0 Members and 353 Guests are viewing this topic.
captainkt
@frantz, nearly all Kapanadze devises have two stages of start up. Possibly due to both HV and LV being used. When I am experimenting my devices do not simply start up without some switching or fiddling to get spark gap working.Also I would not expect device to stop instantly if it did then I would be suspicious.
captainkt
jbignes5
On almost all of his videos there is the temporary source applied to the device then 10 seconds of charging like action then removal of the source. Cap? or static capacitor oh wait they are the same... A laden jar is the device that either can be used for electricity and or static. Hmm. Never really thought about static from the thin air. When using those kinds of oscillations some static effects would be happening to the air and matter. Hmmm
Wouldn't the crossing of two same static sources through a polarization field change the polarization of that same field simply by the direction the wire is fed through the fields?
Is this the same technique they are using to organize the static they get from the Testastika. Except they use magnets or coils to polarize the static to either polarity to make it useful high voltage to be stepped down to add real current to it. This could be compared to the Avramenko plug type of a setup. Just separating the positive from the negative would do this and thats what the Avramenko plug does.
Some more good research:
http://www.youtube.com/watch?v=xCTkGgKZDKA&feature=related
I told you silicon won't work for this system. Thats why Tesla used a spark gap! Silicon is to sensitive to static electricity anyways.
Would this make my idea of using the magamp to switch the input a valid idea with merit then?
Hmm some interesting stuff about static and silicon. http://static.usenix.org/publications/login/2009-10/openpdfs/vandrunen.pdf
Hmm interestingly.. "If you need to ship ESD devices, use ESD-protective bags or wrap them in aluminum foil and put them in an antistatic plastic bag. Note that if there is a battery on the board you should not use aluminum foil, as you may short-circuit things"
Aluminum?? Tesla liked aluminum...
And this about jfet's:  http://www.allaboutcircuits.com/vol_6/chpt_5/9.html
Some tid bits on static and electric lines:  http://www.youtube.com/watch?v=puTZvhOFpRA&feature=related
http://www.youtube.com/watch?feature=endscreen&NR=1&v=WcSSWN4Tnoo
This was not entirely related but has to do with plasma and lasers. Pay attention to the ball of plasma they make and the curious pattern the ball was making on the wall. You could think of it as looking through the center axis of the plasma ball with the laser light being bent while going trough the plasma.
http://www.youtube.com/watch?NR=1&feature=endscreen&v=jBjqT3AQkH0
forest
Quote from: verpies on June 11, 2012, 04:48:50 AM
Do you mean ?:
1) "switching" the absolute permeability of the core (μ = B/H) as in a Reluctance Switch or Flux Switch
2) "switching" the differential/incremental permeability of the core (μÎ" = Î"B / Î"H) as in a Variable Inductive Reactance
I think only experiments with working unit will give answer. Personally I think more like reluctance switch but not exactly.
Some videos proved that rings used in sr913 device are permanently converted into magnets, then demagnetized and then again converted into magnet of opposite polarity. This effect is imho the direct cause of ou, very initial time of creating magnet and destroying it.
frantz
Quote from: jbignes5 on June 11, 2012, 09:21:30 AM
@jbignes5
do you have some idea how to do some kind of experiment?
yfree
Quote from: verpies on June 05, 2012, 01:01:21 PM
Zeitmaschine thinks that devices with ferromagnetic cores are a different class of devices and Kapanadze's devices do not work according to the principles described by McFreey
This can only mean that Zeitmaschine "hat den Artikel überhaupt nicht gelesen". :)
