0 Members and 92 Guests are viewing this topic.
verpies
Quote from: yfree on June 04, 2012, 06:41:21 AM
The document in your link is outdated.
I didn't know.  Where is the one more up to date?
As for the "flaw", I am sure you did not mean the true meaning of this word. McFreey is concentrating on the basic phenomenon behind the working principles of the device and not every detail or ideal condition.
"Flaw" might have been too strong of a word.
I agree, spontaneous decay and NMR enhanced radiation is 3D but the stimulated radiation may not be. In lasers, for instance, spontaneous emission is 3D, stimulated emission is not.
Yes, NMR stimulated beta decay might not be isotropically distributed in 3D, however the secondary products of this decay (e.g: Delta Rays) would be scattered all over.
So after the first scattering event ( Møller, Bremsstrahlung, Deep inelastic, Mott) the particle would not be confined to the plane of the disk anymore.
The link to the SR193 device is here:
http://www.youtube.com/watch?v=rbkvXoDfk7g
Zeitmaschine thinks that devices with ferromagnetic cores are a different class of devices and Kapanadze's devices do not work according to the principles described by McFreey
Quote from: Zeitmaschine on June 03, 2012, 09:25:58 PM
There is another flaw: The Kapanadze coil has with almost absolute certainty no ferrite core...
Zeitmaschine
This is due to the fact, I can't see any room for hidden ferromagnetic cores in Kapanadze's 2004 coil.
https://rapidshare.com/files/3571314754/Commented_video_frames_regarding_the_Kapanadze_device.pdf
The other thing is due to the fact, I can see a »twisted pair« used as ground connection in SR193 video. This kind of cable is also very convenient to connect something to an AC wall socket. :D In the video the working device and the ground cable connected to the pipe is not shown at the same time.
So, could it be that the suggested use of ferromagnetic cores is for distraction only, whereas in reality the use of ferromagnetic cores prevents the Kapanadze device from working?
forest
Zeitmaschine
I agree about no core in Kapanadze. At least no ferrite, iron is possible but probably not used. It's interesting if you think about all this deeper it all falls into NMR area but with very different perspective. Looks like some atoms can tap ambient heat and other frequencies around in some very special situation and there exists a way to convert it into a usable stream of electric energy. Kind of perfect multirange solar panel. In this wide perspective it is NMR.
If you compare Sr913 and Kapanadze devices there is a lot of common. In fact both match the same "signature" with slightly different modulator part .
leo48
QuotePls translate to english
please:
I translate with google translate.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Shokac
reading this!
http://www.absoluteastronomy.com/topics/Lightning
Chapter: Properties
Lightning can occur with both positive and negative polarity. An average bolt of negative lightning carries an electric current of 30,000 amperes (30 kA), and transfers fifteen coulombs of electric charge and 500 megajoules of energy. Large bolts of lightning can carry up to 120 kA and 350 coulombs. An average bolt of positive lightning carries an electric current of about 300 kA â€" about 10 times that of negative lightning.
Kapanadze lightning is veri small ...... cca 20 ampers or......  :-), BUT ONLY CURRENT!
HI VOLTAGE USE ONLY FOR MAKE CURRENT!!!!!!
