0 Members and 138 Guests are viewing this topic.
jbignes5
 We are going from real experiments. Look at the dudes video's there just posted.. But along with the real work comes the how does this work without our input.... It takes a good strong understanding of what we can measure. But there are always gonna be the unknowns or not explained yet. Including the uncanny scales and how they look similar but yet vast distances are measured. It's a pattern. It's life and we can control it. Getting control of the machine is the first angle of attack. That control we collectively have access to is called Us. We allow them to dictate what is right and what is wrong even if the facts show otherwise.
This is the time of awakening. We are opening our eyes and everyday we are astonished at what we can see and is also available online. From reasonable sources.
Listen do you actually think that the visible world is all thats exists? Our eyes and senses see very little of the available spectrum of totally available spectrum.
All of these people who have near death experiences tell of as white light or tunnel vision with white. Well what does a baby see when it emerges from his mother? We are baby gods growing into sentient beings. Hopefully with wisdom and compassion as a major trait.
We need everyone to help and not shun anything that reasonably explains things. Thats what we are here for.
Zeitmaschine
Quote from: jbignes5 on May 25, 2012, 10:29:58 AM
A traditional Tesla coil (see photo).
Rhetorical question to this: Is the output power (sparks, light and heat created by the secondary coil) lower than the input power (supplied to the primary coil), is it equal, or is it higher?
If someone has a definite answer to that question, then the next question arises: How do we know this for sure? How is this measured?
jbignes5
Quote from: Zeitmaschine on May 25, 2012, 11:20:37 AM
Well in my regards that thing is only a sink of potential. The sparks are going from outer to inner as you can see from the intensity of the streamers. They flow inwards after the electrical field forms around it. Like in nature when you give water a soft base it tends to form condensations between flows and rivers will swell in certain areas and bulge in others but they tend to concentrate as they continue. This is the same process. So the electric field gets biased on and allows the free energy to flow inward twords the source potential. This is the ultimate Vacuum. A static potential Vacuum. And it is lined based. As seen in the picture from the previous post.
woopy
Hi all
As everybody post every ideas which can perahps be usefull to this huge amount of mixed ideas
i propose to you some update of my work
hope this helps
good luck at all ;)
Laurent
http://youtu.be/tLB-eqsJzKk
Magluvin
Quote from: woopy on May 25, 2012, 05:40:21 PM
Hi all
hope this helps
good luck at all ;)
Laurent
Hey Woopy
Ive seen some out there that use the center HV output connected to another spark coil, of the same brand and model, and they get good output from the + and - of the second coil. I wonder if you did this if you could rectify the output of the second coil to charge the battery.  ;]
Start at page 96. Using the same spark coils is important. ;]
Mags
