0 Members and 668 Guests are viewing this topic.
energia9
Quote from: yfree on June 08, 2012, 07:46:15 AM
I can answer your question, although I am not Russian.
This man says that one Tesla coil can excite other Tesla coils located nearby, which are exact copies of the first, and this way the energy can be multiplied.
That is all.
Thanks Yfree and T1000
i thought the same...
and i think its possible,
so because electrostatics is not electromagnetic, it does not slow down the sender
aha!
so we send power with 1 tesla coil,   collect power from  abt 3 tesla coils in a capacitor,  and send that accumulated energy back into the sender coil at the resonant frequency of the 3 at timed intervals!!
ok i start to see myself what kapanadze means by stabilizing field between coils,    obviously stabilizing field between the abt 3 tesla coils (any amount of tesla coils.)...
so no free energy in here...  but what it is is recollection of electrons and reusing them
my poor logic tells me it is possible to run a self sustaining machine this way...
this is not even against any laws of physics..
a light shines down onto a surface, and a mirror cathes the photons which would otherwise be lost, and redirect them to the spot.  and we have stronger light.
say 10 watt in,  80% efficinecy,    8 watt out from collector into capacitor.   + sending back accumulated energy from cap back onto the sender. . .   10 watt + 8 watts =  18 watts
and i think this can only be done with electrostatic energy.
tesla was talking about his magnifying transmitter and how he was able to send power around the globe with 95% electrostatic and 5% electromagnetic waves
jbignes5
 In actuality he said he could do it either way. 90% magnetic and 5% electric or 5% magnetic and 90% electric. When he did it the usual way it amounted to a net loss but if he could do it in the electric there was very little loss across the near field.
When you look at the turkey videos of Kapanadze look at the coils he has setup. 1 transmitter and 3 receivers. These receivers do receive less power each but when you put them together they can net more then the input. If you do it right. 3 receiver coils = 3 phase electricity, hence the motor he had in the video.
The transmitter must have a revolving field and the receivers then can concentrate the fields to the inner coil where it can be drawn off when needed in a concentrated form.
Tesla talks about this coil and how different metals do different things in the field. Oh coincidentally he also puts his head in the coil as well to show no ill effects to humans. Now that is brave.
Tesla on the phenomena:
" The electrical resonance is the more perfectly attained, the smaller the resistance or the impedance of the conducting path and the more perfect the dielectric.  In a Leyden jar discharging through a short stranded cable of thin wires these requirements are probably best fulfilled, and the resonance effects are, therefore very prominent.  Such is not the case with dynamo machines, transformers and their circuits, or with commercial apparatus in general in which the presence of iron cores complicates the action or renders it impossible.  In regard to Leyden jars with which resonance effects are frequently demonstrated, I would say that the effects observed are often attributed but are seldom due to true resonance, for an error is quite easily made in this respect.  This may be undoubtedly demonstrated by the following experiment.  Take, for instance, two large insulated metallic plates or spheres which I shall designate A and B; place them at a certain small distance apart and charge them from a frictional or influence machine to a potential so high that just a slight increase of the difference of potential between them will cause the small air or insulating space to break down.  This is easily reached by making a few preliminary trials.  If now another plateâ€"fastened on an insulating handle and connected by a wire to one of the terminals of a high tension secondary of an induction coil, which is maintained in action by an alternator (preferably high frequency)â€"is approached to one of the charged bodies A or B, so as to be nearer to either one of them, the discharge will invariably occur between them; at least it will, if the potential of the coil in connection with the plate is sufficiently high.  But the explanation of this will soon be found in the fact that the approached plate acts inductively upon the bodies A and B and causes a spark to pass between them.  When this spark occurs, the charges which were previously imparted to these bodies from the influence machine, must needs be lost, since the bodies are brought in electrical connection through the arc formed.  Now this arc is formed whether there be resonance or not.  