0 Members and 115 Guests are viewing this topic.
T-1000
Quote from: verpies on June 02, 2012, 05:00:11 AM
Since it's rude not to answer direct questions - I will reply despite them being off-topic:
No. I am not an employment intermediary - I am a scientist.  Scientists, do not find jobs for people.
...but I can help with scientific know-how and scientific equipment.
So do experiment with yoke device instead of wasting our time with questions what can be answered by actually putting effort to make device. As soon as you hit NMR you will see the answers.
Our real life situation is not the best at the moment so we do not have much time to be in forums and do another experiment for  sake of answers you seek.
Good luck!
verpies
Quote from: T-1000 on June 02, 2012, 05:15:41 AM
I did the experiment with a different ferrite and I was uncuccessful.  It is likely that your particular ferrite has special properties.
I did not realize that offering you free test equipment in motivation for scentific I/O power measurements of your past devices (not only the Yoke device) is also a "waste of your time".
Aren't you interested what is the true I/O power ratio of your devices, too?
T-1000
Quote from: verpies on June 02, 2012, 05:24:12 AM
Ferriite color?
You need to look for black one, with Fe isotopoe 56 inside for best case.
Not Russian ferrites usually have NMR on much higher frequency because of different integriends inside.
Also did you follow our instructions? You need to find core material resonant frequency as first rule. And do magnetization of core in 15T(or similar) for second rule.
Our own ferrites are already burned out so no easy way for plug & play. New ones cost time and money we do not have now.
verpies
Quote from: T-1000 on June 02, 2012, 05:33:41 AM
Ferriite color?
Black, from a russian Рубин 714 television set.
I was not able to detect a signal from nuclear precession (FID) in this ferromagnetic core from 1kHz to 60Mhz Larmor Frequency, using the windings depicted in Aidas' diagrams.
Osiakosia, Itsu, energia9, dynoc, philm, Jdo300 and Wattsup also were unsuccessful with their cores. One of them made video of the attempt.
Conventional NMR requires very homogenous longitudinal magnetic flux density in the tested material in order for maximum number of nuclei to resonate to the transverse magnetic field at the same frequency.  If only few nuclei resonate then the NMR signal is too weak to detect.
I did not do isotopic analysis of this core in a mass spectrometer.
