stivep
Quote from: Zeitmaschine on June 17, 2012, 09:15:49 AM
Today I'm trying to think profoundly simple:
Could it be that the TMZ setup in the yellow tent is made with coils out of quadfilar wire? If so, then the two coils in the obscure patent specifications (which are looking suspiciously bifilar) are combined to one quadfilar coil.
Question: Why is there obviously no exciter coil drawn on the patent? The exciter coil in the tent setup could be hidden in the base of each of the three coils - or it could be not. Next question: What happens when high voltage pulses are being applied not to an external exciter coil but to one wire of the quadfilar coil itself (if strength of insulation allows)?
Thus obtain a lot of quadfilar cable, wrap it around an old cardboard tube, connect it the right way to high and low voltage, receive free energy en masse.  :D
Thank you  very interesting
Wesley
FreeEnergyInfo
sparks
  If you go back to TK's first video and watch it you see that he is definitely working with Tesla's magnifying transmitter.  What you can do with a Tesla transformer is create storage of energy.  We know that mass is the equivalent of energy.  As you store more and more energy in the oscillations within the Tesla transformer you are transforming energy into mass increase of the oscillator.  Watch out how far you go in increasing the mass of the oscillator.  e=mc2 and the rate is determined by delta v/deltat.  You shorten up that t parameter you got trouble.  Enough said.  So what did tk do with the high voltage monopole produced by a Tesla coil?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
wattsup
@all
I have tried to make this circuit work for I don't know how long now, without any luck at all. Damn thing just does not want to pulse. So I have had it with circuits, making circuits, and blowing components. I have to concede that I will never be able to pulse things the way I really want to because the circuits are not available and making them myself is just not in the cards.
Now if this is happening to me then it should be happening to at least 1000 other guys just like me around the world. My forté is in the water treatment field but my main forté is business. My business side says if I had the proper skills, and if I wanted to help the OU effort in anyway I could, I would open up a small business called OUCircuits dot com and sell premade circuits of all kinds to OUers around the world, always being paid by Paypal.
I can build coils, buy components, establish and do experiments of all kinds, but the circuit part is definitely not for me.
So, if there is a smart ass out there that has access to components and that can build circuits and would like to make and sell them to me and to 1000s of others, I am more then sure it would be worth the time and effort.
Also, just imagine if such a circuit service was possible, HOW MANY GUYS WOULD BE USING THE SAME CIRCUIT FOR QUICK REPLICATIONS. This would push the OU research further and faster and wider then now possible with everyone always making their own circuits in so many different ways and then wondering  why the hell people cannot replicate this or that effect. Imagine if the Lithuanians were using the same circuit you and I would use.
Anyways, I think I made my point.
Maybe if there is an EEer in the Terrebonne, Quebec area that would like to work in OU as the circuit master, please get in touch with me.
Until I find a solution to my circuit qualms, I am stopping OU research of TK style high voltage systems and going back to low level devices where I have total control over the variable frequency, duty and amplitude. Making fixed HV systems are a dime a dozen and are just looking for a needle in a hay stack with only one look. If you cannot work HV pulsing in variable frequency mode then as far as I am concerned, you are wasting your time. Everything has to do with the right frequency makes the best effects. Yes a single frequency will always work but you could be 1kHz away from fantastic effects and not ever know it. If the dilemma of secure variable frequency pulsing cannot be resolved, then from what I can see, we are just wasting our time just shooting in the dark.
wattsup
DreamThinkBuild
Hi FreeEnergyInfo,
Thanks for the info.
Would it be possible to remove the switch and just cut the signal? Instead of a magnet use a solenoid above the gen coil and feed in a split sine wave.
Not sure if it would have the same effect, something else to try, but here is the Octave/Matlab code to generate the signal. It can be saved as a sound file and looped through a power amp.
Code:
%Name: CutAtPeak for Octave/Matlab
%Description: Generate a cut sine wave at peaks
%By: DreamThinkBuild
%Date: 6/17/2012
%Clear up variables
clear;
clc;
Freq=200; %Signal frequency in hz
FS=96000; %Frequency sampling rate
t=0:1/FS:1; %Time for 1 second
%Convert frequency to samples in quarters
SampleSplit=(ceil(FS/Freq)/4);
%Construct both halve's of signal into OutSig
OutSig=[sin(t(1:SampleSplit)*2*pi*Freq) cos(t(SampleSplit*2:SampleSplit+(SampleSplit*2))*2*pi*Freq)];
%Output to wave file
wavwrite(OutSig,FS,32,'SplitSine.wav');
