0 Members and 116 Guests are viewing this topic.
frantz
Quote from: jbignes5 on June 12, 2012, 10:34:07 AM
The inner is a bifilar but it is for the grounds. It is what gives the ground polarity and a direction of flow. It is the valve basically. It controls the direction via direction of turn vs polarity and direction of the blast released into the coils from the heavy exciter coil. So you get a very intense pulse from a heavy mass copper coil into a Tesla coil type semi bifilar coil. I say semi because the return coil is only partly wound. This makes it respond only to part of the polarity of the blast with the excess going to ground. This causes an uneven ground loop to form and when that happens it is like hooking a paddle wheel to Niagra falls. Huge amounts of current get developed from that loop. Even small loops can create massive currents. As long as you can keep the valve open the unit will run in reverse then, sucking anything it needs from the ground loop currents.
You have to be very careful of these currents they are extremely powerful in some situations.
Curiously this is the same thing we are attempting to do in the crystal battery. The process is the very same process in both applications as far as using a bond of two different metals (iron, water pipe) and aluminum radiator. There will be a measurable power
Hi jbignes5,
You are taking like person who's build this device. If yes, help us to build our one...;-)
I think, bifilar is puted and is connected nowhere, is looped it self (shorted). When we start excite this bifilar via short pulsed magnetic field (week) and in the same time to light a half bifilar via electrostatic field, we are generate wave inside bifilar. What is important there? We should to feet frequency of pulses to creating standing wave inside bifilar. When we have standing wave on there, we have maximum current on there. If we have maximum current, we can add secondary winding for receive OU power.
I'm not talking about 50Hz. For this we can add additional circuit.
Frantz
P.S. Comments are welcome.
jbignes5
Quote from: frantz on June 12, 2012, 10:55:07 AM
Hi jbignes5,
Frantz
At the moment I am building another project. What I am doing is getting enough information from whats available and letting it discover itself. If it was built on a principle then that principle will be revealed. But I'm pretty sure this is an inductive ground loop between two points or groundings. Once started it would act like a pressurized hose. Slap a coil around the hose and it will induce a movement in the coil. Increase the resistance or even capacitance on the load and the device compensates to fulfill the draw. By the way the coil I was talking about would be the semi bifilar solenoid coil or load coil. The bifilar would not be shorted all the time. Unshorting it would allow the current to be used in my previous design but thats not what Kapanadze did. He used the bifilar coil to inductively couple the two grounds. This changes the character of the current. One it allows a massive ground loop to form through induction and it also allows fo an enhancement to the ground via discharges from the exciter coil. The load coil will picjup both polarities from the discharge and store it for a quick moment. This allows the second bifilar to suck up as much current as possible from the ground response to the pulses. This response is of a very different character then we are traditionally taught. They are unorganized clumps of charges that are slowly leaking into our atmosphere from our point. These charges would be wasted otherwise. It is the suction of these charges we want to divert into our devices. Once polarized they are capable of great movements and I suspect it doesn't take much to cause the flow of ground currents.
There is plenty on the subject of ground loops and how it plagues any equipment that is common grounded. Great amounts of literature is out there extolling the causes and ways to protect against it with only the light based versions being a true way to interrupt the ground loop. There seems to be no way to get around it without 200 dollars worth of additional equipment. Well why would we need to get around it then since most power companies rely on the ground loop for operation when the went the 220 volt route. They needed and additional ground safety link and hence is mostly there to protect against transients to a limited success. So ground loops are a must. Now is there a way to harness this ground loop to our advantage???  Kapanadze thought so and tried to show it in his limited way.
So anyways I digress yet again. I am planning on building this next after I have fully figured this out to my satisfaction. Most of which I think I have accomplished. Some of my point seem to be weak but I think I am understanding what Tesla and others saw and did.
What I was thinking is that we could fix this passively. Well inductively. What we do is poke a hole in the surface of the earths charge and let it squirt out and induce what power we need. Of course with any surface like that we need to make sure we absolutely control the aperture. This is kinda built in to the Kapanadze device with clever reflecting and harvesting of the polarities into one steady stream with acceleration.
