0 Members and 493 Guests are viewing this topic.
jbignes5
 I have not finished this drawing yet but this is what I got so far.
The problem is the second solenoid connection. I'm thinking #2 ground.
To be clear ground 2 is connected to the output through the telephone dual wire cable.  The grounds will be hooked to opposite wires so that they flow against each other but are not directly connected to each other.
jbignes5
stivep
ronotte
@T-1000 and all interested,
I did not know that thread on Energetic Forum: thanks. Unfortunately for them their suppositions mostly wrong. I do not know how they got my project as I did not released anything about it...only some generic info.
My tests on multiple TMT configurations lasted at least a couple of months and I've had the opportunity to fully check several different operating conditions. Test's aiming being mainly to check if any OU as many talked about...and not transfer power ;D
First of all I confirm the so called antennas not antennas at all because they radiated only electrical field NO MAGNETIC component: in fact they are not tuned at all for the operating frequency (about 6MHz). I fully checked that in several ways (the EM components very low and dies after 1 meter...impossible to detect because field lower than microvolt)...on the contrary I've been able to transfer up to 100W at 10/40meters with high efficiency.
Said that, it is true have not found any OU....but several funny situations especially using a single couple of TX - RX. In such a case for example increasing the load on RX side does decrease a bit  the requested power to transmitter so showing a NEGATIVE behaviour :) . The transmitter being fed by a regular Wavetek oscillator followed by a RF 200W RF linear amplifier followed by a match box to properly drive the Tesla primary pancake coil at optimum SWR.
Regards to all
Roberto
verpies
Quote from: yfree on June 08, 2012, 05:58:05 PM
The most up-to-date version of articles in PJKBook is here:
Indeed it has been updated to v21.4.  Thank you.
This version of the analysis rightly notices that the best magnetic field geometry for confining the charged particles in the ring/tube/disk is parallel outside of the disk and perpendicular inside of the disk.
This is a very hard field geometry to achieve because magnetic field lines do not cross each other.  It somewhat resembles the field of two repelling magnets, but not quite.
In rectangular ferromagnetic cores the leakage flux is almost perpendicular to the core flux at the expense of being much weaker.
In MFE Magnetic Mirrors and Magnetic Bottles and Spheromak were attempts at this confinement problem.
