Zeitmaschine
Quote from: Shokac on June 14, 2012, 03:42:06 PM
Take 7 thing on the table. HV diode, normal diode, high freqency generator for make high voltage, smal bobin (coil) and conedenser (1,2 or 4). Spark gap.
If connect spark gap between condenser HV generator and coil, getting resonance circuit. Spark gap is use for automatic change frequency in ac circuit. Or for condenser discharge in DC circuit. Talking about HV circuit.
Sorry, I can't visualize this. Could you please draw a quick diagram of it? :)
forest
Spark is the most simplest and I would say the best in economy modulator. Again is not an invention of Tariel but even Tesla do not stated it was him when presented his method of conversion in 1893.
itsu
Hi Jbignes5,
QuoteItsu,
Could you connect the hv hf coil to one end of the coil around the cap and see what the charging rate is then. Have you tried to connect both ends of the coil to each cap terminal then read voltages normally? Maybe doing both eventually could show the current loop we want to create. Also you might want to have a safety spark gap to handle excessive currents in between the cap and coil. This would allow a buildup and release in a natural pulsing mode.
i tried to do severall tests like you suggested, but as i have to wait for some spark gaps (arrestors), some tests are not possible now.
I definitely need spark gaps to protect my capacitors from overloading.
Here the results up till now:  http://youtu.be/xDXR2QyTW_Q
Regards Itsu.
Shokac
Quote from: Zeitmaschine on June 14, 2012, 04:18:19 PM
This is like Lego....
if put right cube to the right place you have right staf. :-)
