0 Members and 478 Guests are viewing this topic.
baroutologos
Coils, capacitors and resonance...
Good points Xeno there. lets apply the Socratic method and find out... our ignorance.
The energy is inputed to the system between the two coils, claimed by Kapandze. What type of energy is that? Electromagnetic? Heat? Cosmic radiation? Ether...?
Why the energy to go between a set of coils? It interacts with the magnetic field or the wire :) ? Thus the magnetic field influences the "unknown energy" and it is transmuted to useful electrical one? Why not to heat? And if so via what procedure?
Resonance
Ok from my experimental work so far with low inductunce high capacitance and high inctuctunce low capacitance (telsa resonators btw have the best resonance) and from all the OU community we can safely conclude that LC resonance alone has not any potential at OU.
Storing energy with some losses at best and obtaining some interesting results.
So it is reasonably to conclude that resonance at best is a tool of collection if applied.
Still we are aknowledging our blindness, thus randomly everyone makes schematics and drafts of how is supposed that machine should work, yet does not understands what might be the process (if existed) that the energy should stem from.
Its like a middle-age man to see an automobile and tries to assemble parts he sees yet still have not a basic understanding of how an internal combustion motor operates.
Whoever has any hint based on experimental work should post it here.
@grizly,
Try that and tell me ;) As far i see from MAD, he spents some 538 watts to light 5 lamps at their 40-50% nominal luminocity. My setups are far more efficient than his.
xenomorphlabs
Well a hint could be that pretty much all replicators tried to tune to electrical resonance.
Remember Smith sais that the electric path won´t get you anywhere, only the magnetic path.
So it seems likely that he means (Electro-) Magnetic.
Look at the Tesla coil not only as a  transformer but as an antenna/receiver system. The more advanced Tesla coil freaks argue for a long time that a Tesla coil is merely a transmission line and i agree with that, because certain things can only be explained with this approach.
That is something that i am currently experimenting with
baroutologos
So you say, and I know that electrical resonance is a deadend. Accepted...
What if -the natural question arises- The "magnetic component" is the other type of resonance called "Magnetic resonance" extensively used at MRI for medical reasons... :)
Each element has a particular Larmor frequency. Is tha type of resonance assosiated with OU?
xenomorphlabs
Quote from: baroutologos on April 01, 2010, 09:21:35 AM
Well MRI uses EM-waves between 1 MHz and 100 MHz (typically),
so that´s the same pair of shoes.
Good point with that Lamor frequency, i guess it needs to be tested.
Maybe you can get copper to resonate and increase the current somehow.
But i personally think it is more a resonance like in a tuned antenna.
grizli
Quote from: baroutologos on April 01, 2010, 09:04:36 AM
You are probably VERYYY WRONG !!!
Lets make 3 coils, all the same diameter
1) 5 turns = 1.43uH
2) 100 turns = 57uH
3) 400 turns =235uH
PRIMARY :
5 turns 1uF = 133khz
WE CHARGE capacitor to 1000V, energy = 0,5 J  energy=0.5Q*V*V
FIRST TEST : 100 turns secondary
PRIMARY RESONANCE = SECONDARY RESONANCE = 133khz -- secondary capacitor= 25nF
ELECTRONS IN THE PRIMARY ARE NOT THE SAME AS ELECTRONS IN THE SECONDARY !!!!!!
THERE IS NO BACK EMF IN RESONANCE transfromer (its not classic transformer in resonance SPEED of Pendulum is not killed
if in resonance we such eletronc from ground than Q1 is NOT Q2
SECONDARY capacitor energy W=0,5*C*V*V    N1/N2= 20,  V2=20 000V, W= 5J (5 times more than input 0,5 J)
secondary 400 turns , W= 20J
SIMPLE TEST MUST be done using SCOPE which I dont have: primary in secondary first must be PERFECTILY IN RESONANCE using tuning capacitors !!!
The PRE CHARGED C1 capacitor is discharged into primary  and we are coping C2(secondary capacitor)(memory single pulse exponential tesla wave, digitl scope memory should be used)  IF IT IS REALLY POSSIBLE TO SUCK ambient electronc C2 voltage should be N2/N1
IN EVERY  pulse we have proportional to N2 is output energy..
than we just COLLECT from secondary capacitor to big tank capacitor : To one end of TC secondary is spark gap(or noble gas gap that fires at exact voltage) set up to maximum L2 voltage when C2 is charged energy goes into tank capacitor: tank capacitor has fast diode!!!
MAKE EXACT TEST AS I described.. I  can not measure than i dont have scope for now..
and coils must be PERFECTLY in resonance !!! MUST tuning capacitor or inductor be used
primary and secondary MUST have THICK copper wire to disable resistance loss (12awg 200 turns secondary would be nice)
