0 Members and 283 Guests are viewing this topic.
Magluvin
Hey Itsu
I got distracted toward the end of your vid and just unpaused and finished it. I see that you did try the diode across the cap. Was it necessary to use the AV plug and ground?
I might think that the cap could just take from one side to the other through a single diode.  Might want to try a faster diode also, considering the freq you are reading.
It may be how the connections inside the cap are connected to the plates. If the connections are both made at the start of the spiral, then yes, your method with the av plug is necessary.  It would be the same for the bifi if the load were connected at the start ends of the bifi.
Im going to look into it to see if some caps are wired as I described, one connection at the start of one plate, and the end of the other.
Like if you were to wire 10 12v batteries in parallel, you shouldnt just connect your load to 1 of the batteries at one end of the line in the parallel group, the pos should be connected to a batt on one end and the neg should be connected to the battery at the other end of the group. Ive studied electric car conversions for some time now. The reasoning is flawless. It helps to pull current from all batteries equally due to the resistance in the parallel battery connections. So it seems to me that a cap should have connections this way also.   Interesting how things are. ;]
Soo, it got me thinking. If we wound our own cap, connect the ends properly, and also, add a core possibly.   :o ;)
Just getting my setup together now.
Mags
andrea76
what i think happens inside the Kapanadze coils.this is the statement of Dr. Roger Hastings about the Newmann motor:
My interpretation of Newman's original idea for his motor is as follows:
As a thought experiment, suppose one made a coil consisting of 186,000 miles of wire. An electrical field would require one second to travel the length of the wire, or in Newman's language, it would take one second for gyroscopic massergies inserted at one end of the wire to reach the other end. Now suppose that the polarity of the applied voltage was switched before the one second has elapsed, and that polarity switching was repeated with a period less than one second.
Result:
Gyroscopic massergies would become trapped in the wire and, as their number increased, so would the alignment of electrons and the number of gyroscopic massergies in the magnetic field increase. The intensified magnetic field could be used to do work on an external magnet, while the input current to the coil would be small or (operationally) non-existent. Newman's motors contain up to 55 miles of wire, and the voltage is rapidly switched as the magnet rotates. He elaborates upon his theory in his book, and uses it to interpret a variety of physical phenomena.
this is similar to the Steven Mark TPU...
itsu
@ conradelektro
Quote@Itsu: very nice video about your Kacher experiments. I tried windings around a 490 pF high voltage capacitor without much success. But I still have to get a EPKOS spark gap or build a spark gap myself. I will also look for these nice car starter capacitors and micro wave oven capacitors.
Thanks, i think "Conrad" sells them  ;)
Nice setup/pictures.
Yes, the kacher can play havoc on the powersupply, therefor i use batteries.
But even then when i ground the minus of the battery and have another ground point in the circuit it burns out a decoupling ceramic capacitor (0.1uF) rated 50V across the battery terminals so now and then.
There is a thread on energeticforum.com (BrovinKacherTesla) which discusses kacher items.
Regards Itsu
conradelektro
Quote from: dllabarre on June 04, 2012, 08:31:19 PM
The big metal mass you talk about.  Is it that large coil on the left side of your bottom picture?
If that is a coil then it could be causing problems for you cause it has inductance.
I would use plane piece of heavy metal or maybe remove all windings from around the heavy coil you are trying to use.
I don't agree using a heavy metal mass to make a floating ground but if others have used it successfully then I'm wrong.
Anyways - remove the coil wire and your system may work more as you think it should work without having the additional inductance.
Also remember kacher produces HF so your heavy metal coil could also be picking up some of that like an antenna which also might mess up what you want (or think) your device to do.
Just me 2 cents.
DonL
The "big metal mass" is an iron core from a transformer (not a coil).
My grounding problem:
A) I found two points in the Kacher circuit which can be grounded, the end of the secondary or the minus rail.
B) Electricity (induced by the radio frequency in the battery) comes from the coil around the 12V battery, goes through a fluorescent tube (and or through an AV plug with LEDs), and has to be grounded eventually.
Ground A) and B) can not be the same ground. Therefore I tried the "big metal mass" as a second virtual ground. Also the body can be a virtual ground.
All works somehow without any ground connection, but the tubes or LEDs become brighter when specific ground connections are made.
It also looks like a tuning problem, because moving a hand near some points in the circuit increases the brightness of the tubes or LEDs. Actually touching some bare wire or bare connection often kills oscillation. But the body can be a good virtual ground at the good ground points. (Attention, the "touching experiments" are not recommended with a high power Kacher.)
I like the Kacher with little power, because one sees the grounding and tuning problems more clearly. Pumping 24 Volt and many Watts into the Kacher gives spectacular effects but drowns subtleties in the strong radio emissions.
The two interesting places in the Kacher are the secondary and the battery. There the strong radio frequency emissions happen. When connecting the end of the secondary to a "big metal mass" the radio frequency emissions also happen at the "big metal mass" and become weaker at the coil.
The unproven speculation: by exciting the ground or the air some additional energy (charge, electrons) can be harvested.
Greetings, Conrad
