0 Members and 381 Guests are viewing this topic.
Zeitmaschine
Current coming from a ground wire in the manner of the TK video's is impossible
Is it? Found this buried on p.59 and p.758: http://www.youtube.com/watch?v=pJ36EtABLAk
Charging by induction, narrator:
»The ground allows electrons to enter from the earth. [...] It [charging by induction] occurs when a charged object is used to charge a neutral one without discharging itself. [...] The rod can be used to charge any number of electroscopes.«
So, essentially the energy stored in all the charged electroscopes comes from earth!
Let's see: Replace the charged rod with a helical coil (important is not magnetic, but electrostatic field), which charge and discharge itself (instead to move it back and forward) a few thousand times a second (with the aid of a spark gap). Replace the electroscope with an oscillating circuit of coils connected to lamps and ground (properly synchronized to the induction field). What happens? Could it happen that we get, say, 200.000 fully charged »electroscopes« (in shape of a coil) each second? That would be a lot of electrons to play around with, especially when they are already located in a transformer coil.
Thinking this over, it would be rather surprising if this approach is NOT going to work.
By the way: David Icke about Tesla, free energy and other strange things: http://www.youtube.com/watch?v=CEXd6uchNCE
TheCell
France patent #120684  Pavel N. Yablotchkov
The system of distribution and amplification of electrical currents
by the means of atmoshpere electricity
Leyden jar / pulling electrons from the ground / current gain by the means of ionisation
jbignes5
Yes the shorted  coil with cap is a good way to build a statically charged field.
I finally finished my thoery with the electric lines. My only stumbling part was what was a charge, well I now know what a charge is. Charges are born for the average that is the background. They are crumpled lines that form into a ball. This ball is a writhing mass of lines and acts like a capacitor. This means the charge lines, if straightened out, would equate the distance across our galaxy. This would be just a condensation of lines after they have been at rest for a bit. So you could think of the charge as a wrinkle in the line that condenses into a mass of lines all balled up.
This is still being worked out but this can be the break we needed to understand what a charge is and how it forms. If matter forms there is usually some kind of bunching of the lines in matter. This explains all the phenomena of heat and light and the effects on matter when charges build up.
cheappower2012
Get down to earth guys,a static potential difference,as in an  earth charge is a totally different
thing from an ac current coming from the earth.You could have a very, very small ac current that's  possible
but a huge ac current like 22 amps is not possible,In the case of TK's video's its an error measurement
caused by the type of clamp amp meter used,look at what I previously posted.
A static discharge and current flow ,direct current,is not an ac current,in the TK's
video's its mostlikely a trick to fake out anyone looking at the video,or  a remote possibility that's its an error on TK's part.
jbignes5
Quote from: Zeitmaschine on May 27, 2012, 06:55:44 AM
Wow bravo.. Finally made the connection....
David sounds like a rather humane sane being.
