0 Members and 670 Guests are viewing this topic.
jbignes5
Not so right on magnetic field of the magnet. Try this version: Picture attached.
The third picture is very correct. And it seems that the connectors that are horizontal are finer threads of electric field lines. What condenses on those lines are out of polarity field lines that get attracted into a balance game across the 90 degree nodes. Anything that is 90 degrees apart will not influence the other. Once attracted they balance to the neutral position, only getting force when it moves away from that perfect value of 90 degrees. This keeps them in perfect placement and allow for a bending of the lines that have condensed across that region in an oscillatory movement. Remember the lines bend from side to side but not so much from start to stop of the line.
The lines are made in such a way that each component allows this golden rule of no compression longitudinally but a percentage ?? laterally. This comes from the shape of the components of the line. I think this shape is pyramidal in form. This allows for complete support longitudinally via stacking but allow for a bend of the stack to either side.
Now is this stuff real matter? I'm leaning to no because it seems these particles are so small that they can virtually build the network on the fly from the available (environmental) supply of free particles. Alone the basic form of these particles have neutral standing. Nothing can be detected on the smallest scales. But on the other hand we have been able to detect a mass on the largest scales. This mass makes up the other half of the available gravity that the entire galaxy has shown, black holes included. We can not detect it because it has no value other then neutral. It passes any energy without loss and acts like a small lens. Since lines form around very high condensations of charges and radiate out of that point it transmits all available information visually and frequency all in real time without cost. The vehicle or focal lenses are already scattered across billions of miles this was done in the creation and expansion(condensing) of our space.  As this expansion or condensing of the electric fields continues the intensity will get higher. Matter will become more energetic as we go from the material to the energy side of our existence.
Now where does the energy come from in a magnet. One question might clear that up... How fast are we moving through the galaxy or even the Universe? It is our flow through this potential matter, in the micro but verified measurable on the galactic scale as having a real gravity, that causes all energetic swirls that we see. Some are quite spectacular when viewed. Like our Sun for instance or even our planet.
We are gonna be going on the upswing of the oscillation as recorded in the Mayan calendar. We have hit bottom and it can't get any worse. Well nothing will be worse then whats coming. It's a transition period and it all matters how we handle it. Will we learn from our past or will we continue down the same old road of deception,death and destruction.
The ancients seemed to have had the same level of knowledge we are coming into here and they couldn't stop and smell the roses. Take a breath and know that we are all brothers and sisters. Yet we treat each other like we are separate for which we are not. The ancients had the perfect idea. Create a humanity protection system where no one had more power then the next. All were capable of great wonders and all were of one spirit. What we have is driving our humanity insane. But we could change that tomorrow, we have the power. We just need to rejoin the human race and care for each other. Both individually and on the whole. We must be represented on the whole as well, for which the current system does not represent anyone but the corporate mandates. They tell us what to do. Shouldn't it be the other way around...
T-1000
kanofski
hay all
this is my first post here so first of all Hello Overunity(DOT)com
i think what is happening here is resonance,  but i think its on a diffrent level, what I think, is that when we would use magnetic standing wave resonance,
this Will give resonance on a diffrent scale
so we would not need a tank circuit :)
so if we would use like for the primary coil
20kHz >
and
20kHz 180* out of phase <
we would get a standing wave @ 90* or 1/2 wavelength @ 40kHz
and the secondary coil
40kHz @ 90* @ 230v thru a SG in the coil, end of coil is output
I'm working on this now winding a 12v to 2100v 2 phase 0* 180*
and order a brand new 50MHz scoop and 50MHz SA
so i Will be testing soon ;)
don't know if this is even possible but in my head the math works hihi.
greets from the NL
