0 Members and 41 Guests are viewing this topic.
jbignes5
 Lines, lines, lines. It's the nature of the universe. As well as the dot theory used in printing we can also apply that to any shape or form depending on the scale of the lines or dots.
A general makeup of the lines I have attached. This is going back to my older theory and fits pretty well. These are not magnetic lines per say. These are electric lines. Magnetic lines are concentrations or condensations of free electric lines in the environment that are not aligned to the 90 degree support electric line.
When you look at the http://en.wikipedia.org/wiki/Sierpinski_triangle go down to the section of Analogues in higher dimensions. To the right of that paragraph is the positive and negative particles shown in the picture with a red and blue triangle. Positive being full of space and negative being more neutral or passive. Each polarity must be skewed in some way that allows the direction of spin or each polarity. One is shaped slightly left and one is shaped slightly right.
If you click the picture there is a very high resolution picture to see the orientation that makes the polarities all from the same gross shape(pyramid).
Can we agree that matter does not generally touch on the smaller scales? If thats so then it must have infinite division at the smallest scales.
If we look at the 3d triangle I have to think that the red is positive and the combination of the red and blue is the negative. The true blue pyramid is actually dark matter because it is true neutral. When you mix dark matter(blue) with the red you get the minimum charge level of our Universe. Since the red has infinite surface area you can transport insane amount of charges in that structure. when you couple that infinite charge with real matter(blue pyramid) you get real tangible detectable charged matter. The blue is by itself totally neutral.
This is what I think these motors that Tesla was designing. Instead of doing them the way he designed they changed them and made them work with current. Why because thats what they are selling. Why would you make something that devalues your own product.
Tesla's transformers were designed to keep the magnetic field inside of a core so that he could use the stiffened lines to generate or induce a value change in a central coil and core. He used the same process that a transformer uses except there was no connection needed between the primary and secondary. When you work with the fields since the magnetic field gets pulled into the core there is only the electric field left. This field is the sole reason why induction works. Learning how to make these lines very strong will give you all the energy in the universe as the lines cut the copper and excite the winds.
The generation of just voltage isn't that intuitive and it has to be converted into usable current by polarizing the electricity. Tesla actually designed a few high voltage generators that didn't have the kickback that normal generators have. If you stay away from the heavy magnetic side everything becomes less powerful in the generation circuit. Then put that to induction coils around the rotor and you now have a concentrated bunch of lines cutting into the core and rotor windings.
I stand with the latest drawings that I have made of the Kapandze system. The other one with the obvious Tesla coils is nothing more then a visual explanation of the process they are trying to sell as his own.
As for the failures of others who tried to do the experiment with the tower that is because you didn't do it right. Having the antennas of the receivers will never be balanced. Each coil will have it's own field associated with it and putting the antennas like that and not evenly around the driving coil will net you nothing more then the first antenna sitting there. The field strength also would be very weak in small setups so the tolerances need to be tighter and less self influencing of each other. You also have to think that these are gears or the fields act gear like.
trawnik
Guys, i just saw that the LM555 as Generator working not like the K561(EL)H561 (or CD4449).
Heres some scope, setup like sr193 did it:
forest
Quote from: trawnik on June 10, 2012, 08:39:25 AM
ok,możesz rozwinÄ...ć myÅ›l ?
can you describe what you mean ? I'm using cd4049 or cd4047 or nand gates like cd4011 for square wave oscillators
never heard about cd4449 what's that ?
Here is my theory what sr913 device is, very very simple.... it is a switch turning on/off magnetic field or rather permeability of core but for the output coil it is like switching magnetic field on/off and we know that we can have large current from large magnetic field switched at 50Hz or from weak magnetic field switched at 50khz , is that correct ? of course using Faraday's induction law, then we have problem with output frequency but this is a separate issue (not quite important for incandescent bulbs)
It still is a trouble for me why it can made a self-sustaining closed-loop device but a kind of blocking generator recovering all not used energy is  a perfectly possible and I'm working on it. Finally I may find that it's just that all loads we are using are very wasteful and most energy can be recovered easily like we did in fluorescent bulbs.
Again , I'd like to pinpoint : there is not law which limit or precise the amount of work done using energy bit.
Closed circuits are limited but we can use an open circuit and get energy like solar panels or heat pumps do.
jbignes5
 The tower version is very simple to understand.
In this picture we have 2 coils. A and B. C is the field of coil A. As the field builds further into the windings of B it creates a potential across the wires of the coil. This in turn creates a field in coil b. If it is oriented right it can repel the field from c and spin up to A's speed with compression of field C. This system is highly unbalanced as I have shown. It would need a complimentary coil on the other side of the field to create a better compression of the electric field around the drive coil A.
The problem I see with kapandze is that he is trying to change the idea enough to be able to attach his own patent to the process. Since most countries only require 20% of the original patent to change in order to reissue a separate patent under the new or improved patent title.
Ok back to the dynamics of this system. Generally the lines follow the origin conductors so winding left or right will change the outcome of the resulting direction to the field(from end to end of the hv coil. Remember my comments of corona discharges and how they look. The hint here being they are only intensified channels. These channels do not change the only thing you are changing is the intensity of them. This allows us to see them briefly.
P.S. There is no such thing as a closed circuit. Every circuit leaks and receives from the environment. Yes they have shielding but even that has leakage.
