energia9
Quote from: Zeitmaschine on June 06, 2012, 11:50:48 AM
The discovery of the week: The transistor's third wire! (see image)
But maybe I have made a mistake in understanding the correct frequency of the inner coil. The frequency of the secondary coil is not 2KHz but rather a difference of 2KHz compared to the first induction coil. Not sure about this, the statement in English translation is a little bit vague. ???
I'm still confused how to do a 50Hz modulation.
are you sure its around 200khz?  i would say it is around 10 megahertz unless there is a tesla coil underneath those heavy gauge windings
stivep
Transformer by Alexander Kugushov part#2.swf
http://www.youtube.com/watch?v=jxDVbj_IfpU
More information is covered in this video, much more.
Plus my comments
Wesley
forest
You wanted any valuable info..well, while I'm still not sure but almost.... then ... just drop everything you thought before and think .....IF you would have a big current but at 230V what would be the simplest modulator to get it pulsed at 50Hz ???? How about a little weak HV current from kacher interrupted at 50Hz to ionize spark gap ?
Anyway...what is the minimal voltage to jump spark gap ? think simple
Shokac
first staf of kapanadze is solved.... adicional current is from hi voltage discharge thru condenser and spark gap. (juel thief, hi voltage transformer or something else)
second staf is also solver.....forming 50Hz......
Kapanadze use simple passband filter made of condenser and coil.... http://electriciantraining.tpub.com/14181/css/14181_50.htm
npr:
use 40uF AC condenser (for starting motors) and 253,3mH coil.... :-)
if try to made this filter.....coil is the same like kapanadze LOW voltage coil.....try to make!
Coil is formed around condenser...
The third thing is not solved :-(..... How conect Hi voltage discharge, passband filter and 220 voltage from inverter or grid... ??? ???
leo48
Quotecan someone translate this?
воÑ, именно эÑ,оÑ, зазор между Ñ,,ерриÑ,ами
позволяеÑ, Ñ,ак распидаливаÑ,ÑŒ миникачер !
воÑ, вам принцип разгона !
Here it is this gap between the ferrite
allows both raspidalivat minikacher!
here is the principle of acceleration!
the gap between the ferrite
Ñ,,ерриÑ,овый  сÑ,ержень  =  ferrite rod
Ñ,,Ñ,оропласÑ,овый промежуÑ,ок = PTFE gap
зазор между обмоÑ,ками индукÑ,ора = the gap between the inductor windings
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
