0 Members and 358 Guests are viewing this topic.
penno64
Also,
does the special magnet not remind you of those out of hard disc drives -
strong neo on one side and shielded by ?????
Penno
Сергей В.
As Stefan said it's time for OU Revolution.  Next step closer ....
to overunity researchers: I will give you a key so you don't need to crash your heads on walls.  :D :D
All you need to do is to make experiments with Voltage exactly 3730 Volts. This is Dr. R.F. Avramenko's Quantum Key 3.73 KVolts. As he said The Quantum Key Will Open The New Era !!
Here is his book on Russian.  :D :D
ps. Don't belive me at all.  :D :D Belive in yours experiments !!  :D  :D
ps1. The question is why i doing this? You will understand when you gain a OU triumph !!
wattsup
Quote from: woopy on May 27, 2012, 07:14:14 PM
Hi all
some update for the eventually interested
good luck at all :)
Laurent
http://youtu.be/7g9DPL_QU2g
@woopy
I just saw your YT. Love it.
Seems the two turn primary is hitting about three turns of the secondary at that same height. Those three turns of the secondary that get the direct hits will climb up the katcher secondary (tower) and get the frequency increase from the harmonic. High frequency will pass through the transistor as if it was a simple conductor or connector or terminal.
The great part about this is that you don't need a FG. The secondary of the katcher becomes the FG and being internal to the system, it can't get blasted to hell like my last FG.
I have seen the same effect with reactive or cold power on the battery. In one of your last YTs, when you put the copper plate between the two batteries with your light, that indicated that a wound coil could work as well. Good move.
But, just wanted to know.......
a) if you put a small coil on your scope probe and put it near the output capacitor before the car flyback, will the waveform be trumpet?
b) will the system work if you put the ground to the negative of a second battery with positive left open or connected to an antenna. Maybe the second battery can be placed beside the first. I have done many high frequency effects where connecting the device to only the negative (or positive) of a battery provided unique results.
c) I wonder if you wound a coil around the second battery and put it in series with the first battery coil or even in series with the first battery + or - terminal, if this could energize more output on the negative of the second battery that supplies the negative ground to your system.
Keep going man, You is are on a good lane.
@wesley
Someone already said this about the 0.01 amp reading. The question is what is the 3rd and 4th decimal value of that reading. If the amps was 0.0155, will the reading show 0.02 amps, or do you need more then 0.0199 to show 0.02 as the reading. That is the question to ask. Does his ammeter have a finer setting to see at least 3 decimal points?
wattsup
jbignes5
 Yes excellent progress whoopy.
What I suggest is that the higher density of matter in the battery allows for a better density of lines around it. This enhances the interaction between your wire and the battery's electric field. The battery has also an standing charge level. This must include the electric field and the charge is the bias. This can be equated to the pond analogy. Two ponds with different levels of water in them(charge). One if let go to drain will have a flow associated with that level or bias. The pressure associated with the flow will be bigger in one then the other no matter how small they are.
There is also another fact that even though the pond has all the normal dimensions with a very special dimension or surface. Any action on that surface creates waves and can even pulsate the flow going out. Also those waves radiate out on the surface.
Speaking of time if the Universe is indeed speeding up then wouldn't that effect time as well?
Now what can we look at that would make us understand the bigger picture. I know what....
  If we understand this process it would unlock the keys to unlimited energy. The two jets are revolving black holes of opposite polarity. The composition is matter squished to the ultimate crystal. Each crystal has a jet that ejects the charges from matter and expands the rolled up spring(charge) that is inside of matter. This is done via a perfect reflector that attracts the matter then rips the charge from that matter repulsing the charge back out (jets). With the matter being squashed into another layer of the base of these super massive crystals.
The swirl they provide to each other is very evident and is most likely responsible for all life in each galaxy. This is what we can see on the largest scales so far. But I think this goes all the way down to our solar system and even planet or atom scales. It is a fractal. If you take this picture and amass a great amount of matter around it you would see the same thing. They are all connected literally via the lines going out from the crystalline zone.
I think matter without charge is dark matter. Obviously some of the matter goes around the crystal and that is recycled into the system. So a black hole is actually a transformer from potential (charge) energy to pure electric lines all straightened out. This process causes a vibration of the electric line like a guitar string. This energy is tally a byproduct that many many processes in our galaxy require to exist. It's all free energy that is loaded or forms a crunched string when matter condenses. If this condensation did not occur then we would be without form because the charges needed to form matter would not be balled up (picture of a charge I provided earlier).
I think that even matter in a black hole has divisions and the amount of energy that they suck up would flow through those divisions must be intense. Matter at that point is so chargeless that it has a draw on the surrounding matter. Gravity.
This draw is on the accretion disk in this picture. Thats the heavy charge surface with the jets being straightened out lines (electric). As the electric lines go beyond the accretion's disk reach of influence they fall back and roll up(charges) and re-enter the accretion disk from the edge which then attracts the dark matter from the crystals waste and reforms matter from the interaction of the condensing lines (charges) falling twords the accretion disk. Our galaxy is in actuality a pair of super massive black holes revolving around themselves. Thats where the spin comes from in everything within the black holes influence. When matter has no charge there is no way to see or sense it hence the name dark matter. But once charge is reintroduced to matter it becomes real and sense-able.
The space in between galaxies is so filled with dark matter that it defies all logic. In that sense we are floating in it and when matter gets charge it floats with organization. That organization tends to align it into planes. Once the planar surface is created it grows in the shadow of the great recycler or black hole upto the point of the system of the black hole has influence over. One thing that I have noticed is that black holes tend to grow. This means the accretion disk spins faster and thats where I'll leave it with this link.
http://www.sciencedaily.com/releases/2011/05/110523074954.htm
If the Universe is speeding up as they say then time is speeding up as well. Hmmm
verpies
Quote from: Shokac on May 28, 2012, 03:06:36 PM
in this stuff, no free energy.
0.01 (or my bee 0,017 or 0,019)x220V (or 225V) = 4.10W in primary
12,9V x 0,31A = 3,99W on secondary
no free energy.... has even losses. :-(
0.019A x 225V = 4.275W is true only if:
1) The DMM measurements pertain to Direct Current and Voltage, or...
2) The DMM measurements pertain to Alternating Current and Alternating Voltage, that:
   a) Both have a shape of a sine wave
   b) Both are in-phase with each other
   c) Both are measured with RMS meters ( not averaging meters or peak-value meters! )
   d) Both are measured with meters that are capable of valid measurements at the frequencies being measured.
...any line reflections or nonlinear core saturation effects would invalidate 2a, 2b and possibly 2d.
Just because an electric circuit is supplied with 50Hz sine wave voltage, does not mean that the resulting current is a 50Hz sine wave - this is true only for purely linear circuits.