But even if the spark would not be produced, still there is an alternating E. M. F. set up between the bodies when the plate is brought near one of them; therefore the approach of the plate, if it does not always actually, will, at any rate, tend to break down the air space by inductive action.  Instead of the spheres or plates A and B we may take the coatings of a Leyden jar with the same result, and in place of the machine,â€"which is a high frequency alternator preferably, because it is more suitable for the experiment and also for the argument,â€"we may take another Leyden jar or battery of jars.  When such jars are discharging through a circuit of low resistance the same is traversed by currents of very high frequency.  The plate may now be connected to one of the coatings of the second jar, and when it is brought near to the first jar just previously charged to a high potential from an influence machine, the result is the same as before, and the first jar will discharge through a small air space upon the second being caused to discharge.  But both jars and their circuits need not be tuned any closer than a basso profundo is to the note produced by a mosquito, as small sparks will be produced through the air space, or at least the latter will be considerably more strained owing to the setting up of an alternating E. M. F. by induction, which takes place when one of the jars begins to discharge.  Again another error of a similar nature is quite easily made.  If the circuits of the two jars are run parallel and close together, and the experiment has been performed of discharging one by the other, and now a coil of wire be added to one of the circuits whereupon the experiment does not succeed, the conclusion that this is due to the fact that the circuits are now not tuned, would be far from being safe.  For the two circuits act as condenser coatings and the addition of the coil to one of them is equivalent to bridging them, at the point where the coil is placed, by a small condenser, and the effect of the latter might be to prevent the spark from jumping through the discharge space by diminishing the alternating E. M. F. acting across the same.  All these remarks, and many more which might be added but for fear of wandering too far from the subject, are made with the pardonable intention of cautioning the unsuspecting student, who might gain an entirely unwarranted opinion of his skill at seeing every experiment succeed; but they are in no way thrust upon the experienced as novel observations."
This could be the reason for Woopy's experiments with the copper plate? Oh and also that could explain the captret as well. I always thought the captret was something special. It had the feel of a transistor. Wow.. Big doink moment there. It's a transistor! A loadable(chargeable(capacitance)) transistor...
The capacitor is normal but it can be modulated via the body that is normally used to static shield the capacitor. I got to try my big oil cap for that.... Hmmm..
I'm also thinking this can only be done with aluminum.. Maybe this is why Tesla loved aluminum soo much.. That and aluminum acts differently then copper to a magnetic field. I'll see if I can find a good video of this difference.
When you add the one wire exciter to the static shield it now becomes a booster. Maybe...
Fond a clip about aluminum and a magnet. Ok the end question is because of a small difference in the field of the south pole. Whatever that difference is what makes the magnet turn the way it does. Weather that is spin of something else we will have to see...
http://www.youtube.com/watch?feature=endscreen&NR=1&v=a0YCTwWvykw
Hmm.. http://www.youtube.com/watch?NR=1&v=5sxuBsAFuI4&feature=endscreen
T-1000
Quote from: ronotte on June 08, 2012, 09:29:35 AM
@ T-1000,
Just to add some personal experience on the famous Tesla power issue:
I built and tested a set comprehensive of one transmitter device and 3 receiver devices as per K. Meyl basic Tesla design. I can confirm that TOTAL RECEIVER POWER is LESS than transmitted power. I used professional measuring devices.
So, it is also true that the Meyl's approach a bit different from original Tesla in many ways, mainly: presence of a virtual ground wire interconnecting both TX and RXs, 6MHz operating freq...etc
Roberto
http://www.energeticforum.com/renewable-energy/4864-donald-smith-devices-too-good-true-197.html#post196992
verpies
Quote from: Сергей Ð'. on June 08, 2012, 03:14:02 AM
Here is another video example. You can see how to putting power out of Tesla-Brovin kacher or Tesla transformer. The light bulb is 220V, 100W and shine the full strenght.  Look it how it's easy to be done...
http://www.youtube.com/watch?feature=v=vAZq27ISyLQ
This one has a ferrite core and a copper ring/tube.
In the first version the ring is cut and in the second version it is shorted.
The latter one seems to be in agreement with William J. McFreey's analysis.
