0 Members and 204 Guests are viewing this topic.
Shokac
Who knows from where this picture and if someone has a larger format?
Shokac
Quote from: verpies on May 29, 2012, 12:35:13 PM
0.019A x 225V = 4.275W is true only if:
1) The DMM measurements pertain to Direct Current and Voltage, or...
2) The DMM measurements pertain to Alternating Current and Alternating Voltage, that:
   a) Both have a shape of a sine wave
   b) Both are in-phase with each other
   c) Both are measured with RMS meters ( not averaging meters or peak-value meters! )
   d) Both are measured with meters that are capable of valid measurements at the frequencies being measured.
...any line reflections or nonlinear core saturation effects would invalidate 2a, 2b and possibly 2d.
Just because an electric circuit is supplied with 50Hz sine wave voltage, does not mean that the resulting current is a 50Hz sine wave - this is true only for purely linear circuits.
It does not matter in this case because the same form of voltage/current on the primary and secondary.
forest
I don't know why you are dispute obvious wrong measurement using metter with bad accuracy. It is clear to me that this video proves nothing, due to mistmatched tool used to prove something. I suspect that's why video was removed by author.
verpies
Quote from: Shokac on May 29, 2012, 02:09:37 PM
It does not matter in this case because the same form of voltage on the primary and secondary.
How do you know, they have the same shapes?
Even if the shapes of the voltage waveforms were the same in the primary and secondary, the voltage alone is not power.
woopy
Hi Wattsup
thank's for interest
A) yes the trumpet is fully at work against the collector cap
B) No and yes,  i tried  to connect the ground to the minus of a battery (1 meter away from the power battery) and no working. than i connected a wire from the positive of this battery to a big antenna  ( my house roof rain collector about 30 meters lenght ), and it works very well.
but than i connected directly the ground to the same antenna ( without crossing the battery ) and it works the same . i mean very well.
C) will try ,as i intend to wrap more turns to see what happens.
hope this helps
Good luck at all :)
laurent
