Zeitmaschine
Yes, no visible moving parts on Kapanadze device. Not even trimmer resistor or trimmer capacitor (only one moving fan).
Quote from: Hank Mills
Resonance between a primary and a secondary in a Tesla Coil is a function of many variables. Two of these variables include the physical length of the primary and secondary windings, and the frequency at which the primary is pulsed. There are mathematical equations that can allow you to calculate these factors ahead of time.
http://pesn.com/2011/04/29/9501818_Tesla_Coils_for_Dummies/
Maybe this is a silly question, but has anyone yet tried to run a Tesla Coil in Joule Thief mode?
http://www.bigclive.com/joule.htm
A Joule Thief circuit needs no VCO-IC like a LM566 (this LM566 idea seems from p. 409 anyway) and it needs no »mathematical equations calculated ahead of time«. It auto-resonates at its own frequency with just one transistor. So the idea would be, to apply manually a high voltage start pulse to the spark gap and the Tesla primary coil. This creates a voltage pulse in the secondary coil(s). Then this pulse is used for feedback to the transistor which drives the HV transformer (or whatever creates the HV for the spark gap) and therefore the next spark fires just at the right time in order to keep the primary and secondary coils in auto-resonance.
Quote from: cosmoLV on February 03, 2012, 04:43:26 PM
There are no much in his lab, Capacitors old TVs without HV transformers, and other old soviet parts and etc... But this are some 4, 5 years ago.
what has Tariel say at that time was that device is very simple.
..and at that time â€" in 2003 when Green box was filmed in his lab are no ossciloscopes (only old soviel frequency reader) thats all...
As it seems ...
But the relatively complicated circuit with a voltage controlled oscillator (and complex patent specifications) contradicts this. Very interesting!
jbignes5
 Standing waves...
Thought I would do an extensive research on that and low and behold strings or lines came up.
http://www.youtube.com/watch?list=PLF71B362214423F9D&NR=1&feature=endscreen&v=vqv0hy_4iKM
http://www.youtube.com/watch?v=gBWAPKDSxks&feature=BFa&list=PLF71B362214423F9D
Now add Longitudinal wave:
http://www.youtube.com/watch?v=aLAB-d8VnZ8&feature=BFa&list=PLF71B362214423F9D
And wave theory:
http://www.youtube.com/watch?v=IforxtGa2n4&feature=BFa&list=PLF71B362214423F9D
http://www.youtube.com/watch?list=PLF71B362214423F9D&feature=endscreen&NR=1&v=lt8z9xLFBDA
And on to the electric field.
http://www.youtube.com/watch?v=NvNd-0AYAVg&feature=BFa&list=PLF71B362214423F9D
The wave theory and tubes is very telling to the method done by Kapanadze. He is sort of using gusian surfaces to create a pumping wave through the device. My including of a element that has capacitance and be energized should make it happen very easily. Each video shows a component of the system. From lines to forces we should be able to simulate and design a working pumping device.
Hmm.. What does our military know by now? http://www.youtube.com/watch?feature=endscreen&NR=1&v=leCEmJA0WsI
hmm this has got to be my favorite.  http://www.youtube.com/watch?v=VtzfKnUhL-A&feature=related
Shokac
Quote from: Zeitmaschine on June 14, 2012, 08:30:31 AM
Pattent is not complex.
It is very simply.
Frequncy adjuster/stabilizer is spark gap
Filter is condenser
HF generator is Juel thief for making high voltage
Bobins is coil.
Electronic component in this patent is transistors for Juel thief.
All electronic in aquarium device is for automatic start, for inverter and for automatic loop.
Again, TK with high voltage making current and put in standard voltage circuit (Inverter or grid)
frantz
Shokac,
tell me one thing.
Why inside patent TK have 2 coils?
Everybody talking about 3 coils...
What's up?
I don't see any resonator on there.
Do you know answer?
Frantz
P.S.
I will draw my idea in two variants and I will put it here.
Shokac
Quote from: frantz on June 14, 2012, 02:10:39 PM
Shokac,
tell me one thing.
What's up?
Do you know answer?
Frantz
Yes, have 3 coil.
1. Coil for HV in Juel thief
2. Primary coil with spark gap
3. Power Coil (Secundary). In this coil TK pump current with HV. (I don't no how)
