0 Members and 181 Guests are viewing this topic.
baroutologos
In responce to the diagram posted about the "biffilar shorted on itself" thing, i decided to make a draft setup from the existing objects in hand at my "laboratory" :) and to see if there is any potential in it.
I used my spark-gap Tesla coil that arched to a stand, this wire from the stand was feeding the biffilar (by wire) shorted on itself and then connected to common ground with TC and then a copper tubing (all coils same direction wound) forming 4 turns one end open the other to a 75watt load and then to a thick piece of wire going throught the tube and then to ground.
tesla coil, biffilar and thick wire had all the same ground (water pipe)
I run the system and nothing completely happened. Not even a faint glow of the lamp. Nothing, I tried to re-orientate the coil in relevance to TC yet nothing...
I tried also to cap pulse (instead of using HV from my Tesla coil) with 12,5 nf cap at 2-7Kv the biffilar scheme. nothing also.
My Conclusion
I wonder who makes those schematics? Have he tried them? Has he maded any specs? Can he explain the priniple of operation or he is talking bull? I know they try to help but...
IMO, in trying to re-engineer the Kapanadze device, you must answer first two questiosn:
1) where should the energy comes from
2) how is supposed to be captured.
Salutes,
forest
your spark is spark : violet weak one , but you will need arc, silent solid white or green something like that in kapanadze video.
baroutologos
forest:
your spark is spark :  weak one , but you will need arc, silent solid white or green something like that in kapanadze video.
Lol man.
xenomorphlabs
@baroutologos:
Good effort!
QuoteIMO, in trying to re-engineer the Kapanadze device, you must answer first two questiosn:
That is exactly what i have in my mind as well.
As long as that is not figured out, you will end up building
an ordinary tesla transformer.
1) There is only a limited number of possibilities where the energy is coming from.
According to Kapanadze´s patent details, it is entering the system between the first and second bobbin (how he calls it)
2) The energy is captured at resonance with the coils.
Other candidates are magnetic distortion effects or maybe
capacitive effects.
It is for sure no "simple transformer effect-only" because the coupling factor is always limited and linear.
It must be a non-linear effect otherwise you would not go over cop of 1.
Avalanche breakdown of the spark gap could contribute to it too.
Keep it up, i am building a set-up too currently, but i want to go a slightly different route to test the possibilities out.
grizli
Quote from: baroutologos on April 01, 2010, 03:10:38 AM
My Conclusion
Salutes,
BUT "MAD" video use oposed turned coils I mean not classical bifilar, but magnetic field is crossed and he got light
try classical tesla bifilar that does not  cancel magnetic field
