0 Members and 445 Guests are viewing this topic.
jbignes5
 So continuing on with the line theory. With the amount of matter in our own planet just think of the well of lines we have. Look at the drawing I drew of how I think this process works.
#1 charge in the line. The charge is held within matter via the lines that matter has.
#2 the line external to matter. It should equal the total length of charge(bunch of lines).
#3 matter.
Don't pay attention to the amount of lines as I did this as an example. Truth be told I believe the lines are based on 4's from two angles that are 90 degrees apart. this forms a tetrahedron.
It could be that Tesla was accessing this huge capacity of lines within out planet. He would extend and retract the lines with the high voltage he used and the ground connection.
It could be the lines that are crumpled are more near the center of the matter. It makes sense.
Picture 2 is a better example.
Hey woopy could you check this out and see what you think about it. This goes along the lines of the captret and the battery you have there.
http://www.youtube.com/watch?v=IIObtIEXtMA&feature=g-all-lik
stivep
Few interesting points:
That transformer was made based on original Ukrainian patent
Conclusion:
someone has been working on it  insuring himself that this stuff works
You guys have direct  patent number  so  it is just the matter of time to find out what is in the patent.
Transformer show at the  very beginning  0W IN  when U shapes are closed.
when U shapes are open than  drawing was 10ma.
Load of 4W was unchanged in brightens.
That was in regards to regular transformer just with  U-s on it.
Than he at one point connected over 8W of load using switches  next to light bulbs and drown current did not change
Please  download original video from Arunas link and check by yourself .
Than there is 3 way to do it.  Just build this transformer by yourself.
Wesley
stivep
Quote from: jbignes5 on May 29, 2012, 06:28:54 PM
#3 matter.
My friend
do not take short cuts please.
It is interesting concept
Prepare it point by point and present it right way.
I will see if that fits somehow pockets of energy mentioned in my  earlier post.
If  charge is stored in capacitor and you have space capacitor only without  plates just like you put into  delta T motion that dielectric than at certain distance in space you can catch it and using new set of plates  retrieve energy from it.
Energy does not have mass ( official science statement)
Only carrier of energy  might  have mass  but not always.
So if capacitor  could store energy in vacuum than by removing plates at charge space in  motion at given vector and velocity you can catch it to.
sound crazy? Yes even for me...
view it one more time.
http://www.youtube.com/watch?v=9ckpQW9sdUg
dielectric was touched with hands ( glass jar)
Plates have been removed and touched with hands than shorted together.
But after dielectric is moved to new place and plates  put back than charge is recovered.
Imagine than vacuum capacitor in vacuum of space in motion but only dielectric that could be pictured as  displaced  part of vacuum
How  I want to connect it with your theory?
Hm,..... we have source and we need transportation.that might be similarity to your  theory.
Do I believe in it.. I do not know yet.
But if photon does not have mass and is energy that means photon has speed and vector
It  becomes mass ,or start to have anything to do with mass , when it  strikes ionosphere.
So how about  volume in motion means ... once partitioned  chunk of space with charge..
that was once with plates and now is without just  speeding at given vector to be caught with new sets of plates.
If i'm wrong than please
HOW CAN YOU PICTURE PHOTON GOING  FROM THE SUN TO THE EARTH AND NOT HEAVING MASS? ???
HOW?
AS WHAT?
EMPTY SPACE AT SPEED?
DOES PHOTON HAVE DIAMETER IF IT DOES NOT HAVE MASS?
THINK ........
Wesley
I'm afraid that some of you are just skipping  my posts instead reading  it.
jbignes5
Quote from: stivep on May 29, 2012, 08:03:17 PM
My friend
I will see it that fits somehow pockets of energy mentioned in my  earlier post.
Imagine than vacuum capacitor in vacuum of space in motion but only dielectric that could be pictured as  displaced  par of vacuum
Hm,..... we have source and we need [/size]transportation.
It  becomes mas when it  strikes ionosphere.
If i;m wrong than please
HOW CAN YOU PICTURE PHOTON GOING  FROM THE SYN TO THE EARTH AND NOT HEAVING MASS? ???
HOW?
AS WHAT?
THINK ........
Wesley
I know Wesley. I hurried on that one but it has taken me sooo much time to even get where I am. Yes I hurried the explanation.
Lets see if we can describe this is total.
The lines are formed from dark matter. This stuff is what is responsible for gravity. It doesn't matter much if it is energy or matter. What matters is the effects on matter we can sense.
The lines are pliable except when they are supplied with high voltage. Tesla said he could make ropes in the air and stiffen them to travel on. I'll have to get the reference.
Lines are normally everywhere out of the heavy masses we see. These lines are rolled up in between matter and are a part of a network that matter allows to form. This rolling of the lines is much like a tape measure like effect. All solid matter has these rolls in it and actually holds matter apart. Depending on the amount of voltage depends on the size of each roll. The more potential that is in the center of the matter the further it pushes apart matter and changes phase as we call it. A simple example is water freezing or boiling. This phase goes from solid as we think it to a liquid and from a liquid to a gas. Exciting the lines to stretch out is simply a matter of increasing the excitation of that line.
It could be that our attention to the magnetic did not allow us to see the truth of the matter. So when there are all these 1 wire transmissions we are merely using the lines to the full advantaged. Usually the other side of the load is a mass of matter. This is where the field forms expanding and contracting the lines that it has in it. This connects to the source of the one way wire transfer and a cycle begins. This can create and imbalance in between the source and the expansion mass. This imbalance can be allowed to balance via the load. No lines have been consumed, only rolled up and expanded in a cyclic way.
I have to think more about this but maybe you can help me ferret this out.
on another note check out the pdf of Tesla's. The very last or near last chapter is about his mechanical and Electrical oscillator:
http://ia600302.us.archive.org/16/items/inventionsresear00martiala/inventionsresear00martiala.pdf
Page 486..
