0 Members and 52 Guests are viewing this topic.
conradelektro
I reactivated my Kacher and tried connecting the end of the secondary to a big metal mass and alternatively to a good ground.
Fluorescent tubes placed near the big metal mass light up (even in a water glass). In case the secondary is connected to ground (no big metal mass), the fluorescent tubes light up in or near the secondary.
I know, one should use a battery (and not a power supply) and that power can be tapped from the battery by winding some wire around it. Once I have the 12V batteries I will do further tests, specially the tests done by Woopy..
I also know, that the frequency can be higher when reducing the number of windings of the secondary.
Greetings, Conrad
crowclaw
Quote from: conradelektro on May 30, 2012, 01:11:19 PM
Greetings, Conrad
Your circuit is that of a high voltage RF oscillator which is quite common of course. The high output is able to ignite the gas and hence the tube will glow (very little current flow)... there are many similar circuit arrangements which will produce identical results when these tubes are held close by!  The problem is how much of this RF energy is being transmitted in such away to course havoc maybe with distant communications equipment etc.
jbignes5
Quote from: crowclaw on May 31, 2012, 07:30:02 AM
Ok so that means one wire transmissions are indeed rf then? Or is ouyr understanding of the process so messed up that we could interpose this technology with normal two wire transmission? Longitudinal energy is not rf. It might look like that but it is not rf. Or is it. Would this prove Tesla was right then that RF was not what Hertz theorized then?
Induction is not magnetic based. We know this. Induction is solely static based. This can be even thought out as such. Two forms of energy one of mass and inertia and the other statics. Both can be interrelated. Any static tests will show you how it can effect real masses. A charged comb by flowing water is the most Telling. It effects all masses. Given the size of matter when compared to the medium at that scale, particle size, it's density would be massive and still floating in something. This something is the background energy network. All matter is condensing and so is that energy network.
Some of the stuff I have been showing you guys is the very same process as I am trying to describe. Filaments seem to be the main component when the universe gets condensed enough. AS that energy condenses it gets more intense and the background is biased by that condensing. It seems the universe is packing together in clumps and is connected by vast energy flows. I mean vast, light years even.
What real effects can we look at and suppose the direction of this existence. Every form of matter that has charge in it is expanding. Our own planet shows signs of it now and the water we have on this planet is being shed by the sun. We capture this. It could be that this process is going on inside of our planet as well. The Dark matter that is trapped inside of our planets core is growing because dark matter has gravity. Dark matter + energy(light)= sensible Matter (Real). This process is exactly proven by the Biggest find of water in our Universe. Look it up sometime. Quasar as an additional search term might help you to understand that something odd is going on.
I think that Black holes are actually condensed Dark matter. Probably in crystalline form. Everything can be gained by understanding the basics of these processes. Ungodly amounts of power are funneled into black holes and it seems that it is very overunity because they grow in density and effect 1000's of light years of space in increasing pressure.
Has anyone done any scans of the electric field around a high voltage coil? Ever? We could use the avramenko plug and led to optical sensor(webcam or HD video camera. Since intensity would reflect field strength at that location all one would need to do is run the field at low level and check the response of the led on the camera. Of course we will need to use a computer to decipher the led intensity and position through the camera.The optical sensor would be more accurate though.
I have another experiment I am gonna try. I think I'm gonna build the mechanical + electric oscillator and hook it to a hv solenoid +cap. This should give the very steady pulse that Tesla figured out as the pulse for the solenoid+Cap that is shorted. This would charge the solenoid up and maintain it. This oscillation that is created in the hv coil then can be induced into a transforming gauge wire that changes the HV to low voltage high current. And the more current you use the bigger the "Magnetic" field would be and reflect back to the HV coil setup. This might intensify the current one is using in the mechanical+electrical oscillator. So everything would, once started, intensify for one impulse. Using a break or gap is a very good way to not let this get out of hand. But the gap would be for no other purpose then to protect itself from run away.
I might even have to pulse the load to lower the draw from the heavy coil around the hv solenoid+cap combo to better regulate the potential building up in the interior HV solenoid. Maybe a bifilar heavy coil would help in keeping the output from effecting the input and use the gap as a timing feature to change the duty cycle of the internal HV coil +cap.
Another interesting thought or experiment is that shorting the heavy coil could increase the inner intensity of the HV solenoid and allow it to pressurize then release into the load. This would do two things. Make an on demand pulsed high current mode and a regular idling mode for low current uses.
T-1000
Quote from: jbignes5 on May 31, 2012, 07:51:26 AM
www.youtube.com/watch?v=EMKlmnsmMgk#t=0h5m50s looks familiar? :)
jbignes5
Quote from: T-1000 on May 31, 2012, 09:03:02 AM
Excellent find. Wow... That is exactly what kapanadze is trying to do with the turks. That is the system...
Very basic Tesla method.
Thank you for bringing that up. I totally forgot about Mr. Smith....
