0 Members and 68 Guests are viewing this topic.
jbignes5
Quote from: wattsup on June 17, 2012, 05:04:37 PM
@all
I have tried to make this circuit work for I don't know how long now, without any luck at all. Damn thing just does not want to pulse. So I have had it with circuits, making circuits, and blowing components. I have to concede that I will never be able to pulse things the way I really want to because the circuits are not available and making them myself is just not in the cards.
Now if this is happening to me then it should be happening to at least 1000 other guys just like me around the world. My forté is in the water treatment field but my main forté is business. My business side says if I had the proper skills, and if I wanted to help the OU effort in anyway I could, I would open up a small business called OUCircuits dot com and sell premade circuits of all kinds to OUers around the world, always being paid by Paypal.
I can build coils, buy components, establish and do experiments of all kinds, but the circuit part is definitely not for me.
So, if there is a smart ass out there that has access to components and that can build circuits and would like to make and sell them to me and to 1000s of others, I am more then sure it would be worth the time and effort.
Also, just imagine if such a circuit service was possible, HOW MANY GUYS WOULD BE USING THE SAME CIRCUIT FOR QUICK REPLICATIONS. This would push the OU research further and faster and wider then now possible with everyone always making their own circuits in so many different ways and then wondering  why the hell people cannot replicate this or that effect. Imagine if the Lithuanians were using the same circuit you and I would use.
Anyways, I think I made my point.
Maybe if there is an EEer in the Terrebonne, Quebec area that would like to work in OU as the circuit master, please get in touch with me.
Until I find a solution to my circuit qualms, I am stopping OU research of TK style high voltage systems and going back to low level devices where I have total control over the variable frequency, duty and amplitude. Making fixed HV systems are a dime a dozen and are just looking for a needle in a hay stack with only one look. If you cannot work HV pulsing in variable frequency mode then as far as I am concerned, you are wasting your time. Everything has to do with the right frequency makes the best effects. Yes a single frequency will always work but you could be 1kHz away from fantastic effects and not ever know it. If the dilemma of secure variable frequency pulsing cannot be resolved, then from what I can see, we are just wasting our time just shooting in the dark.
wattsup
Heh.. tried the mag amp yet? You can even build one yourself. just need two toroids. There are plenty of diagrams for the coiling to get any type of transistor or switch that you need, with feedback or not!
You know it must be good if the military used it. It was a very robust replacement for tubes in the radar systems they used. Trust me you will have full control over the magamp.
Don't give up.. Keep trying but use what works. Silicon doesn't work for the voltages we are trying to use here. The best magamps I have seen were rated pretty good. We only need about 20-100k cycles... and the conductors can be rated for very high voltages.
You also might want to try woopy's katcher pump. It seems to be very nice to energize metals.
@ itsu I wonder what would happen if you wrapped that coil around a resistor... Would the resistor get energized as well? And finally around a solenoid coil and read the output from the coil. Tesla said to terminate the load with a mass of metal. Thats why you got no results from the other tests. This katcher is actually the Tesla coil. But instead of using a copper pipe in the middle he connected one end of the source to the load then connect to a metal mass. So both the Tesla coil and katcher should be able to use one wire methods directly connected to the blue flame point..
The bigger the metal mass the better. Tesla also said copper was a good source for amps as a terminator. You guys are still thinking in terms of regular current. This is a pressure hose. A pulsed pressure hose. In that sense any coil would act like a diode or check valve, moving freely in one direction and rather inductively impeding in the other. This might be related to his vacuum pump. He made one that he could get any vacuum out of. I think there is a schematic for it in his patents. I'll have to look to see what it entails and if it indeed is related.
Not the vacuum system yet but is very related to the system we are looking at...
http://www.teslauniverse.com/nikola-tesla-patents-454,622-system-of-electric-lighting  This is a one wire system sorta but look at the driver before the big loop!
And this explains what you need to do when the frequency is very high or the voltage...
http://www.teslauniverse.com/nikola-tesla-patents-514,167-electrical-conductor
Hmm read this one and tell me what it is saying... Lots of info in this one...
http://www.teslauniverse.com/nikola-tesla-patents-514,973-electrical-meter
sparks
@all
wattsup
Hey wattsup how you doing besides being frustrated. :( :)    Don't get caught up in the details.  Replicators are replicators.  Simple experiments based on hunches.  Like this one.  Take a piece of copper wire and stick it in a piece of cork.  Put it in the microwave and turn her on.   Little spark show as the enamel burns off and then the end of the wire starts to heat up and glow stopping any further fast electron effects.  Now take a new piece of wire preferrably about 1 inch long and this time put a drop of water at the base of the wire on top of the cork.  Turn on the microwave with your finger on the stop button.  Study the effect.  Blue white light fills the microwave cabinet.  Why? What is making the blue white light.  Where did the drop of water go.  Why am I trembling like a leaf when my microwave becomes a water lamp.  Albert Einstein gave us the  statement mass is energy and prooved it.  Mathmatical nut cases went crazy with this formula trying to describe the beautiful process of creation in black and white.  Finally having to admit grey scale does exist.  Why would a process that creates the total diversity of life create boring little constructs all the same just because people can't see them.  Planck is the one that started this madness.  Assigning arbitrary constants to how big something can be.  Why cant an atomic neucleus with it's neutrons just be a fat proton with a degree of surface tension we call charge.  How can charge be negative and positive.  It's like saying hey I have two cars.  One you can see and one that isn't there.  If you buy into that then I own an estate that no one can see it is a negative estate.  You can buy a timeshare at my negative estate for some positive dollars.  It won't cost you anything cause I'll just give you some of my negative dollars in exchange.  Then we'll be even and you get to use my negative estate for a couple of weeks for free.  JEESH
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Come on, fellows, lighten up. It's just VRSWR.
https://www.youtube.com/watch?v=5gSXi3BkkNA
https://www.youtube.com/watch?v=_dAQ4c13wdw
https://www.youtube.com/watch?v=MBUfaYi02WI
ETA: for the microwave experiment Sparks suggests, go to the thrift store and get some glass "hurricane lamp" chimneys. Use a little spacer to space one up a bit from the bottom of the microwave oven (turntable removed) and do the experiment inside the chimney. Sometimes you will get a perfect "ball lightning" plasma ball in there, that can even persist for an instant or two after the MW power is off.
energia9
Quote from: sparks on June 17, 2012, 01:33:18 PM
  If you go back to TK's first video and watch it you see that he is definitely working with Tesla's magnifying transmitter.  What you can do with a Tesla transformer is create storage of energy.  We know that mass is the equivalent of energy.  As you store more and more energy in the oscillations within the Tesla transformer you are transforming energy into mass increase of the oscillator.  Watch out how far you go in increasing the mass of the oscillator.  e=mc2 and the rate is determined by delta v/deltat.  You shorten up that t parameter you got trouble.  Enough said.  So what did tk do with the high voltage monopole produced by a Tesla coil?
hello Sparks and EVERYBODY
I have made a PDF of my way of approach
I hope to help you with all my simplicity.
pLeAse download the file.
Thank you
forest
Quote from: TinselKoala on June 17, 2012, 08:24:27 PM
Offtopic here but I'd like to ask if vodka can still be lit by TC discharge after a few times you burn a little with flame ? Very insteresting  effect.Does it heat vodka ?
