0 Members and 43 Guests are viewing this topic.
trawnik
another scope (sr193 generator chematic), again CD4449 is a Hex Inverter and works different as the LM555
jbignes5
This might give you an explanation of this process. Or at least clues to the process.
http://www.youtube.com/watch?feature=endscreen&NR=1&v=x_CFLL68aZQ
A better version.
http://www.youtube.com/watch?v=e6v01maAPN8&feature=channel&list=UL
And this one shows you the kind of field that can self excite real matter. This excitation is what we are looking for in a heavy copper coil. The entire coil will be cut by the very thin lines of the Tesla coil on the very high voltage end or top. The electric field is greatest at the end of the coil with the highest value. Like wise the heavy current side or low voltage end is the current field. This is the driving mechanism that accelerates charges and condenses to a high voltage as it travels up the coil. The speed of the charges change and so does the density of the lines associated with that point on the coil.
One of my better analogies is of a string of pearls strung on elastic thread. Now with longitudinal energy what you are controlling is the tension of the current. The higher the tension the more force it would take to divide the established network of pearls. Now apply my previos post about what lines look like and you can see how this works. The natural charge level keeps lines bount in a line. Anything below that disperses the particles or pearls and then can be rebuilt with any charges that were bound to the previous releasing.
If we replace the pearls with pyramids you can see why nature is guided in certain fractal paths. The angles to which a network can form is very limited and a bit testy to be frank. When you raise any form of energy it usually ends up twisting into a coil like fashion. This is due to the non linear particles that make up the medium we live in. Around our point in the universe is a very dense electric field with a very big ground electrode to boot. It has been shown that the earth is very conductive to voltage stimulation. This means it is conducting into the point and gathering mass. This is why the earth is growing. We are condensing energy from the Universe every second of every day. We are filling up like a balloon with an absence of dark matter or primary matter. Matter displaces the dark matter by containing energy in some form and this usually creates a self sustaining flow for the matter to use to maintain it's detect ability.
One thing that would help would be to use polarized glasses like effect and separate the frequencies we want to see even magnetic. We should be able to devise a way to see these fields and some have done just that. With plasma and High voltages they have been able to see the structures of these fields in action. With those experiments they saw dark matter for the first time. Where the boundry was between the high voltage(plasma, very intense bright light) and current(plasma dark or clear). The dark areas I suspect is the dark matter and it shadows us like an inverse or negative of our reality. This is a 90 degree shift when going from matter to dark matter. One doesn't effect much of the other induction wise but it can be bridged. This could be the reason why we have paranormal investigators. Some of the evidence there is irrefutable and some is bunk.
It seems to me that the dark matter spectrum is subservient to the matter because matter displaces dark matter. The dark matter is there all the time except it doesn't actively run things. Matter runs the dark matter like a boat cuts the waves in the ocean. If there is an intelligence on that side of matter it would be of opposite logic to us. We are the gods then because we can do what they can not and need a vessel to make anything real in this world. They can enter if one wanted into our psych and enact change only if we let them. We are the gods. They have kept us down and out and always in the survival mode for far too long. We let them into our lives because we experience great tragedies or just becoming the beat stick for society. This is sad because we are all capable of more then this. Our potential is limitless. Our creativity unsurpassed and to them thats a beautiful thing they will never experience. So they use only what they have available to use, our own minds!
They treat us like the proverbial elephant from birth. They chain us to their ideas and punish those who go outside of the box and we learn this. They tax us to death and even after as well. They step on our families like they were nothing and rip our souls to shreds. They corrupt our minds with junk that they push on us and no sight of the end is clear. Until we realize that we are the gods then we will die in obscurity like all the rest of the greatest thinkers and doers of our times.
FreeEnergyInfo
INFO ....
www.freeenergylt.narod2.ru/anonimus_free_energy/
verpies
Quote from: forest on June 10, 2012, 09:01:59 AM
Here is my theory what sr913 device is, very very simple.... it is a switch turning on/off magnetic field or rather permeability of core
Do you mean ?:
1) "switching" the absolute permeability of the core (μ = B/H) as in a Reluctance Switch or Flux Switch
2) "switching" the differential/incremental permeability of the core (μÎ" = Î"B / Î"H) as in a Variable Inductive Reactance
frantz
Quote from: FreeEnergyInfo on June 11, 2012, 02:34:04 AM
INFO ....
Hi FreeEnergyInfo,
I think this scheme is next fake.
If you will look on switch inside "CAN", you will see switch which running HV transformer.
Inside movie from 2004 you can observe two stages of running the device:
1. connecting power plug in and direct start of HV gap
2. connecting load by switch on the can.
and what is strange on there? Man who's switching on the load, did this action several times.
Question why this man did this operation several times? For protecting some parts inside device?
Why device didn't start immediately?
Why device didn't stop immediately when was switched off? Maybe device had some condensed electrostatic fields (not magnetic)?
I think, the key to this device is inside electrostatic field. Magnetic field is important on the output transformer (coil).
Frantz