Lets look at this force in action:
http://www.youtube.com/watch?v=5sxuBsAFuI4
Now this guy doesn't know about the electric field he is playing with here. This is not heavy current stuff. It's 3k volts that is discharged from caps! Just because the exciter coil is a very heavy gauge does not mean it is magnetic. It's the electric field. Look at the effect of the pressure it can induce in the cans. Can =1 turn of metal Very high magnetic response crushing inward.
Remember about aluminum and magnetic fields right?
itsu
@ All,
in my last video (Capcoil 1) in post #11885 on: June 05, 2012, 12:49:14 AM  i showed my capcoil
being loaded to about 50V using my Woopy pulser (Kacher/car ignition coil).
When retesting this with a flyback transformer (= pulsed DC instead of the ignition coil which is AC),
i found that my capcoil was not loading well (few volts only).
Further tests showed that the reason for not loading the capcoil with the flyback was that
the flyback is not driven by my Kacher (= HV/HF), while the car ignition coil was.
So the reason the Capcoil is being loaded is NOT the pulsing of the coil by HV (DC or AC),
but purely the HV/HF (RF) generated by the Kacher coil and picked up by the AV-plugs on the caps,
probably in combination with the ground wires/multimeter wires (picking up the RF).
A video of this testing can be seen here: http://youtu.be/wtii5B5sxE4
Regards Itsu
jbignes5
Itsu,
Could you connect the hv hf coil to one end of the coil around the cap and see what the charging rate is then. Have you tried to connect both ends of the coil to each cap terminal then read voltages normally? Maybe doing both eventually could show the current loop we want to create. Also you might want to have a safety spark gap to handle excessive currents in between the cap and coil. This would allow a buildup and release in a natural pulsing mode. This gives you control over how fast the internal field is uncompressed by the discharge. The spark gap should build up voltage levels like loading a spring. The shorting of the gap facilitates an instant release inwards then outwards of the field. Just like in the video of the aluminum can crushing. The internal bifilar should be around the cap but you are showing that the cap can and will be charged when exposed to this field.
Now move the cap to the inside of the field and see what the results are. The inside meaning the capcoil design.
I'm thinking you only need one end of the wire of the Tesla coil. Just affix it to one end of the cap. The other terminal can be connected to a virtual ground or antenna or even a block of, say aluminum. Copper seems to exhibit super excitation in this field and mixed with winding direction you can polarize the space in and around it(coil). And yes this stuff is like RF except for one thing. It doesn't bother biological matter. And the other matter that it excites has a vast array of effects like super excitation. In metals this excitation is as follows.
Iron: ??? /heat
Copper: Heavy current/heat
Aluminum: Excessive voltage/heat
These all vary to the magnitude to each attribute. So what does this tell us then. When using excessive voltage we should use aluminum as an interface and when we want to convert the hv low current to lower voltages and higher current we should use copper 1 turn being the best or highest efficiency for transmitter to multiple coils for more powerful effects from recievers. More copper that is exposed to this field the better it resists the flow and chokes the pre-aperture slightly. This resistance can back flow into the aperture and we need a way to control that backflow. Thats what the load coil 1/4 wave flapped solenoid coil is. You could say we are creating a magnetic bottle and capturing the flow by induction in a diode like fashion. This might be a version of propulsion like the lifter technology.
On another note I started research on the ground loop phenomena and came across this.
"Hum reduction transformers or common mode coils are constructed with either 75 Ohm twisted pair (made of fine wire) or coaxial cable wrapped around a very high permeability core. Most basic hum isolation transformers are basically just coax cable wound on a toroid-type core. They work by mutual inductance. The coax cable is wound around a transformer core so that both the inner and shield of the cable become inductors. The tight coupling ensures that any voltage in the shield caused by variations in earth potential are transformed into the inner conductor.
The method is an ancient idea and can cope with very large ground loop signals, and has very large bandwidth with very little loss. This type of anti-humming transformer also provides DC continuity between the input and output leads which is a good thing. The transformer does not stop ground loop current flowing (the amount of current is lower because of the added inductance) but the transformer reduces the current, canceling the effect of ground loop current. A Good one can reduce the ground loop effect up to 40-50 dB."
forest
Hi jbignes5,
Frantz
Oh boy.... exactly my idea. You take the cake!
