develop an electromotive force of that magnitude while for antenna currents of from 2,000-4,000 amperes at the usual frequencies it need not be larger than 30 feet in diameter. (TK scaled down to 100kW and 5kW)
Ps. Tesla mention earlier in the document that it was not thin wire secondary and it was not many turns not close wounded.
Since we entering a circle from the beginning one more time I would like to share some good historical documentation (apologize to those which studded this long time ago)
http://www.kathodos.com/teslasaid.pdf
Download link seams very slow but is worth waiting if you did not read it before, at least little bit from page 46
Xd.
verpies
Quote from: T-1000 on May 23, 2012, 11:14:55 AM
Quote from: verpies on May 22, 2012, 11:10:53 AM
Did the Yoke device, made by your hands, work with <10W of input power and >20W of output power?
Yes, you share more details than others.
However, you don't share everything needed for replication.  For example, see the missing red info in these replication instructions,  - for instance in pt.8.
@verpies
In regards to yoke device you need to understand NMR conditioning process. It is not possible to make 1:1 copy. We shared much as we could.
There are also already different patents on subject I mentioned in another post and ours is close to them: 2 main frequencies, one is magnetizing, another is core material resonant and magnetizing frequency governs transformation method. Simple as that for this process and even for making Tesla ball lightning... It is only one root principle.
I still haven't gotten a direct answer to my question and pt.8 still remains unclarified :(
Also, what is your physical evidence that the NMR phenomenon or Fe isotope transmutation was even happening in the Yoke device ?   Contents of third-party patents do not constitute such evidence and alternative explanations also exist.
