0 Members and 91 Guests are viewing this topic.
Zeitmaschine
Quote from: Shokac on June 14, 2012, 05:44:03 PM
if put right cube to the right place you have right staf. :-)
So as it seems I have wrong cube.
My current secondary coil (bifilar) resonates at approx. 2.4MHz (see screenshot of oscilloscope). To get resonance with spark gap I need high voltage with 2.4MHz (in my understanding). But unfortunately my spark goes off when I go beyond 250KHz.
Hence, any Ideas how to act further?
starcruiser
try to use a harmonic of the 2.4mhz, lower the HV source to 240khz as an example. you just need to kick it
Regards,
Carl
jbignes5
Quote from: itsu on June 14, 2012, 05:03:09 PM
Hi Jbignes5,
i tried to do severall tests like you suggested, but as i have to wait for some spark gaps (arrestors), some tests are not possible now.
I definitely need spark gaps to protect my capacitors from overloading.
Here the results up till now:  http://youtu.be/xDXR2QyTW_Q
Regards Itsu.
Excellent.. I do appreciate your professional manner when showing what you have discovered. The spark gap is very important to the successive experiments after the first. What we are trying to do is build a dam and let it overflow across the gap. This should create a very substantial current flow as suggested by Tesla and others. Just make sure you have a safety on and off at the cap/coil. and between the HV of the katcher. Just to be safe.
Another suggestion is to put some space in between the coil windings beyond the first coil wrap.
Yet another experiment is what would happen if you replace the copper pipe in the Katcher to the cap by itself? With safety gap!!!!!! Please approach the coil top with very easy movement and monitor the cap as it goes in the Katcher coil.
As I thought we can energize a cap just by the electric field so if we move this inside the Kanadze system it should become the source potential. Then all we need to do is put the shield coil around the bifilar and then the collection coil outside of that with another shield coil around that. The shield coil on the outside will always be on or shorted. This is to reflect all input by the bifilar into the main capacitor. the collection coil is there for collection when the internal shield coil is un-shorted. So when we short the internal shield coil it gains speed by reflecting back and forth between the cap and near reflector. Once the reflector is un-shorted it will pass the super excited energy twords the collection coils. Then immediately short the first again to let it build up again.
Yeah so the second cap must be done differently. Try it directly connected to the cap can. This you might want to do at a lower voltage, if you can adjust it.
Thanks for the video it helped tons to see it going and came to the same conclusions as you did. By the way did you connect one end of the cap/coil to ground? You probably should or to a slab of metal... It should increase the results.
P.S. It's a phonetic. J Bigness.. Yes thats my real name...
jbignes5
Quote from: Zeitmaschine on June 14, 2012, 06:10:29 PM
Add a pair of magnets to the spark gap...
stivep
http://amasci.com/tesla/tmistk.html
http://montalk.net/notes/longitudinal-waves
, longitudinal waves do not violate Maxwell’s equations, rather they are what Maxwell termed
current. Usually current is defined as a flow of charges. But across a capacitor consisting of two conductors separated by an insulator that allows no charge to pass, oscillating energy can still transfer. Physicists aren’t sure precisely how to explain displacement current other than that the changing electric field from one conductor induces a magnetic field that induces another electric field on the second conductor. However if the conductors consist of one spherical electrode inside another,
all the magnetic fields cancel and yet there is still a displacement current
. This proves that the displacement current is nothing more than a longitudinal E/M wave in some cases. In other cases a magnetic field might indeed play a role, but the Maxwell equations allow for either possibility.
I think I have got something:
http://www.godlikeproductions.com/forum1/message162830/pg1
That could explain John Hutchison
And possibly World Trade Center phenomena might be  analyzed by that  token.
If energy density is to be at one point at given time than
impact must be felt at that particular point
Imagine that you are taking shower where shower  head has parallel dishes and pressure start to  fluctuate
You will feel that concentration of energy.
If than you compare it to garden hose  than you may push the sand or damage the green at given point just by  fluctuating  longitudinal wave
If than that longitudinal wave is upside down  facing up than balls on the top of it will levitate.
So if Army say is in possession of such or say John Huthison was in possession of one than he could damage or levitate objects.NMR THAN IS ADDITION TO LONGITUDINAL WAVES that makes  transmutation happened.
Than you connect two of above and you might have possible dustification of towers.
Theory of Dr Judy Wood is than impliable attribute .
So was Tesla envisioning wireless electricity or
idea of a Tesla directed energy weapon causing the Tunguska..... to the area in 1927 to find evidence of the meteorite presumed to have caused the blast
http://prometheus.al.ru/english/phisik/onichelson/tunguska.htm
SUMARY:
Think please.
If I'm right we than have theoretical  skeleton to explain  everything including
-Tesla wireless electricity transfer.
-Tariel Kapanadze
-9/11
-Tom Barden experiments
-John Hutchison antigravity and  transmutation\\
- ultimate killing machine.
-dustification and more.
Schumann resonances
Please first
1. view interactive video on right side of the screen in Wikipedia ( push the button below)
2. concentrate on electromagnetic resonance series pattern
3. notice that if originated at one point   than travels to ionosphere and  reflects causing series of lightnings in another parts of the world.
http://en.wikipedia.org/wiki/Schumann_resonances
How do I see it.?
1.HAARP   may send Longitudinal Wave at certain angle in form of beam.
2.  That causes reflection by ANGLE OF INCIDENT
3 That is precise tool  of controlling geographic  XYZ of target point.
At september 11 of 2001 we have had hurricane #3 in NY that was just waiting next to Long Island for few days and not many people know about it. It  was not in the media :) And than disappeared.
We do not need much of of energy there. Resonance is the key
In area of  weather we use it just as a trigger . By  adjusting  concentration of energy we hitting target with energy bullet.
In area of total destruction we still are able to have guided weapon the only diameter of the beam and focusing  of beam is in question AS I HAVE NO KNOWLEDGE IN THIS AREA
Amplification  of beam properties or coupling to it ,using natural resources  of that existing energy is pure speculation
So I'm asking  you
what if for some  weird reason I'm right.
Than all "they" need is to know what Tesla known and what science  oppose to know.
but by recalling side effects of Lithuania experiment
"they" can  be in possession  of ultimate  weapon against all of us.
  just think...............................
term "they" or "them" is reserved to real terrorists, the real one  responsible for killing thousands of people
Supporting material:
Light is electromagnetic wave  too.
Super-resolution and non-diffraction longitudinal polarized beam
http://arxiv.org/ftp/arxiv/papers/0709/0709.2748.pdf
longitudinal field has many
attractive applications, e.g. in particle acceleration [2, 6,
7, 13], fluorescent imaging [14], second harmonic
generation [15-17] and Raman spectroscopy [18]. It can
permit the achievement of higher resolution in  zpolarized confocal fluorescence microscopy [19] and
scattering scanning near-field optical microscopy [20].
The longitudinal field can be suppressed or enhanced
by amplitude, polarization and phase modulation of the
incident beam [21]. For example, a longitudinal field can
be completely suppressed in an azimuthally polarized
beam
Wesley
